Latest topics | » Passenger Back rest by landisr Yesterday at 7:02 pm
» OE Quality Drive Belt by landisr Wed Oct 16, 2024 1:11 pm
» Mini-Mate Camper by MikeO Wed Oct 16, 2024 7:17 am
| | A strange howl | |
+2Erdoc48 welshman in canada 6 posters | Author | Message |
welshman in canada Scooter Rider
Number of posts : 18 Age : 69 Location : Brighton Ontario Points : 441 Registration date : 2023-09-03
| Subject: A strange howl Sun Oct 06, 2024 12:25 pm | |
| Before I explain my problem I'll give you a brief rundown about the scoot. I bought it in September of last year and for numerous reasons I didn't get much riding in before the Canadian winter forced me to stop. I felt it was a bit 'wobbly' and didn't seem to go where I thought it should or wanted. I figured I would adapt soon enough. Over the winter I replaced all the fluids and replaced the belt. It only had 8,500 kms on it but I figured a new belt was prudent The other thing I did was replace the tyres which were the originals. I installed Michelin City Grip 2's. The scoot is now much nicer to ride and I've been able to get a bit of mileage on it this summer On to my issue. I'm starting to hear a howl as I'm riding. It starts around 80 km/h and continues up past 100. The noise never changes and doesn't get louder as speed increases. I'm pretty certain it's coming from the front somewhere and last weekend I started taking more notice to see if I could figure it out Firstly,it is almost certainly coming from the front. I then realised the noise comes and goes pending the surface of the pavement. It also comes and goes if I gently sway off centre. This leads me to believe it's front wheel related. The bearings are fine and the tyre runs true with no vibration. It's a bit of a mystery and perhaps it was there last year and I just didn't notice due to me getting used to riding a different type of machine. It has a stock windshield, but I feel it's lower than that. More as if it's down by the floor boards. On a final note I should say I'm hard of hearing and wear two hearing aids. I don't wear them while riding as they get uncomfortable and the noise gets pretty bad. This leads me to believe the noise is worse than I realise given I am capable of hearing it. BTW my partner says she can't hear it. Sorry to ramble on a bit!! Anyone have any thoughts?
Charlie |
Number of posts : 377 Age : 60 Location : Myrtle Beach, SC Points : 1262 Registration date : 2022-05-31
| Subject: Re: A strange howl Sun Oct 06, 2024 2:06 pm | |
| Can’t say with certainty, but if you can hear it from the pavement, maybe it’s the tire or tires (a resonant hum). I recall certain brands of tires on other bikes, like the Honda ST1300 (from the forum) have resulted in a speed related hum. It’s not harmful of course, but to many they changed tires and the hum resolved. I’m not suggesting changing tires if they’re still in good condition, just something you may have to live with til the next tire change, assuming no mechanical issues otherwise. |
| Subject: Re: A strange howl Sun Oct 06, 2024 3:37 pm | |
| - Erdoc48 wrote:
- Can’t say with certainty, but if you can hear it from the pavement, maybe it’s the tire or tires (a resonant hum). I recall certain brands of tires on other bikes, like the Honda ST1300 (from the forum) have resulted in a speed related hum. It’s not harmful of course, but to many they changed tires and the hum resolved. I’m not suggesting changing tires if they’re still in good condition, just something you may have to live with til the next tire change, assuming no mechanical issues otherwise.
The tyres are new and maybe a trait of the City Grip 2's It's installed in the correct rotation and the pressure is as per the manual. |
Number of posts : 359 Age : 71 Location : Bristol, UK Points : 1034 Registration date : 2022-12-23
| Subject: Re: A strange howl Sun Oct 06, 2024 6:13 pm | |
| Sounds to me like a Tupperware howl. You only notice it on a Swing at higher speeds Have you tried temporarily blocking the top front air vent, then try to two bottom ones, then all of them. If it was a bearing issue, the pitch would vary depending on speed Hope this helps. Be safe, be seen! Ooh, just thought, the front fender has a steel, arched brace under the plastic (part no. 2) it's glued to the fender with sticky foam. That makes a constant noise at higher speeds when the glue fails. A good adhesive sealant will cure that, remove fender and bracket and glue back together, then re-assemble. |
| Subject: Re: A strange howl Mon Oct 07, 2024 10:38 am | |
| I'm thinking it must be body work as it never varies in pitch as you would expect of a bearing or tyre. I'll do a bit more investigation with the vents. The front mudguard was removed over the winter when I installed the Hyper Pro springs. Worth a look. Cheers |
| | | Carlos Veiga Scooter Rider
Number of posts : 1 Location : Lisboa - Portugal Points : 926 Registration date : 2022-04-07
| Subject: Re: A strange howl Mon Oct 07, 2024 11:36 am | |
| - welshman in canada wrote:
The tyres are new and maybe a trait of the City Grip 2's It's installed in the correct rotation and the pressure is as per the manual. I also had this "problem" on my SW, but the "howl" came from the rear where a Michelin City Grip was running. I never cared much and it was the same, as it only happened when it turned straight, disappearing, at the slightest inclination, to the right or left. I changed the tyre to a Bridgestone Hoop, just like at the front and that "howl" just disappeared. It may be a characteristic of these tires... |
Number of posts : 1030 Location : Teesdale, UK Points : 4189 Registration date : 2016-05-15
| Subject: Re: A strange howl Mon Oct 07, 2024 12:16 pm | |
| I know you said you usually don't wear your hearing aid on the bike, but if you do is the noise still there and the same? I'm asking this because hearing loss often affects only certain frequencies more than others. The fact you says the howl comes and goes with different road surfaces makes me think it's just a characteristic of the tyre - although I would be keeping an eye on the wheel bearings in case one of them is getting on the way out. |
Number of posts : 562 Age : 65 Location : Ocala, FL Points : 1971 Registration date : 2020-12-26
| Subject: Re: A strange howl Tue Oct 08, 2024 10:44 am | |
| I also occasional hear a howl on my front tire, usually at higher speeds, when I tilted scooter, change directions suddenly (evasive maneuvers ) or on sustained/fast leaning turns I checked the normal stuff (installation/bearings/pressure), nothing. Increasing air pressure to 30-32 psi helped some, I also believed it was the cheaper Shinko tires, maybe related to thread design, but the City Grips are completely different, so |
| | | | A strange howl | |
