Hyperpro fork springs I_icon_minitimeby JohnyC Today at 5:39 am
Hyperpro fork springs I_icon_minitimeby JohnyC Yesterday at 10:04 am
Hyperpro fork springs I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Hyperpro fork springs I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Hyperpro fork springs I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Hyperpro fork springs I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Hyperpro fork springs I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Hyperpro fork springs I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Hyperpro fork springs I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Hyperpro fork springs I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
4 posters
MaxB
MaxB
Number of posts : 302
Hyperpro fork springs Empty
PostSubject: Hyperpro fork springs   Hyperpro fork springs I_icon_minitimeSat May 01, 2010 12:18 pm
I installed the springs yesterday. I put about 100 miles on them by the time the rains came.
Impressions:
I love them. On the local streets that are cratered and frost heaved, I no longer bottom out and have a lot less front end clanking and squeeking. Plus my back doesn't hurt (collapsed discs, arthritis).
The steering is much more precise, like a sport tourer, no more wallowing in the corners.
I used the 20w fork oil sent with the springs and it seems perfect for my weight.
The scooter seems to be more level while riding. and when I sit on it with the kickstand down, it doesn't sag to the point of feeling like it will tip over. I don't slide forward on the seat as much.
I am glad I found this tip on the forum. Good product.
Now if it stops raining, I'm out for more riding.
MaxB (hyperpro springs,PCIII, J Costa variator,Cup holder, BIG GRIN, less back pain)
DaveR
Number of posts : 440
PostSubject: Re: Hyperpro fork springs   Hyperpro fork springs I_icon_minitimeWed Aug 18, 2010 6:43 pm
Where can I find the info on replacing front fork seals?
MaxB
MaxB
PostSubject: Re: Hyperpro fork springs   Hyperpro fork springs I_icon_minitimeWed Aug 18, 2010 10:36 pm
I have not replaced the seals on the Swing but here are some good sources. that said, Be sure to have new seals in hand before starting. Some shops may not have them in stock and you don't want to have the scoot down for a long time waiting.
1. take off brake cylinder hang out of the way.
2. remove the front fender and reflectors.
3. Loosen the 2 top bolts on the tree on each side.
4. remove axle and then remove wheel
now you are left with just the 2 forks
5. remove the 2 bolts and slide the fork out.
follow the instructions on this page
http://www.motorcyclistonline.com/howto/replace_fork_seals/index.html
they are pretty good.
Note:
Using an impact wrench on the damping cartridge retaining nut helps a lot.
reassemble the front end.
look up a parts fiche to familiurize (sp) yourself with the parts in the fork. Here is an example:
http://hondaparts-direct.com/fiche_section_detail.asp?section=144693&category=SCOOTERS&make=HONDA&year=2005&fveh=3417
OK that said: I have in the past not disassembled the whole fork. After remvoal from bike.
Remove fork cap and remove spring and drain. colapse the slider into the bottom tube (make it shorter)
1. pop off dust cover
2. remove retaining clip
3. drill or punch a small hole using ice pick on each side of seal and insert a sheet metal screw then use pliers to remove the old seal. (be careful not to scratch the slider)
4.push new seal in place and use long plastic drain pipe to reseat the new seal.
5. put retaining clip back in and put dust boot back on.
6. check oil level in fork
7. reassemble front end on bike.
8. don't forget to retorque all the bolts to proper torque.
Keep the inner fork clean of bugs and grit. for a longer seal life. (I spray wax mine when i clean the front fender.
There may be something I left out, doing this from memory.
Hope this helps
MaxB
Number of posts : 2008
PostSubject: Re: Hyperpro fork springs   Hyperpro fork springs I_icon_minitimeThu Aug 19, 2010 12:47 am
Here is a how-to on adding the hyperpro springs for those who are interested:
http://www.leroybeal.net/motorcycles/silverwing/suspension/suspension.html
Number of posts : 771
PostSubject: Re: Hyperpro fork springs   Hyperpro fork springs I_icon_minitimeSat Aug 17, 2013 11:14 am
Bob will be installing my Hyperpro Springs and changing the fork seals this weekend. I just have to pick up my fork seal kit at my Honda Dealer today. It came in yesterday. He will be using the tips on this forum like we have done with many other mods and maintenance issues on the Swing.
Thanks for all your help.
» Hyperpro Fork Springs
» HyperPro Springs
» Hyperpro Springs in UK
» MPG before and after Dr. Sliders
