| Another 12 Volt Power Install without removing Tupperware | |
| Subject: Another 12 Volt Power Install without removing Tupperware Mon Jun 07, 2010 1:26 pm | |
| Subject: Re: Another 12 Volt Power Install without removing Tupperware Tue Jun 08, 2010 12:28 am | |
| Bigbird, Thanks for the instructions, I'm sure they will help me install one too. I keep saying I'm going to do this but I just never do. How long did it take you do you think? Thanks. |
| Subject: Re: Another 12 Volt Power Install without removing Tupperware Tue Jun 08, 2010 12:46 am | |
| Subject: Re: Another 12 Volt Power Install without removing Tupperware Mon Aug 23, 2010 12:10 am | |
| Subject: Re: Another 12 Volt Power Install without removing Tupperware Mon Aug 23, 2010 8:22 pm | |
| Pictures or the new power plug are now added to my album. |
| Subject: Re: Another 12 Volt Power Install without removing Tupperware Mon Aug 23, 2010 10:23 pm | |
| bigbird,
That looks like a good place for one. I keep meaning to go out and try to put one in but I seem to always get busy. The last time I tried to plan it out was when I tried to change my oil. I couldn't get the drain plug out since it was stripping so I just put the new filter in and filled it up with oil that i drained by removing the filter. I still don't know what I'm going to do about the drain plug.
But I just may put the plug where you put yours. It seems to be pretty weatherproof and it doens't rain out here much at all either. Thanks. |
| Subject: Re: Another 12 Volt Power Install without removing Tupperware Wed Sep 08, 2010 6:55 pm | |
| Subject: Re: Another 12 Volt Power Install without removing Tupperware Wed Sep 08, 2010 7:44 pm | |
| That's very bad luck, bigbird. Glad you found out what the problem was without starting a fire! |
| Subject: Re: Another 12 Volt Power Install without removing Tupperware Wed Sep 08, 2010 9:42 pm | |
| Subject: Re: Another 12 Volt Power Install without removing Tupperware Thu Sep 09, 2010 1:15 am | |
| Bigbird: It takes a special person to admit their mistakes. Even with all your experience and expertise, you got something wrong. I like the way you admitted it, and passed the heads up on to others. That's what makes this forum so good. Kudos to you! |
mikef Scooter Rider
Number of posts : 35 Age : 75 Location : Eugene, Oregon Points : 5273 Registration date : 2010-07-20
| Subject: Re: Another 12 Volt Power Install without removing Tupperware Tue Sep 28, 2010 4:40 pm | |
| I'm glad I checked here. I, too, want to add a 12volt socket. I saw there is a place in the lockable pocket, already there. I took off the front garnish, figuring I could access the backside of the hole, but not even close. I figured more had to come off. That's why I checked here first. Thanks for the help. |
new7man Scooter Rider
Number of posts : 21 Location : Fort Worth, TX Points : 3424 Registration date : 2015-08-05
| Subject: Good mod but a couple of things you might wanna know Mon Nov 16, 2015 3:47 pm | |
| I did this install last week and it worked out very well although there were several things that were left out. You might want to know that using the Add-a-circuit won't allow you to close the fuse box. I'm still looking into the best option to solve this problem. Also, I had to read through the directions several times because they are a bit unclear, for instance it mentions a one inch opening twice and later in the instructions refers to a once inch opening again without saying which one inch opening he's talking about. Can be confusing. But otherwise the installation went better than expected. Thanks |
| Subject: Re: Another 12 Volt Power Install without removing Tupperware Thu Nov 19, 2015 6:55 pm | |
| I found it a lot easier to run a pair of wires directly to the battery through a 15A fuse. Only need to remove the box and fish the wires through. Easier if you remove the left rear panel which is easy. |
