![Dr Pulley HiT Clutch: V-3 vs V-4 Empty](https://2img.net/i/empty.gif) | Subject: Dr Pulley HiT Clutch: V-3 vs V-4 Thu Jul 15, 2010 11:23 am | |
| The most obvious difference between the V-3 clutch and the new V-4 clutch is that the V-4 has 4 clutch shoes (wear pads), while the V-3 clutch has, you guessed it, three clutch shoes.
Functionally the two operate the same in that they are designed to lock up at a certain RPM. The new V-4 clutch has more clutch pad surface area, and given that it has more clutch shoes, push pins and springs it also seems to allow more fine tuning adjustment.
![Dr Pulley HiT Clutch: V-3 vs V-4 Empty](https://2img.net/i/empty.gif) | Subject: Re: Dr Pulley HiT Clutch: V-3 vs V-4 Thu Jul 15, 2010 12:43 pm | |
- The most obvious difference between the V-3 clutch and the new V-4 clutch is that the V-4 has 4 clutch shoes (wear pads), while the V-3 clutch has, you guessed it, three clutch shoes.
So the new HIT ( http://www.buggypartsnw.com/home?page=shop.product_details&flypage=flypage.tpl&product_id=418&category_id=30 ) is available here. |
