» Fun times ahead
Brake light help!!! I_icon_minitimeby Loosemarbles Today at 3:49 pm
» Dashboard Square
Brake light help!!! I_icon_minitimeby MikeO Today at 4:11 am
» Hello From MD
Brake light help!!! I_icon_minitimeby GHM-PM Yesterday at 7:15 am
» LED Headlights
Brake light help!!! I_icon_minitimeby landisr Mon Oct 28, 2024 11:35 pm
Brake light help!!! I_icon_minitimeby DescendingRaven Mon Oct 28, 2024 5:15 pm
» Ignition Switch
Brake light help!!! I_icon_minitimeby POCAHONTAS Sun Oct 27, 2024 9:07 pm
» Lift Without A Lift
Brake light help!!! I_icon_minitimeby landisr Sat Oct 26, 2024 5:25 pm
Brake light help!!! I_icon_minitimeby xwelder Sat Oct 26, 2024 3:18 pm
Brake light help!!! I_icon_minitimeby xwelder Fri Oct 25, 2024 5:00 am
» Handlebar Holder Recall
Brake light help!!! I_icon_minitimeby xwelder Thu Oct 24, 2024 9:12 am
 Brake light help!!!
Bigmac90
Number of posts : 7
Registration date : 2019-06-03
Brake light help!!! Empty
PostSubject: Brake light help!!!   Brake light help!!! I_icon_minitimeSun Apr 12, 2020 6:56 pm
Hi everyone,
Hope you’re all safe and well.
I’ve just discovered on the way home from work that my brake light isn’t working as it should. The brake light appears to be constantly on. I’ve checked the switches on the levers, they seem to be switching fine, can’t work out why the light would be on all the time?
Any suggestions would be much appreciated!
Cheers!
J
GoonerKev
GoonerKev
Number of posts : 409
Registration date : 2019-04-09
PostSubject: Re: Brake light help!!!   Brake light help!!! I_icon_minitimeSun Apr 12, 2020 7:10 pm
J
Sounds like a bad earth somewhere in the line
Number of posts : 1384
PostSubject: Re: Brake light help!!!   Brake light help!!! I_icon_minitimeSun Apr 12, 2020 8:16 pm
Sounds like a bad brake switch sticking. Very small switches under lever area. Try pulling one connector of each side till problem is found. Left side has two switches but one is the starter limit switch more under bar and a bit larger.
AS stated above short is very possible also.
GoonerKev
GoonerKev
PostSubject: Re: Brake light help!!!   Brake light help!!! I_icon_minitimeMon Apr 13, 2020 2:32 am
That reply reminded me of my mate who had the same problem on his Silverwing a while back, yes it turned out to be those "2 small switches", problem was fixed.
Number of posts : 4214
PostSubject: Re: Brake light help!!!   Brake light help!!! I_icon_minitimeMon Apr 13, 2020 6:33 am
Or you might check out the two rear 12v 21/5w bulbs, they're dual filament and you could have a blown filament on one or both of them.
Bigmac90
Number of posts : 7
PostSubject: Re: Brake light help!!!   Brake light help!!! I_icon_minitimeMon Apr 13, 2020 4:07 pm
Appreciate the input guys.
I think it was the rear brake light switch! Again. Second one in 6 months. I’ll be fitting the new one tomorrow so I’ll know for sure then but having removed the old one and tested with a meter, it isn’t switching properly.
Murf
Murf
Number of posts : 172
Registration date : 2017-04-19
PostSubject: Re: Brake light help!!!   Brake light help!!! I_icon_minitimeTue Apr 14, 2020 11:52 am
To start my swing on a trip I had to use a fuse to jumper the brake switch on the left side.
PostSubject: Re: Brake light help!!!   Brake light help!!! I_icon_minitimeWed Apr 15, 2020 9:47 pm
[quote="Murf"]To start my swing on a trip I had to use a fuse to jumper the brake switch on the left side.[/quote
That's a good idea fuse to plug into connector-harness. thumbs up
Brake light help!!!
» brake light
» Brake light wiring.
» Can't buy a brake light modulator. Anyone help?
» Healtech brake light pro
» front brake light
