Garmin 660 tether I_icon_minitimeby xwelder Today at 3:57 am
Garmin 660 tether I_icon_minitimeby sonuvabug Yesterday at 4:19 pm
Garmin 660 tether I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Garmin 660 tether I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Garmin 660 tether I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Garmin 660 tether I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Garmin 660 tether I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Garmin 660 tether I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Garmin 660 tether I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Garmin 660 tether I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Garmin 660 tether
Garmin 660 tether Empty
PostSubject: Garmin 660 tether   Garmin 660 tether I_icon_minitimeTue Sep 07, 2010 12:05 pm
The Garmin Zumo 660 does not come with any tether points.
I purchased my Garmin Zumo 660 two months ago.
I have read that the Zumo 660 has occasionally slipped out of the mount. If you caught the Zumo 660 you were lucky, otherwise it could be permanently damaged.
I temporarily tethered the Zumo with a multi-stranded heavy duty thread tied around the rubber boot for headphones till I found a more permanent solution.
I created a tether with
1) Cable tie base ( http://www.lowes.com/pd_292685-1781-45-1MBUVL_0_?productId=3128405&Ntt=cable+tie&Ntk=i_products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=cable%20tie$y=0$x=0 )
2) Key ring (large enough to lay flat when stored )
3) Small Black Diamond Carabiner ( http://www.rei.com/product/798833 )
I attached the cable tie base to back of the Garmin Zumo 660 non-removal panel above the speaker then attached the key ring to cable tie base.
The carabiner is used to attach/detach the key ring to a cord that is wrapped around the ram mount base.
Now if my Zumo 660 slips out of the base, it will not fall to the ground.
Garmin 660 tether
» Garmin sat nav
» garmin gps ram mount
» Garmin Zumo 660
» Garmin GPS XM Antenna
» Garmin Nuvi GPS Recall
