SW wont Start I_icon_minitimeby zrx212 Yesterday at 4:40 pm
SW wont Start I_icon_minitimeby Meldrew Yesterday at 4:37 pm
SW wont Start I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
SW wont Start I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
SW wont Start I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
SW wont Start I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
SW wont Start I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
SW wont Start I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
SW wont Start I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
SW wont Start I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
 SW wont Start
dunwoodysw
Number of posts : 2
Registration date : 2015-05-20
SW wont Start Empty
PostSubject: SW wont Start   SW wont Start I_icon_minitimeSat Jun 27, 2015 1:47 am
Dear Silverwing Riders,
I live in Atlanta, GA bought a 2007 SW ABS has 1783 MI. 15 months ago never been on it because i was traveling. This week i siphoned the gas out and put new gas, & battery. I tried to run it but got no luck. The scooter crancks but does not start the multifunction display flickers. The fuse on the left side 30 AMP is good. I am not sure if the issue is an electrical problem or fuel delivery. II forgot that the SW was dropped, any suggestion would be appreciated.
Ride Safely.
yammer
yammer
Number of posts : 100
Registration date : 2013-05-04
SW wont Start Empty
PostSubject: Re: SW wont Start   SW wont Start I_icon_minitimeSat Jun 27, 2015 10:46 am
The flickering of the display suggests an electrical issue, quite possible a connection problem. I would start with checking all connections for loose or corroded contacts and since you replaced the battery, it may be where the problem is.
SW wont Start Empty
PostSubject: Re: SW wont Start   SW wont Start I_icon_minitimeSat Jun 27, 2015 10:57 am
Check your battery voltage. You should have at least 12.5 volts at the terminals. If the battery voltage drops below 12 volts while it is cranking then there won't be enough voltage to crank the starter AND power the ECU and Fuel Injection, etc.
+1 on what Yammer said. Check your battery-to-ground connection.
Edit 1 time
dunwoodysw
Number of posts : 2
SW wont Start Empty
PostSubject: Re: SW wont Start   SW wont Start I_icon_minitimeSat Jun 27, 2015 3:25 pm
Thanks guys for your quick response, The cables are well connected and tight. I will check the battery voltage and see what is going to happen.
SW wont Start Empty
PostSubject: Re: SW wont Start   SW wont Start I_icon_minitimeMon Jun 29, 2015 12:10 am
You sure the kill switch is in the 'operate' position?
Number of posts : 1999
SW wont Start Empty
PostSubject: Re: SW wont Start   SW wont Start I_icon_minitimeMon Jun 29, 2015 12:41 am
That kill switch thing happened to me one time and I thought, "What The Heck!" But once I figured it out I check it now when it won't start. Sometimes I bump it without knowing when I get off or move it around in the garage. It doesn't even have to go all the way to kill to kill. I've had the switch sit half way a couple of times.
SW wont Start Empty
PostSubject: Re: SW wont Start   SW wont Start I_icon_minitimeMon Jun 29, 2015 8:33 pm
I prefer bikes that allow the engine to be cranked with the kill switch set to stop the engine. It's real handy when you need to spin an engine over to do compression checks or other maintenance. It is more likely with this type to cause embarrassment when you're stuck at an intersection with a green light and cars honking at you. Don't ask. Well actually it was my glove that caught on the switch.
SW wont Start
» Swing wont start
» Silverwing wont start
» Engine wont start
» New Silverwing, Wont Start, Help!!
» Front axle wont come out.
