| The Perfect Connector for LED Lights Hook-up | |
+5Kenjj50 Jim Cater Cosmic_Jumper edwardwr DennisB 9 posters |
| Subject: The Perfect Connector for LED Lights Hook-up Mon Nov 02, 2009 5:17 pm | |
| Hi All, Rear Light Hook-up cable adapter for installation of extra accessory lights, brake lights, turn signals lights, and trailer lights. Under the rear left cover, toward the tail section, there is a 6 pin disconnect connector for all your scooters rear lights. This new product is installed between the two tail light connector halves and supplies lead wire connections to connect your new lights and light ground wire. This will be a custom item, built to your needs. NO MESSING AROUND with trying to find the wright wire, it's already done for you. Just plug it in and your ready to install your lights. Basic setup: Ground wire (White) and accessory wire (black). $24.00 USD (add $2.00 USD for each additional wire added). For Brake light (Blue) and left (Yellow) and right (Green) turn signal wire leads. Shipping is USPS First Class Mail with tracking number, $3.50 to lower 48 states. Contact me through this forum.
| Subject: Installation pictures Sun Nov 08, 2009 2:13 pm | |
| 1. Remove left rear cover 2. Locate rear lights connector. 3. Separate the two halves of the connetor. 4. Plug-in the new wiring light adaptor cable. 5. Your ready to install your new lights. (Most LED accessory lights, on the market today, draw very little current and require no additional fuses). 6. Test all your scooter lights before you reassemble your scooter. |
edwardwr Scooter Rider
Number of posts : 5 Age : 78 Location : Utica, IL Points : 5673 Registration date : 2009-05-12
| Subject: Want one Mon Nov 09, 2009 12:29 pm | |
| Dennis, Wish ya had this a few months back when I put the Tow_pac kit on the wife's SW <grin>. PM me with order info, winters comming and I'll redo it.. Ed hazmatter@gmail.com |
| Subject: Re: The Perfect Connector for LED Lights Hook-up Mon Nov 09, 2009 1:15 pm | |
| Hi Ed, Sorry about the timing. I was thinking of a good way to do a lead wire hook up for lights for a trailer that didn't damage my stock Honda Silverwing wiring hardness when the adapter cable idea came to me. I just got the correct Honda connector and wire terminal crimers in. Now I'm thinking of adding a LED brake light by Custom Dynamics under my spoiler. That would get alot of attention from the drivers behind me when I brake. |
| Subject: Re: The Perfect Connector for LED Lights Hook-up Mon Jan 18, 2010 11:28 pm | |
| Dennis How long are the pigtail wires on your Perfect Connector adaptor? Tim |
| Subject: Re: The Perfect Connector for LED Lights Hook-up Tue Jan 19, 2010 9:35 am | |
| Hi Tim, Normally 6" but I can make them as long as needed. Most LED lights come with some long leads. If you need longer leads for your project, just let me know. |
Jim Cater Scooter Rider
Number of posts : 53 Age : 64 Location : Atlanta, GA Points : 5383 Registration date : 2010-04-20
| Subject: Re: The Perfect Connector for LED Lights Hook-up Wed Apr 21, 2010 9:32 am | |
| Wow!! Just saved me some cash NOT having light kits installed!! I LOVE DIY!! |
Kenjj50 Super Scooter Rider
Number of posts : 220 Age : 74 Location : Naperville, Illinois Points : 3576 Registration date : 2015-09-28
| Subject: Re: The Perfect Connector for LED Lights Hook-up Mon Dec 07, 2015 2:58 pm | |
| Dennis,
Can I get one of your Perfect Connectors wiring harness? If so, let me know how much and the best method of payment. Thanks.
Kenjj50 |
Bash On! Super Scooter Rider
Number of posts : 252 Location : Dallas, Texas Points : 3646 Registration date : 2015-08-24
| Subject: Re: The Perfect Connector for LED Lights Hook-up Mon Dec 07, 2015 3:16 pm | |
| - Kenjj50 wrote:
- Dennis,
Kenjj50 Sorry, Dennis B is no longer in business or on the forum and hasn't been for years, I believe. I posted the same type of email when I joined a few months ago, only to be given the same bad news. (Notice the date of the post next above yours) I've put emails out to the group looking for leftovers/extras but have had no success so far (though one or two members have promised to search their respective garages!). |
bicyclenut Maxi-Scooter Rider
Number of posts : 141 Age : 56 Location : Chicago Suburbs Points : 3561 Registration date : 2015-09-04
| Subject: Re: The Perfect Connector for LED Lights Hook-up Tue Dec 08, 2015 8:07 pm | |
| Kenjj50,
What are you trying to connect into for? I was thinking of trying to make one of these myself if I can find the connector type if it is readily available as I work in automotive.
Mark |
Number of posts : 341 Location : Surprise, AZ. Points : 5784 Registration date : 2010-04-30
| Subject: Re: The Perfect Connector for LED Lights Hook-up Tue Dec 08, 2015 10:47 pm | |
| Subject: Re: The Perfect Connector for LED Lights Hook-up Sat Jan 02, 2016 10:11 am | |
| Ron/trouble100,
Thanks. I finally ordered several of these to see about adding an additional light and hard wiring my top box lights.
Mark |
| Subject: Re: The Perfect Connector for LED Lights Hook-up Sat Jan 02, 2016 10:36 am | |
| I've got two of these tail light wire harness connectors available if anyone is interested. I needed to make up one for myself and also made a couple extra for other forum members. Unlike the original Perfect Connector, the connectors I've made do follow Honda's original wire color codes and also use OEM-size 20 gauge wire and matching OEM Hitachi plugs.
PM me if interested.
| Subject: Re: The Perfect Connector for LED Lights Hook-up Sat Jan 09, 2016 1:34 pm | |
| Received my Perfect Connector clone from Tim today. Very well made wire harness, will make adding Admore lights a piece of cake. Instructions included as well. Guess we should call this the Cosmic_Jumper Perfect Connector now. Thanks Tim! |
| Subject: Re: The Perfect Connector for LED Lights Hook-up Sun Jan 17, 2016 6:15 pm | |
| Added Admore Lightbar last night using the custom made Perfect Connector from Cosmic_Jumper (Tim), worked perfect, made the installation so much easier. |
J.R. Scooter Rider
Number of posts : 32 Age : 69 Location : Watertown, Minnesota Points : 5597 Registration date : 2009-08-25
| Subject: Re: The Perfect Connector for LED Lights Hook-up Mon Mar 07, 2016 12:01 pm | |
| I received the second connector from Tim. The connector and instructions made my project a breeze. Thanks Tim, J.R. |
