| Q: Dr Pulley's HiT Clutch | |
Number of posts : 4415 Age : 81 Location : damn near Philadelphia, PA Points : 10747 Registration date : 2009-06-12
| Subject: Q: Dr Pulley's HiT Clutch Mon Jun 15, 2009 10:32 pm | |
| I'm trying to come to terms with doing Dr Pulley's, very pricey, HiT Clutch upgrade for my '03 S/Wing. I've already installed the 28 gm Dr Pulley variator Sliders, but unlike JeffR, I'm getting poorer mpg's and higher operating rpm's. Impressive upgrate in variator performance & acceleration though. So, my question is: Has anyone here actually installed the HiT Clutch and , if so, whaddya think? Also; has anyone installed the Malossi variator Spring. What results did you notice? Tim '03 Silverwing, Cosmic Jumper Philadelphia |
| | | JeffR Site Admin
Number of posts : 2598 Age : 65 Location : Bay Area, Ca Points : 8671 Registration date : 2008-12-19
| Subject: Re: Q: Dr Pulley's HiT Clutch Mon Jun 15, 2009 11:13 pm | |
| Tim, You are getting worse gas mileage and higher rpm's? That is strange since I have read that others have gotten about the same results as I have. I read that a few people on the www.silverwing.org site was getting lower rpms' too. Can you tell us what your rpm's are before and after if you remember? Maybe they twisted as you put the variator back on. Just a thought though. |
Number of posts : 2453 Location : Georgetown, Tx Points : 8374 Registration date : 2008-12-23
| Subject: Re: Q: Dr Pulley's HiT Clutch Tue Jun 16, 2009 6:15 am | |
- I've already installed the 28 gm Dr Pulley variator Sliders, but unlike JeffR, I'm getting poorer mpg's and higher operating rpm's. Impressive upgrate in variator performance & acceleration though.
Did you use dry lubrication on the sliders?? - Cosmic_Jumper wrote:
- So, my question is: Has anyone here actually installed the HiT Clutch and , if so, whaddya think?
I have the HIT clutch but not installed yet. I have been measuring the custom map on the Power Commander, the next step is installing the sliders and then measuring and then the HIT clutch (have to investigate how to install the clutch). |
| | | RAYJASPER Scooter Rider
Number of posts : 13 Points : 5702 Registration date : 2009-04-30
| Subject: HiT251706 for Silver Wing 600 Sun Jun 28, 2009 9:11 am | |
I have the HIT clutch but not installed yet. I have been measuring the custom map on the Power Commander, the next step is installing the sliders and then measuring and then the HIT clutch (have to investigate how to install the clutch). Hi, does this mean you don't know how to install the HiT clutch? did you ever dismount the original clutch from the driven pulley ? if yes, then you surely can install the HiT clutch easily. |
