Won't lock I_icon_minitimeby john grinsel Today at 4:14 pm
» Rear wheel valve stem
Won't lock I_icon_minitimeby JohnyC Today at 11:53 am
Won't lock I_icon_minitimeby COMick Yesterday at 6:13 pm
Won't lock I_icon_minitimeby xwelder Yesterday at 12:31 pm
Won't lock I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Won't lock I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Won't lock I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Won't lock I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Won't lock I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Won't lock I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
 Won't lock
redeye
Buickguy
Texas Winger
BlackFly
GaryT
GaryT
Number of posts : 36
Registration date : 2011-04-11
Won't lock Empty
PostSubject: Won't lock   Won't lock I_icon_minitimeSun Jun 26, 2011 6:57 am
For one reason or another , I can't get the steerig to lock. I can push down but the key won't turn to lock. What am I doing wrong ? Mad
BlackFly
BlackFly
Number of posts : 151
Registration date : 2010-11-20
Won't lock Empty
PostSubject: Re: Won't lock   Won't lock I_icon_minitimeSun Jun 26, 2011 7:08 am
Did you moved the handlebar a little bit? The lock can only engage in a specific position nearly the left endstop
GaryT
Won't lock Empty
PostSubject: Re: Won't lock   Won't lock I_icon_minitimeSun Jun 26, 2011 7:45 am
Yes i turned it to the left , then wiggled it back and forth but no luck. I'll try again today.
Texas Winger
Number of posts : 27
Registration date : 2011-04-07
Won't lock Empty
PostSubject: Re: Won't lock   Won't lock I_icon_minitimeSun Jun 26, 2011 8:58 am
Mine locks when turned to the RIGHT
Buickguy
Number of posts : 86
Registration date : 2011-04-10
Won't lock Empty
PostSubject: Re: Won't lock   Won't lock I_icon_minitimeSun Jun 26, 2011 9:36 am
Mine will lock at either end, not quite at the stop.
There is a touch. You have to push the key in, but not too hard and the bars have to be in the right spot.
redeye
Number of posts : 163
Registration date : 2010-10-13
Won't lock Empty
PostSubject: Re: Won't lock   Won't lock I_icon_minitimeSun Jun 26, 2011 9:45 am
I've never been able to lock my Silver Wing, either. My Morphous locks without the slightest problem. Tried all of the tips in the posts after yours, without success.
Number of posts : 1288
Won't lock Empty
PostSubject: Re: Won't lock   Won't lock I_icon_minitimeSun Jun 26, 2011 9:54 am
Like others here, I have been able to lock the steering by moving the handlebars to the left to stop and backing off just a tiny bit. Pushing key in and turning to lock while finding sweet spot of handle bar. Not hard to do, but might take a little practice to learn. I have never tried the turning to right. Gonna try that later today. Good luck Gary
Number of posts : 2392
Won't lock Empty
PostSubject: Re: Won't lock   Won't lock I_icon_minitimeSun Jun 26, 2011 4:10 pm
Mine locks left or right.
Don't actually think about it, I just turn the bars and depress and turn the key to lock the bars.
That said, I don't lock the bars left/right often, if at all. I tend to use the HISS. I often read about thieves breaking the lock when stealing a bike adding to the cost of repair if/when the bike was recovered.
Number of posts : 4218
Won't lock Empty
PostSubject: Re: Won't lock   Won't lock I_icon_minitimeSun Jun 26, 2011 4:50 pm
So the steering doesn't lock. you've fiddled about, maybe squirted WD-40 into the lock and it still doesn't work. It's not the end of the world, just find another way to secure the scoot. You can always have another go in a few days, and it might work then.
cjuzda
Number of posts : 133
Registration date : 2011-05-16
Won't lock Empty
PostSubject: Re: Won't lock   Won't lock I_icon_minitimeSun Jun 26, 2011 5:49 pm
I'm sure you've tried this but with the bars straight or a bit to the left. Push the key in, hold it in and and apply constant pressure as you slowly turn the bars to the left. That way when you get the bars to the right spot, the key should just turn into the lock position. If this doesn't work it's likely broken in some way. You could also try and take all the weight off the front wheel which should allow you to experiment with the positioning of the bars more easily
Won't lock
» wont stay running
» SW wont Start
» Clutch removal of 22mm bolt
» New Silverwing, Wont Start, Help!!
» Silverwing wont start
