Socket sizes needed for Maintenance I_icon_minitimeby xwelder Today at 5:31 pm
Socket sizes needed for Maintenance I_icon_minitimeby GHM-PM Today at 1:06 pm
Socket sizes needed for Maintenance I_icon_minitimeby sonuvabug Yesterday at 9:17 pm
Socket sizes needed for Maintenance I_icon_minitimeby JohnyC Wed Nov 20, 2024 3:04 pm
Socket sizes needed for Maintenance I_icon_minitimeby john grinsel Mon Nov 18, 2024 12:50 pm
Socket sizes needed for Maintenance I_icon_minitimeby Meldrew Sat Nov 16, 2024 9:37 pm
Socket sizes needed for Maintenance I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 11:05 pm
Socket sizes needed for Maintenance I_icon_minitimeby terryweasely Thu Nov 14, 2024 3:48 am
Socket sizes needed for Maintenance I_icon_minitimeby AldusFran Mon Nov 11, 2024 2:21 pm
Socket sizes needed for Maintenance I_icon_minitimeby landisr Sat Nov 09, 2024 5:46 pm
GaryL
GaryL
GaryL
Number of posts : 237
Registration date : 2010-07-10
Socket sizes needed for Maintenance Empty
PostSubject: Socket sizes needed for Maintenance   Socket sizes needed for Maintenance I_icon_minitimeSun Aug 22, 2010 2:28 am
Still being relatively new to the SWing, I have not had to perform any major maintenance yet... Just an oil change. However, I have read with interest the posts on belt changes, tire changes, etc. and it seems relatively easy to do most of these things (I have moderate mechanical skills).
What I am looking for are the sizes of the metric sockets that are needed for some of the bigger bolts and nuts associated with these repairs. I have some metric tools, but mostly in the smaller sizes. I have gone through the shop manual, and have not found anything stated about the sizes... only the torque values. I'm sure that they assume that one has a full set of tools available. I do have torque wrenches.
In reading the posts, It appears that:
Front axle nut: 22mm
Variator bolt: 17mm
I have not found a size stated fot the rear axle nut.
What about the Torx bolt size for removing the rear swing arm?
Are there any other large fasteners or bolts that I need to be aware of? I want to aquire these tools as opportunity presents so that I will be ready when the time comes to tackle some of these jobs.
Thanks for your help!
Number of posts : 2778
PostSubject: Re: Socket sizes needed for Maintenance   Socket sizes needed for Maintenance I_icon_minitimeSun Aug 22, 2010 4:01 am
Hi GaryL,
The large nut on the rear axle is 27mm.
Hammy
Hammy
Number of posts : 362
PostSubject: Re: Socket sizes needed for Maintenance   Socket sizes needed for Maintenance I_icon_minitimeSun Aug 22, 2010 4:51 am
24mm for oil drain bolt.
Sidewinder Pilot
Sidewinder Pilot
Number of posts : 200
Registration date : 2015-05-22
PostSubject: Re: Socket sizes needed for Maintenance   Socket sizes needed for Maintenance I_icon_minitimeThu Mar 16, 2017 4:06 am
Could someone tell me what size the clutch nut is?
Also, has anyone found a good way to pull the clutch bell without a special Honda tool?
Thanks!
PostSubject: Re: Socket sizes needed for Maintenance   Socket sizes needed for Maintenance I_icon_minitimeThu Mar 16, 2017 11:52 am
The clutch nut is 22 mm and torqued to ~40 ft lbs. it's easy enough to remove by locking up the rear brake --so no need to use a special tool to hold the clutch bell.
Several members have used a long 4-arm puller (Harbor Freight) to remove the clutch bell. Dont forget to remove the "C" ring on the shaft.
Reinstalling the clutch bell is a bit less tedious. A 1 1/2" piece of PVC cut to the appropriate length along with a stack of large washer and the original clutch nut are used to press the clutch back in place. Slip on the PVC, add a few washers, tighten the nut, remove the nut , add more washers...
Sidewinder Pilot
Sidewinder Pilot
PostSubject: Re: Socket sizes needed for Maintenance   Socket sizes needed for Maintenance I_icon_minitimeThu Mar 16, 2017 8:14 pm
Thanks, I was thinking of the puller put was unsure of any issues using one.
Registration date : 2009-07-18
PostSubject: Re: Socket sizes needed for Maintenance   Socket sizes needed for Maintenance I_icon_minitimeSat Mar 18, 2017 4:59 pm
Harbor freight is your friend!
» Roller sizes
» Torx sizes ?
» Why are there two different sizes of tires
» 6 point 24 mm box wrench
» Oil Filter Wrench/Socket
