Ignition lock I_icon_minitimeby JohnyC Today at 5:39 am
Ignition lock I_icon_minitimeby JohnyC Yesterday at 10:04 am
Ignition lock I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Ignition lock I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Ignition lock I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Ignition lock I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Ignition lock I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Ignition lock I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Ignition lock I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Ignition lock I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Ignition lock
djteske
Winger61
spike
spike
Number of posts : 20
Registration date : 2011-02-12
Ignition lock Empty
PostSubject: Ignition lock   Ignition lock I_icon_minitimeTue Feb 15, 2011 4:15 pm
06 Silverwing, lock worked fine, put some graphite powder in the lock and no it doesn't turn. I had the fork locked also, took 5 minuets to unlock, then I couldn't turn the key to start the sw.
Think the lock is shot? Are they expensive?
Spike
Winger61
Winger61
Number of posts : 452
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeTue Feb 15, 2011 4:35 pm
Spike,
Have a look in Silver Wing topics, 'ignition barrel - may have a problem'. There's about 3 pages of a thread started by Waspie - he had a similar problem, but there are a few suggestions to 'cure' the problem.
djteske
djteske
Number of posts : 16
Registration date : 2012-11-14
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeWed Nov 14, 2012 12:35 pm
Just bought a 2002 SilverWing with one key, which I promptly lost. No, I don't have the key tag with the key code. The manual may have it inside, but it is locked in the storage. The dealer looked up the VIN, but can't tell me the original dealer. So, unless someone has a better idea, I need to remove the ignition switch, and take it to the dealer.
Does anyone know what it takes to remove the ignition switch?
Number of posts : 2392
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeWed Nov 14, 2012 12:43 pm
Spike you don't say if your a Uk/Europe or USA/Canadian rider.
Is your Wing a HISS fitted machine. If so then yes it will be expensive. Honda changed mine under warranty with similar symptoms.
djteske, have you thought about the introduction section at the top of the home page? Might be polite to have a quick visit!
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeWed Nov 14, 2012 3:40 pm
Jeez, give the guy a break, he sounds like he's in a pretty desperate situation.
He just bought it, give him some time before he's a full time participant. I'm sure if someone helps him rather than giving him attitude it's far more likely that he'll become a contributing member.
Besides, if he's buying a scooter in November to ride in Wisconsin, he sounds pretty hardcore.
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeWed Nov 14, 2012 3:44 pm
Thank you for your comments.
Just to keep you in the loop we have been communicating behind the forum to resolve his issue don't be so keen to criticise before knowing all the facts.
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeWed Nov 14, 2012 3:48 pm
That's great, but I have been seeing a pattern.
I didn't read anything about requirements before asking for help at this forum, I just wanted to make sure I know all the rules.
Also thanks for keeping as much of the help as secret as possible so everyone doesn't find out that there is good information and help to be had around here. We definitely don't want good information cluttering up the interesting conversations around here. Keep those "behind the forum" conversations going.
djteske
djteske
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeWed Nov 14, 2012 6:38 pm
So, does anyone have a diagram of the ignition switch, or a detailed instruction on how to access it> I have a basic drawing that makes me think I should just hunt for screws and remove them. Thanks.
Number of posts : 921
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeThu Nov 15, 2012 2:03 pm
Spike, I had a similar problem a while back. Came out one morning and the key went in okay but would not turn. I put the key slightly in and turned the barrel around on the lock. This worked for me and ignition has been okay ever since. Worth a try.
djteske
djteske
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeThu Nov 15, 2012 2:20 pm
OK, I'm pretty new to this SW group. I see a lot of you are in the UK. Just wondering, what side are the handlebars on over there?
tarmacburner2
tarmacburner2
Number of posts : 1099
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeThu Nov 15, 2012 5:19 pm
They are on the front end, bolted to the front forks so you can steer.
Apart from that I couldn't understand your question, I think you need to clarify it.
Cheers,
Ignition lock 510-80
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeThu Nov 15, 2012 6:01 pm
Topside------Except for Waspie. Smile
tinman
Number of posts : 1298
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeThu Nov 15, 2012 6:13 pm
Other then having a back seat pillion driver the handle bars are on the front. :lol!: rolling laughter
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeFri Nov 16, 2012 12:33 pm
djkesje. Every thing much the same except we have a 12volt outlet socket in the left hand pocket, and our headlight is dipped to the left as we ride on the other side of the road. Do you know it is advisable to take out the under seat light bulb to avoid a flat battery? it happened to me! Smile
Atrick
Atrick
Number of posts : 198
Registration date : 2012-09-04
Ignition lock Empty
PostSubject: Re: Ignition lock   Ignition lock I_icon_minitimeFri Nov 16, 2012 1:52 pm
Handlebars are for steering? So that's what they're for - bugger, I thought they were highway pegs so no wonder I keep wobbling.... Shocked
Ignition lock
» Breakaway Throttle Lock
» Leaving key in the lock
» Won't lock
» Parking Brake
» NEP CC-3 throttle lock
