Turn signal fuse keeps blowing I_icon_minitimeby JohnyC Today at 5:39 am
Turn signal fuse keeps blowing I_icon_minitimeby JohnyC Yesterday at 10:04 am
Turn signal fuse keeps blowing I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Turn signal fuse keeps blowing I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Turn signal fuse keeps blowing I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Turn signal fuse keeps blowing I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Turn signal fuse keeps blowing I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Turn signal fuse keeps blowing I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Turn signal fuse keeps blowing I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Turn signal fuse keeps blowing I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Kunamika Hopper
Kunamika Hopper
Kunamika Hopper
Number of posts : 47
Registration date : 2020-09-18
Turn signal fuse keeps blowing Empty
PostSubject: Turn signal fuse keeps blowing   Turn signal fuse keeps blowing I_icon_minitimeMon Aug 08, 2022 3:28 pm
Hello all!
About 2 weeks ago, I laid my bike down. Made a trip from Houston to Livingston tx afterwards, and had no issues at all. when I got back to Houston though, my turn signal fuse blew.
replaced the fuse, then it blew again. Took apart the switch, cleaned it, did a continuity test, replaced fuse. blew again.
So, I've been going connection by connection checking for continuity.
I've taken the entire front off of my bike, plus the floorboards, seat, and under seat access panel. it seems that there's no continuity from the connectors which attach from the signal switch to the fuse, but all of those wires are bound up with all the other wires, so I don't see how they could be shorting.
I can't find any pin connectors for the orange and blue wires between the main switch connection and the fuse box to test. Are there any, or do I just have to unbind all of the harnesses, then pull and replace the individual wires?
Apologies if this is too vague, it's my first foray into electrical work (other than replacing fuses, lights, etc.). I'd like to learn how to solve this myself, but is it the sort of thing where you're just better off going to the shop?
Anyway, thanks for any help!
Number of posts : 3314
PostSubject: Re: Turn signal fuse keeps blowing   Turn signal fuse keeps blowing I_icon_minitimeMon Aug 08, 2022 4:00 pm
I would make sure both front and rear bulbs and contacts are corrosion free, first.
Kunamika Hopper
Kunamika Hopper
PostSubject: Re: Turn signal fuse keeps blowing   Turn signal fuse keeps blowing I_icon_minitimeMon Aug 08, 2022 4:13 pm
John, I checked for corrosion, and there is none.
The 9 pin connector for the signal wire going from where the turn signal attaches seems lack continuity, but I may be doing this wrong.
But, just to be on the safe side, do you know if a bad bulb (which still lights and flashes) can blow the fuse? I've found mixed info online.
Number of posts : 1607
PostSubject: Re: Turn signal fuse keeps blowing   Turn signal fuse keeps blowing I_icon_minitimeMon Aug 08, 2022 5:15 pm
Could the relay be playing up?
Kunamika Hopper
Kunamika Hopper
PostSubject: Re: Turn signal fuse keeps blowing   Turn signal fuse keeps blowing I_icon_minitimeMon Aug 08, 2022 7:01 pm
Maybe so. I'll have to look at the wiring diagram again to check location. would it be one of the 2 main relays located underneath the glovebox?
Thanks for the suggestion!
Number of posts : 1384
PostSubject: Re: Turn signal fuse keeps blowing   Turn signal fuse keeps blowing I_icon_minitimeMon Aug 08, 2022 9:03 pm
Pull the fuse one side is power other to circuit to power up signal system. Check for continuity to a frame ground after fuse at least is a start to finding the short.
A bad bulb could be the issue if filaments are shorted. Rare though. Don't over think it DC circuits aren't that hard figure out. Any other lights out left-right Brakes?
Kunamika Hopper
Kunamika Hopper
PostSubject: Re: Turn signal fuse keeps blowing   Turn signal fuse keeps blowing I_icon_minitimeTue Aug 09, 2022 10:32 am
Nope, it's just the signal. it's intermittent and inconsistent though: Doesn't seem to short under any specific circumstances (hard cornering, powering on, braking, etc.).
bikes half naked and I think I found the wire. just have to open up the harness and swap it. will report back on results.
Kunamika Hopper
Kunamika Hopper
PostSubject: Re: Turn signal fuse keeps blowing   Turn signal fuse keeps blowing I_icon_minitimeThu Aug 18, 2022 10:27 am
well, after much head scratching, I've solved the issue.
started opening the wiring harness, then realized it was Pandora's box. decided to retest all connections, and lo and behold- continuity on all points.
yet, the fuse continued to blow. took apart the turn signal switch, and noticed that the washer, which goes underneath the toggle switch itself, had been knocked out of place, and was making contact with the wire ends at random points during motion. reset the washer, and voila, no more blown fuses.
wasted 4 days off chasing ghosts for such an easy fix, but got enough practice removing and replacing Tupperware to feel comfortable stripping the whole bike and putting it all back in less than 2 hours.
Might have to do a wrap or paint project
PostSubject: Re: Turn signal fuse keeps blowing   Turn signal fuse keeps blowing I_icon_minitimeThu Aug 18, 2022 10:39 am
Yay! Thanks for letting us know you’ve found the problem. We all benefit from shared information.
4 Days tracing an electrical problem to find a simple fix? Yeah, that sounds about right.
JamieB
JamieB
Number of posts : 224
PostSubject: Re: Turn signal fuse keeps blowing   Turn signal fuse keeps blowing I_icon_minitimeThu Aug 18, 2022 11:00 am
It’s a job well done then when you fix it yourself.
Doesn’t matter how long it took, you sorted it.👍🏻
MUCHoldERwingguy
Number of posts : 89
Registration date : 2022-01-29
PostSubject: Re: Turn signal fuse keeps blowing   Turn signal fuse keeps blowing I_icon_minitimeThu Aug 18, 2022 12:19 pm
Good job, call it a learning curve moment. Oh yeah had more than a few of those.
Kunamika Hopper
Kunamika Hopper
PostSubject: Re: Turn signal fuse keeps blowing   Turn signal fuse keeps blowing I_icon_minitimeThu Aug 18, 2022 11:46 pm
a cheap lesson in time and money, with minimal injury when I laid the bike down. I've learned a lot about the wiring diagram, and gotten over the plastic barrier to repair, I just wish this wasn't the bike to experiment with.
it's my daily driver, and my dream bike. When this one goes, idk if I'll be able to find another one, so learning on it is tough. but it's back to peak now, so I'm thankful`
» Help fuse keeps blowing
» Blowing fuse
» Air Horn blowing fuse
» Blowing headlight fuse
» Are there any serious problems or issues with the Silver Wing ?
