| Getting the Swing on its centre stand | |
+8honda_silver robert jdeereanton tankyuong john grinsel MikeO Waspie Tamjay 12 posters |
Tamjay Scooter Rider
Number of posts : 76 Age : 82 Location : Stamford, Lincolnshire Points : 5362 Registration date : 2010-06-10
| Subject: Getting the Swing on its centre stand Fri Nov 19, 2010 9:14 am | |
| Are there any lady SWing owners out there who find it impossible to put the scoot up on its centre stand?
For the life of me, I cannot do it on my own - I have to enlist the help of a strong chap!!!
There must be a knack that I haven't mastered yet.
Laurie |
| Subject: Re: Getting the Swing on its centre stand Fri Nov 19, 2010 9:47 am | |
| Laurie I'm defo not a lady but do have a weak right shoulder that hampers me at times. I find the wing easier than my 400 Burger to get on the centre stand. My technique is to use my body weight through my right foot which is being used to place the centre stand on the ground and slightly rocking back with my left arm. Probably what your doing but may be down to weight distribution!!! (I'm a 12-1/2 stone geeza!!!) |
| Subject: Re: Getting the Swing on its centre stand Fri Nov 19, 2010 11:02 am | |
| Subject: Re: Getting the Swing on its centre stand Fri Nov 19, 2010 4:18 pm | |
| First learn proper technique or have someone show you.
#1 left hand on bar, right on passenger hand grip----gloves help
#2 no dancing shoes
#3 move bike forward and quickly back, when bike is in motion, step on stand and up she goes, no effort.
Of course you should be on the level, solid ground, pavement.
If you are a little unsteady and fear bike falling----practice pushing bike backwords around in circles just to get feeling. People who work in bike/scooter shops and put bikes out and in for display everyday are good at it.
When I used to run bike schools---I always it seemed, often to end up with macho man and his big mouth, saying no training needed as "he had been doing it for 30 years and laid down his Harley in TN"....not the way to avoid accidents. So to get things under control, I would ask for his key, the ask him to push his bike (hand on bars and grab rail) thru a set of cones......after a couple of cones, they would usually end up on top of bike, with bike on ground. Then getting the cooperation was easy----my comments were if you cannot push your bike around with the key out how without ending up on ground.....how can we trust your skills riding it without some proper training?
I as weakened stroke person have no trouble getting SilverWing up on centerstand, using described technique.
John Grinsel |
tankyuong Silver Wing Rider
| Subject: Re: Getting the Swing on its centre stand Fri Nov 19, 2010 4:55 pm | |
| You can go withe darkside tire and it's real easy
jdeereanton Silver Wing Guru
| Subject: Re: Getting the Swing on its centre stand Fri Nov 19, 2010 5:35 pm | |
| - tankyuong wrote:
- You can go withe darkside tire and it's real easy
I love the conjunction 'withe'. While the car tyre may make some aspects of putting the bike on the centre (nod to the original poster) stand easier, it does not in and of itself make the complete task a simple matter. Although I do understand that using a car tyre (staying with it) on a motorbike does lead to a decrease in colon cancer. And this from Frank Zappa, "...you might not believe this little fella, but it'll cure your asthma too." |
robert Super Scooter Rider
Number of posts : 267 Age : 81 Location : arizona Points : 5458 Registration date : 2010-09-20
| Subject: Re: Getting the Swing on its centre stand Fri Nov 19, 2010 5:50 pm | |
| Hi Tamjay, I'm 67 and don't have the strengh I used to, I roll the rear tire on a small piece of plywood, it raises the scoot just enough for you to get it up on the stand...Ride Safe, Robert in Az. |
| Subject: Re: Getting the Swing on its centre stand Fri Nov 19, 2010 6:50 pm | |
| - robert wrote:
- I roll the rear tire on a small piece of plywood, it raises the scoot just enough for you to get it up on the stand.
