Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
3 posters
tankyuong
tankyuong
Number of posts : 475
Do 17" motorcycle tires last longer than SWing tires? Empty
PostSubject: Do 17" motorcycle tires last longer than SWing tires?   Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeThu Jul 29, 2010 10:07 am
I was wondering cause I've heard motorcycle tires only last about 4k. Streetbikes that is
Number of posts : 2008
PostSubject: Re: Do 17" motorcycle tires last longer than SWing tires?   Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeThu Jul 29, 2010 10:17 am
How long a tire lasts depends on the rubber compound and use.
But all other things being equal, a 17 inch tire should, mathematically last longer.
A single linear inch of tire gets wear every time it hits the ground.
So given that a single linear inch on a larger tire will hit the ground fewer times than a smaller one, the smaller one should wear faster.
If you figure out a way to get 17 inch tires on a Silverwing safely, be sure and let the forum know.
Dan
PostSubject: Re: Do 17" motorcycle tires last longer than SWing tires?   Do 17" motorcycle tires last longer than SWing tires? I_icon_minitimeThu Jul 29, 2010 10:45 am
For car they have tire ratings ...
Tire wear rating
Tire handling rating
Tire temperature rating
So even though a tire may be the same size, each tire can wear differently due to tire compound and heat ... the same would be true for motorcycle tires.
There are some people who like "sticky" tires regardless of the low mileage the tire gets.
The size of the tire is still dependent on tire compound and temperature handling characteristics of the tire.
» New SWing no longer clean
» Wet tire spray and motorcycle tires?
» New Tires on my SWing
» New tires for my SWing
» It took longer than expected
