| Exhaust clamp | |
Yusepe Scooter Rider
Number of posts : 38 Location : Milton Keynes Points : 2569 Registration date : 2017-10-20
![Exhaust clamp Empty](https://2img.net/i/empty.gif) | Subject: Exhaust clamp Mon Apr 10, 2023 12:00 pm | |
| Hi, Anybody knows which clamp replacement should I order for the original exhaust? I found many different sizes, not sure which one is our Silverwing. This is an example, https://www.wemoto.com/parts/picture/ay-y78-37-40 They have many https://www.wemoto.com/parts/search?q=exhaust+clamp&page=2 Thanks |
![Exhaust clamp Empty](https://2img.net/i/empty.gif) | Subject: Re: Exhaust clamp Mon Apr 10, 2023 2:00 pm | |
| Well, the original has two fasteners, although I don't know how important that is.
David Silver Spares has the OEM one in stock but it's not cheap.
Type these part numbers into David Silver's website 'search by part number':
https://www.davidsilverspares.co.uk/parts/by-part-number/
Band/Clamp: 18373-ML7-920 Bolts: 90161-ML7-000
You might as well replace the gasket while you're there: 18391-ML8-000
The OEM band/clamp does have a specific fit with a little locating lug. |
![Exhaust clamp Empty](https://2img.net/i/empty.gif) | Subject: Re: Exhaust clamp Mon Apr 10, 2023 2:28 pm | |
| Thanks for the response.
The page you sent is marked as £24, not cheap for what it is.
The clamp of my bike is original and has only one fastener, it is 2010 version.
Probably I need to understand what 37-40 means in the spec, I don't think the diameter is for being totally close and open, I think those 3 millimetres might be the hose size tolerance?
Cheers. |
![Exhaust clamp Empty](https://2img.net/i/empty.gif) | Subject: Re: Exhaust clamp Mon Apr 10, 2023 4:23 pm | |
| If you can get the part number of the 2010 type and put that into the David Silver website it might be much cheaper. My parts catalogue only goes up to 2004.
JohnyC Touring Scooter Rider
![JohnyC](https://2img.net/u/3413/63/00/33/avatars/6268-1.jpg)
Number of posts : 346 Age : 71 Location : Bristol, UK Points : 979 Registration date : 2022-12-23
![Exhaust clamp Empty](https://2img.net/i/empty.gif) | Subject: Re: Exhaust clamp Mon Apr 10, 2023 7:00 pm | |
| Hi Yusepe.
What the 37-40 means it will clamp any pipe with a diameter 37mm to 40mm. And should be the correct clamp for a Silver Wing OEM muffler to manifold connection. Now you know the size you need, try to find a 2 bolt version.
Hope this helps.
Be safe, be seen! |
steve_h80 Silver Wing Guru
Number of posts : 1021 Location : Teesdale, UK Points : 4140 Registration date : 2016-05-15
![Exhaust clamp Empty](https://2img.net/i/empty.gif) | Subject: Re: Exhaust clamp Tue Apr 11, 2023 1:58 am | |
| Or just use something like a metal hose clamp. That's me planning ahead. I need a new rear tyre and I suspect when the exhaust comes off for wheel removal it will FUBAR the clamp. |
![Exhaust clamp Empty](https://2img.net/i/empty.gif) | Subject: Re: Exhaust clamp Tue Apr 11, 2023 10:37 am | |
| - JohnyC wrote:
- Hi Yusepe.
Hope this helps.
Be safe, be seen! It helps a lot, good point. Now I can find something not original similar or better for the corrosion and not expensive. Cheers. |
![Exhaust clamp Empty](https://2img.net/i/empty.gif) | Subject: Re: Exhaust clamp Tue Apr 11, 2023 10:38 am | |
| - steve_h80 wrote:
- Or just use something like a metal hose clamp.
That's me planning ahead. I need a new rear tyre and I suspect when the exhaust comes off for wheel removal it will FUBAR the clamp. For me hot and W40 did the trick. |
David Watts Scooter Rider
Number of posts : 15 Location : South Wales UK Points : 982 Registration date : 2022-01-21
![Exhaust clamp Empty](https://2img.net/i/empty.gif) | Subject: Re: Exhaust clamp Tue Apr 11, 2023 2:24 pm | |
That's me planning ahead. I need a new rear tyre and I suspect when the exhaust comes off for wheel removal it will FUBAR the clamp. You don't need to take the exhaust off to remove the rear wheel. My rear wheel is in my house waiting for a new tyre and the exhaust is still on the swing LOL. |
![Exhaust clamp Empty](https://2img.net/i/empty.gif) | Subject: Re: Exhaust clamp Tue Apr 11, 2023 2:42 pm | |
| That sounds interesting. I always thought that the muffler had to come off so as free-up the brake calipers by unfastening all the pipes and cables, so as not to distort them.
Do you have a pic? I would hate to think that I've been giving myself extra work.
Is there a certain amount of dexterity involved?
![Exhaust clamp Empty](https://2img.net/i/empty.gif) | Subject: Re: Exhaust clamp Tue Apr 11, 2023 3:15 pm | |
| I'll take a photo tomorrow (it's getting dark here in South Wales). I remove both calipers and they will go up over the exhaust and sit on the floor, there's a flexi pipe on the brake line which allows this. I use a scissor jack under the rear axle, unbolt both shockers and lower the axle until the wheel is on the floor and it can then be removed under the exhaust.
| Exhaust clamp | |