Raising the rear tire does make raising the center stand much easier. Which is the same trick that the Darkside tire does, it raises the rear axle by ( 0.82" diameter increase / 2) == 0.41" inches. So you could experiment with different side pieces to determine which height would work best for you. |
| Subject: Re: Getting the Swing on its centre stand Fri Nov 19, 2010 8:14 pm | |
| Another thought: many folks try to lift the bike onto the centerstand, which is difficult to do. I use my right foot to press the center stand to the ground, then lean the bike to make sure both feet of the stand are flat on the ground. Then I step straight down on the centerstand while keeping my right hand on the passenger grip and my left hand on the left handgrip. It really does not take much force to get the bike up onto the stand. I find this easier than trying to roll the bike backwards onto the stand. |
GaryL Super Scooter Rider
Number of posts : 237 Age : 72 Location : Casa Grande, Arizona Points : 5503 Registration date : 2010-07-10
| Subject: Re: Getting the Swing on its centre stand Fri Nov 19, 2010 9:06 pm | |
| I use the same technique as Vito, except that I lift on the passenger grip at the same time that I stand on the centerstand. Works every time for me. Incidently, this is the same technique I used to get my GoldWing on it's center stand as well. |
| Subject: Re: Getting the Swing on its centre stand Fri Nov 19, 2010 10:09 pm | |
| I used to think this was really difficult when watching my father-in-law park his burgman 650; having my own SW, I discovered it takes no effort at all.
1. Stop the bike and pull out the kickstand and do not use the parking brake 2. Step out of the bike and stand on the center stand and let your weight push the bike upwards. 3. Lightly guide it backwards
Number of posts : 2658 Age : 81 Location : Medford, Oregon Points : 8393 Registration date : 2009-07-18
| Subject: Re: Getting the Swing on its centre stand Sat Nov 20, 2010 6:18 am | |
| It's 99% technique and 1% strength to get the SW on the center stand. I've done it with a bare foot once. The real critical thing is to put a bit of pressure on the stand pedal and rock the bike slightly feeling for both stand feet to be on the ground. Once you've got it centered on the stand feet bear down on the pedal and pull up a bit on the passenger grab bar and up she rises. Don't overdo the 'umph' factor or the bike will pop up and slide a bit backwards on the stand. Of course the SW feels light to me since I've got a lot of practice putting my Goldwing on it's center stand. |
| Subject: Re: Getting the Swing on its centre stand Sat Nov 20, 2010 8:49 am | |
| - GaryL wrote:
- I use the same technique as Vito, except that I lift on the passenger grip at the same time that I stand on the centerstand. Works every time for me. Incidently, this is the same technique I used to get my GoldWing on it's center stand as well.
This is the process that I've been trying, but alas, I'm not strong enough But thanks for all your tips guys. The bike has been put to bed for the winter (on its centre stand, but not by me!!), so I'll come back to this topic when she's ready to be woken up. Laurie |
dwOhio Scooter Rider
Number of posts : 21 Age : 72 Location : Mansfield, Ohio Points : 5338 Registration date : 2010-05-06
| Subject: Re: Getting the Swing on its centre stand Sat Nov 20, 2010 2:36 pm | |
| I have never had problems getting the Swing up on it's center stand. I probably will now, reading how so many people do have trouble. |
Peach Scooter Rider
Number of posts : 81 Age : 51 Location : Knoxville, TN Points : 5385 Registration date : 2010-06-08
| Subject: Re: Getting the Swing on its centre stand Mon Nov 22, 2010 11:20 am | |
| I can get it on the stand with some difficulty. I stand on it with BOTH feet until it "catches". I have the worst time getting it off without it going down. That's how I dropped her once and I felt like an idiot. Then I couldn't get her up by myself (wet grass) and had to call my dad for assistance! I felt like I was 17 again, but not in the good way! |
| Subject: Re: Getting the Swing on its centre stand Mon Nov 22, 2010 12:03 pm | |
| I have no problem getting it off the stand. I stand astride the bike and rock if forwards and backwards until it comes off. Make sure you have the side stand down - just in case!!
Laurie |
