Where to install Fuze Block FZ-1 I_icon_minitimeby xwelder Today at 9:06 am
Where to install Fuze Block FZ-1 I_icon_minitimeby GHM-PM Today at 8:06 am
Where to install Fuze Block FZ-1 I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Where to install Fuze Block FZ-1 I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Where to install Fuze Block FZ-1 I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Where to install Fuze Block FZ-1 I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Where to install Fuze Block FZ-1 I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Where to install Fuze Block FZ-1 I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Where to install Fuze Block FZ-1 I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Where to install Fuze Block FZ-1 I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
3 posters
ehaughn
ehaughn
Number of posts : 131
Registration date : 2010-06-13
Where to install Fuze Block FZ-1 Empty
PostSubject: Where to install Fuze Block FZ-1   Where to install Fuze Block FZ-1 I_icon_minitimeSat Jan 01, 2011 2:22 pm
Hi All,
Happy New Year.
I picked up a FuzeBlock FZ-1, http://www.cyclenutz.com/Fuzeblock-Fuse-Block-FZ-1_p_92.html. I am curious if anyone has installed this or something similar. I am trying to determine the best place for this.
I am leaning towards installing it in the left side glove box.
Any thoughts?
Erick
PostSubject: Re: Where to install Fuze Block FZ-1   Where to install Fuze Block FZ-1 I_icon_minitimeSat Jan 01, 2011 5:24 pm
Where ever you mount the FuzeBlock make sure you can easily access to check or change fuses.
I mounted something similar under the right rear quarter panel ( http://silverwing.org/cgi-bin/topic_show.pl?pid=12960 use cut/paste to view) and then another distribution/grounding on the front so I could easily access power in both the rear and the front.
ehaughn
ehaughn
PostSubject: Re: Where to install Fuze Block FZ-1   Where to install Fuze Block FZ-1 I_icon_minitimeSun Jan 09, 2011 11:31 pm
Hi All,
Thought I would provide you an update on my Fuze Block project.
I mounted the Fuze Block inside the nose, just under the windscreen, right behind the dash and gages. I used 2 long double-sided velcro straps.
It fit perfectly, barely enough room.
I took the switched power from the low beam headlight.
I am in the process of hooking up the battery tender and motolights.
I will try to get some pictures tomorrow.
Latery
masscoot
masscoot
Number of posts : 438
PostSubject: Re: Where to install Fuze Block FZ-1   Where to install Fuze Block FZ-1 I_icon_minitimeMon Jan 10, 2011 7:48 am
Hi Erick,
I used the Centech AP-2 and mounted it and the relay behind the left access door in the trunk. It was convenient to the battery. All my aux wires (pos & ground) are "homeruns" from the power block to the device. I did not want to pinch into the harness which could lead to problems down the line from vibration. In the picture you see one of the cheaper wire splices (blue) that caused me quite a lot of grief on a trip. I have since replaced it with a more stable connector. An even better way to get switched power is to buy the connector the DennisB makes, a clean plug-n-play solution. Contact him for details.
Where to install Fuze Block FZ-1 IMG_0075
ehaughn
ehaughn
PostSubject: Re: Where to install Fuze Block FZ-1   Where to install Fuze Block FZ-1 I_icon_minitimeMon Jan 10, 2011 11:40 pm
Hi masscoot,
Very nice job. Clean and everything is labeled.
Have to take some pics of mine. Hope to have the wiring done in a few days.
We got lots of snow here in Atlanta, everything is shudown.
ehaughn
ehaughn
PostSubject: Re: Where to install Fuze Block FZ-1   Where to install Fuze Block FZ-1 I_icon_minitimeThu Jan 13, 2011 11:32 pm
Ok all,
Check out the pics.
(83 Kb) Downloaded 36 times
(77 Kb) Downloaded 33 times
ehaughn
ehaughn
PostSubject: Re: Where to install Fuze Block FZ-1   Where to install Fuze Block FZ-1 I_icon_minitimeThu Jan 13, 2011 11:35 pm
Here are a couple more
(64 Kb) Downloaded 30 times
(56 Kb) Downloaded 25 times
» Problem - with KEEPING the clock set
» Replace Small block
» connector block in the front of the Swing
» New Belt on the block
» GPS?
