ehaughn Maxi-Scooter Rider
Number of posts : 131 Age : 56 Location : Norcross, GA Points : 5487 Registration date : 2010-06-13
| Subject: Ideas for light installation Tue Oct 26, 2010 10:03 pm | |
| Hi All,
I been tossing around ideas on frontal lighting.
Here is what I came up with so far.
Still not sure if I want to use the Dennis light bar or front fender mount. I am leaning towards the Dennis bar though.
I will definitely be using LEDS, actually the 24 watt dimmer version from advrider
I did purchase the 24 watt non-dimmer, but holy smokes, these are way too bright. Just a single light is blinding. I ended up selling them and will purchase the dimmable version shortly.
Now, for the wiring. Here is what I came up with.
I plan to use the H7 connector (purchase an H7 male, connector and connect to the H4 female on the scooter harness) from the high beam, and connect it to the LED lights. This basically makes the high beam inoperable. This allows me to use my existing handle bar switch for toggling off and on the additional lights. The current high beam is 55 watts and the LEDs', both lights, are 48 watts, so I should not have any issues here.
Any thoughts is greatly appreciated.
Advrider http://www.advrider.com/forums/showthread.php?t=607184
H7 connector http://cgi.ebay.com/ebaymotors/H7-Male-wire-harness-connectors-Plugs-Xenon-HID-D2R-D2S-_W0QQcmdZViewItemQQhashZitem5d28187752QQitemZ400104650578QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Thanks,
Erick |
