Latest topics | » 2003 ABS info on recall work by Erdoc48 Yesterday at 4:40 pm
» Handlebar Holder Recall by xwelder Yesterday at 9:12 am
» It's that time of year again. by Meldrew Wed Oct 23, 2024 3:31 pm
» Silverwing 600 Owner by GHM-PM Wed Oct 23, 2024 6:47 am
» I Need Help With The Brake Bleeding by zrx212 Sun Oct 20, 2024 4:57 pm
» New FPR, new vacuum pipes, still 22mpg by zrx212 Sun Oct 20, 2024 4:35 pm
» A strange howl by 53Scooterguy Sun Oct 20, 2024 11:56 am
» Tip For Bleeding Brakes by zrx212 Sun Oct 20, 2024 9:58 am
» Brake/Start Switch Availability by GHM-PM Sat Oct 19, 2024 7:31 am
» Passenger Back rest by Meldrew Sat Oct 19, 2024 4:36 am
| 2003 ABS info on recall work | |
xwelder Scooter Rider
Number of posts : 5 Location : UK Points : 17 Registration date : 2024-10-17
| Subject: 2003 ABS info on recall work Yesterday at 2:50 am | |
| Been searching round the forum for info. does anyone know how to check if the recall work has been done on the 2003 silverwing by previous owners ? the online vin check says unable to retrieve data ? thanks edit...found this....is this the total amount of work needed ? https://ibb.co/jG5ynzf |
Number of posts : 568 Age : 65 Location : Ocala, FL Points : 1984 Registration date : 2020-12-26
| Subject: Re: 2003 ABS info on recall work Yesterday at 10:33 am | |
| Before I got my SW600, I only found 3 "Highway Safety" recalls https://www.arfc.org/motorcycles/honda/silver_wing/recalls.aspx Maybe there's a different site with similar info on your area The only way to really know if these safety or other non-safety recalls have been done, is to check with Honda dealer, but info on a 20ish year-old scooter may be hard to find. One other possibility, usually parts that are replaced/upgraded for any reason, will have the new P/N, revised P/N or date of manufacture or some kind of marking/suffix denoting revision, etc. more so on safety items, it's mostly aimed at shop techs to id previous work, etc. If you find a P/N, check against a good parts catalog, on the Honda parts catalog when a part is upgraded the old/obsolete p/n will be "Lined Out" with new p/n next to it. Besides removing under-seat light bulb, to prevent discharging batt., SW600 are fairly bulletproof, AFAIK. |
| Subject: Re: 2003 ABS info on recall work Yesterday at 10:48 am | |
| - zrx212 wrote:
- Before I got my SW600, I only found 3 "Highway Safety" recalls https://www.arfc.org/motorcycles/honda/silver_wing/recalls.aspx
Besides removing under-seat light bulb, to prevent discharging batt., SW600 are fairly bulletproof, AFAIK. Thanks so for the 2003 model i should be looking at the lower handlebar mounts ? the fuel tank & bolts become loose in the main stand ? anyone got any info on where the tanks leaked ? |
| Subject: Re: 2003 ABS info on recall work Yesterday at 12:28 pm | |
| " anyone got any info on where the tanks leaked ? " There's several threads here on fuel tank failing/leaking, mostly due to rust, usually neglect/sitting/moisture condensation inside, etc. The recall is about stress cracks, literally when the scooters were new and is inspect/replace as needed, if your scooter is not leaking in 20yrs, you should be ok |
Number of posts : 363 Age : 71 Location : Bristol, UK Points : 1045 Registration date : 2022-12-23
| Subject: Re: 2003 ABS info on recall work Yesterday at 1:18 pm | |
| The only rusting issues I have found on a couple of FJs 600 models including my 09 is bad corrosion on the front lower curve to the bottom of the tank, where there is a rubber curtain protecting the tank. The curtain causes the build up of muck/ detritus between it and the tank causing aggressive surface rusting. You will need to remove the under cover, then inspect with a light and mirror between the rubber cover and tank surface.
Hope this help |
| Subject: Re: 2003 ABS info on recall work Yesterday at 1:52 pm | |
| - JohnyC wrote:
- The only rusting issues I have found on a couple of FJs 600 models including my 09 is bad corrosion on the front lower curve to the bottom of the tank, where there is a rubber curtain protecting the tank.
Hope this help thanks...will check this out |
Number of posts : 378 Age : 60 Location : Myrtle Beach, SC Points : 1270 Registration date : 2022-05-31
| Subject: Re: 2003 ABS info on recall work Yesterday at 4:40 pm | |
| Mine is an 03 with those recalls as well (I had my tank repaired by the prior owner- he paid for it so I think he had it re-welded)- the other recalls were the handlebar clamps and the center stand bolts- I’ve checked them and all is well and I’ve been riding it for 2 years now and never had any issues. I assume the original owner had them corrected (I think I’m the 3rd or 4th owner). I ride one and don’t stress about it.
Usually with a recall, it’s a relatively small number of bikes, so it’s unlikely to be an issue. You can check those areas reasonably easily (except the tank) and if all is nice and tight, ride on. |
