| Scoot wouldn't start after tip over. | |
+4GaryL hot shoe model28a MaxB 8 posters |
MaxB Touring Scooter Rider
Number of posts : 302 Age : 73 Location : Indiana Points : 5886 Registration date : 2009-10-06
| Subject: Scoot wouldn't start after tip over. Mon Sep 13, 2010 4:47 pm | |
| As posted elswhere. I had a tip over
The scoot would not start when I tried. I fidled with several switches and the two Ododmeter buttons. Finally it started.
Does anyone have an owners manual that tells how to reset after a tip over????
I guessed and got it finally. But I am interested in how to do it without guessing.
MaxB (who can't find his owners manual) |
| Subject: Re: Scoot wouldn't start after tip over. Mon Sep 13, 2010 5:09 pm | |
| If I remember right I believe you have to jest turn it off and back on again. |
hot shoe Scooter Rider
Number of posts : 30 Age : 100 Location : high desert of central Az Points : 5276 Registration date : 2010-07-16
| Subject: Re: Scoot wouldn't start after tip over. Mon Sep 13, 2010 5:17 pm | |
| I'm guessing you may have hit the kill switch somewhere along the procedure and then again in trying to get it started which turned it off again allowing it to start. |
GaryL Super Scooter Rider
Number of posts : 237 Age : 72 Location : Casa Grande, Arizona Points : 5508 Registration date : 2010-07-09
| Subject: Re: Scoot wouldn't start after tip over. Mon Sep 13, 2010 5:30 pm | |
| Did it crank, but not fire, or did it simply not crank at all? Depending on the answer, it could be different things. |
| Subject: Re: Scoot wouldn't start after tip over. Mon Sep 13, 2010 9:12 pm | |
| - MaxB wrote:
- As posted elswhere. I had a tip over
MaxB (who can't find his owners manual) Per owner's manual: Bank Angle Sensor Ignition Cut-off System Your scooter’s banking (lean angle) sensor system is designed to automatically stop the engine and fuel pump if the scooter is overturned. Before restarting the engine, you must turn the ignition switch to the OFF position and then back to ON. The engine will not restart until you perform this procedure. |
jdeereanton Silver Wing Guru
| Subject: Re: Scoot wouldn't start after tip over. Tue Sep 14, 2010 3:36 pm | |
| - model28a wrote:
- If I remember right I believe you have to jest turn it off and back on again.
Turns out you are quite correct - good memory - no jest. |
| Subject: Re: Scoot wouldn't start after tip over. Tue Sep 14, 2010 6:13 pm | |
| Thanks to all , now to find my owners manual. hahahaha
MaxB |
goldwing121 Scooter Rider
Number of posts : 4 Age : 51 Location : pikeville ky Points : 4947 Registration date : 2011-05-15
| Subject: Re: Scoot wouldn't start after tip over. Sun May 15, 2011 7:01 pm | |
| there a tip over swith in the front , you have to unhook battery for a minute or so to reset swith |
