| Oil Filter Wrench/Socket | |
+6bikerboy jmaslak tinman Cosmic_Jumper bigbird Ken-King 10 posters |
Ken-King Scooter Rider
Number of posts : 7 Location : Elizabeth City NC Points : 3802 Registration date : 2014-07-07
| Subject: Oil Filter Wrench/Socket Tue Sep 02, 2014 11:00 am | |
| I've purchased (now) two. One is a wrench I got from the Honda Dealer and the other is the "socket" type I got from NAPA.
The wrench type I got is just a wee bit to big to fully tighten the filter as well the socket type. I ended up placing a rag over the filter to take up any space between the wrench/socket ant it seems to have worked.
My question is: are there any wrenches/sockets that actually fit the oil filter?
Last edited by Ken-King on Tue Sep 02, 2014 12:40 pm; edited 1 time in total (Reason for editing : Fat Fingered Honda) |
| Subject: Re: Oil Filter Wrench/Socket Tue Sep 02, 2014 11:36 am | |
| - Ken-King wrote:
My question is: are there any wrenches/sockets that actually fit the oil filter? If you're using an OEM Honda oil filter, this is the tool I recommend: http://wingstuff.com/products/2065-oil-filter-wrench?context=service_parts_tools |
| Subject: Re: Oil Filter Wrench/Socket Tue Sep 02, 2014 12:03 pm | |
| - bigbird wrote:
- If you're using an OEM Honda oil filter, this is the tool I recommend:
http://wingstuff.com/products/2065-oil-filter-wrench?context=service_parts_tools Big bird is right, that's a great filter tool. Unfortunately the small end is made for a 17MM drain plug, not the 24MM 'nut' on the drain tappet on our Silverwings. Tim |
| Subject: Re: Oil Filter Wrench/Socket Tue Sep 02, 2014 12:25 pm | |
| I have been using a Rigid adjustable pipe strap .With the xtra long wix filter ,it give the room to slip the strap around the filter and works on all different size filter.One tool for all ,All for one. |
jmaslak Super Scooter Rider
Number of posts : 252 Location : Golden, CO, USA Points : 4810 Registration date : 2012-06-15
| Subject: Re: Oil Filter Wrench/Socket Tue Sep 02, 2014 12:41 pm | |
| I recommend the K&N filter with the hex nut on the end. |
| Subject: Re: Oil Filter Wrench/Socket Tue Sep 02, 2014 12:47 pm | |
| That MAY be the issue. I got the filter from NAPA and the wrench I got is the one (above) recommended. I'll be sure next time to purchase the filter from Honda. Thanks guys. |
| Subject: Re: Oil Filter Wrench/Socket Tue Sep 02, 2014 1:14 pm | |
| - Ken-King wrote:
- That MAY be the issue. I got the filter from NAPA and the wrench I got is the one (above) recommended. I'll be sure next time to purchase the filter from Honda. Thanks guys.
That IS the issue. That wrench I linked to is only for the OEM Honda filter. If you are going with an automotive substitute filter, then those cap type filter tools work fine. |
bikerboy Silver Wing Rider
Number of posts : 405 Age : 81 Location : Leyland England Points : 5371 Registration date : 2011-05-12
| Subject: Oil filter wrench/socket Tue Sep 02, 2014 1:42 pm | |
| Over here in the UK the dealer seemed to 'give' me a socket every time I bought an OEM filter. It wasn't much cheaper without and now all my pals have one ! |
| Subject: Re: Oil Filter Wrench/Socket Tue Sep 02, 2014 2:35 pm | |
| - bikerboy wrote:
- Over here in the UK the dealer seemed to 'give' me a socket every time I bought an OEM filter. It wasn't much cheaper without and now all my pals have one !
You can buy an OEM oil filter two ways; the filter alone or an oil filter "kit", which includes the socket tool. |
petesuz Scooter Rider
Number of posts : 12 Location : Tucson, AZ - USA Points : 998 Registration date : 2022-03-14
| Subject: Re: Oil Filter Wrench/Socket Sun Mar 20, 2022 2:46 pm | |
| OK - well maybe this is primitive - but if it won't come off with my hand I simply poke (bash) a screwdriver through it and twist it off. As putting a new one on has really always been hand tight (but a strong hand tight) on all my other bikes and cars. Torque spec never really entered into it, and never had one fall off. So why buy a wrench? I suppose it's less messy. But I wear vinyl gloves anyway. Call me neanderthal. If I find one in my tool boxes I'd use it I guess, but I wouldn't go out of my way to find one. |
Number of posts : 1607 Age : 63 Location : South East England Points : 4757 Registration date : 2016-10-01
| Subject: Re: Oil Filter Wrench/Socket Sun Mar 20, 2022 4:36 pm | |
| I use one of these; I really only use it to get the old filter off. IMO it works a treat |
| Subject: Re: Oil Filter Wrench/Socket Sun Mar 20, 2022 4:49 pm | |
| Third post today, I really should get out more. But come to think of it I've been out on my push bike today, wearing shorts too. I bought one of those a long time ago, in my experience it doesn't work as well my strap wrench for removing old filters. But it may well be more useful removing the oil filter on my Forza, as it's a lot easier to get at than the one on the Silver Wing. |
| Subject: Re: Oil Filter Wrench/Socket Mon Mar 21, 2022 7:22 am | |
| - Loosemarbles wrote:
- I use one of these;
I really only use it to get the old filter off. IMO it works a treat I have this type also and have no problems. Very cheap and works! This is similar to mine and price is good: https://www.walmart.com/ip/Hyper-Tough-Oil-Filter-A-Cap-Wrench-74-76-mm-Model-4215/55524392 Just make sure to get the correct size for our filters. One nice thing is that the correct one works for both the Wing and the Forza! |
