| New Silverwing, Wont Start, Help!! | |
+8Mech 1 twa steve_h80 Cosmic_Jumper oldwingguy GHM-PM Modernman1953 DennisB four50ncalif 12 posters |
four50ncalif Scooter Rider
Number of posts : 5 Location : San Jose CA Points : 2979 Registration date : 2016-09-01
| Subject: New Silverwing, Wont Start, Help!! Thu Sep 01, 2016 5:52 pm | |
| Hello fellow swing owners!!
I have just recently purchased a dead swing on Clist, The bike has been sitting since 2011. It cranks over good, but seems like there is no spark and no fuel (fuel injectors not firing). The fuel injection light stays on, no blinking
The things I have done to it so far:
New battery checked all fuses put fresh gas in cleaned injectors new spark plugs new ignition coil sprayed all electrical plugs with cleaner checked relays bench tested fuel pump (good) bench tested fuel injectors (good)
Other Symtoms:
-There seems to be no fuel in the return line to the gas tank from the fuel rail
-I had to hot wire the fuel pump to a switched 12v wire to the fuel pump relay, I looked at the wiring diagram online, and the fuel pump is wired right to the relay (I know the relay is good what would cause there to be no power to the fuel pump?) I have yet to chase the wire
I am baffled, any help appreciated! |
Number of posts : 2778 Age : 74 Location : NE Oklahoma Points : 9063 Registration date : 2008-12-28
| Subject: Re: New Silverwing, Wont Start, Help!! Thu Sep 01, 2016 6:09 pm | |
| Hello, When these scooters sit for a time the FI pressure regulator gives out.
Item # 13
http://www.hondapartshouse.com/oemparts/a/hon/506c791df870023420a3c07d/throttle-body |
Number of posts : 379 Location : Yuma, AZ Points : 3487 Registration date : 2016-06-01
| Subject: Re: New Silverwing, Wont Start, Help!! Fri Sep 02, 2016 10:37 pm | |
| Gas tanks gum up with old gas. I was just talking with a silverwing owner who had their gas tank replaced due to bad gas and the bike sitting.
| Subject: Re: New Silverwing, Wont Start, Help!! Fri Sep 02, 2016 11:33 pm | |
| OK Introduction Posted, Also I had the fuel pump out (thought it was bad) And at that time I drained the old gas out and now has new gas in it.
I just ordered a service manual for it so I may not try to do too much more to it until it arrives (would rather make some more educated guesses, than to just fiddle blindly)
My theory as of now is that the cam pulsar is not working properly and that the computer does not know that it is turning over and then not sending the signal to the injectors and the spark plugs.
I may need a fuel pressure regulator also |
Number of posts : 2615 Age : 72 Location : Bullhead City, AZ Points : 7470 Registration date : 2012-05-17
| Subject: Re: New Silverwing, Wont Start, Help!! Fri Sep 02, 2016 11:46 pm | |
| Good luck with your troubleshooting! Wish I had a miracle cure for you, but afraid this is strictly detective work now!!! |
| Subject: Running!! Fri Oct 07, 2016 2:02 am | |
| Hey guys I know it has been a while since my first post but I wanted to give an update on my Swing. So as advised I went ahead and bought a service manual. This was a critical part in helping me figure this thing out. If you look at the wiring diagram all the issues that I was having (no spark, no fuel pump, no injectors) all are circuits that go through the ECM. So that was the first hint that the ECM might be the problem. Just to confirm my suspicion I had my dads friend (career mechanic) help my to go through the steps listed in the service manual to test the fuel pump circut, including the fuses, relays, bank angle sensor etc. We figured that the ECM was the culprit, so I went and ordered a used one on Ebay (new are $500). Just yesterday it showed up, plugged it in and it started right up!! So today I put it all back together and changed the engine oil and filter and the trans oil, It is going to need a new rear tire, but my first ride is coming soon! I am beyond thrilled to have this thing running! Also learning a bunch about fuel injection and electronic testing ect is not too bad either. |
| Subject: Re: New Silverwing, Wont Start, Help!! Fri Oct 07, 2016 3:00 am | |
| Congrats on getting it running. |
| Subject: Re: New Silverwing, Wont Start, Help!! Fri Oct 07, 2016 8:15 am | |
| Excellent news that you got it running! And thanks for the update, it is very helpful to the group so if another has the problem... |
Number of posts : 1936 Location : Hocking Hills U.S.A. Points : 5327 Registration date : 2016-01-29
| Subject: Re: New Silverwing, Wont Start, Help!! Fri Oct 07, 2016 8:35 am | |
| Good job troubleshooting, and welcome from o-HI-o |
Number of posts : 4416 Age : 81 Location : damn near Philadelphia, PA Points : 10713 Registration date : 2009-06-12
| Subject: Re: New Silverwing, Wont Start, Help!! Fri Oct 07, 2016 8:39 am | |
| Congratulations. Even using the FSM to diagnose replacing the ECM is a tough bullet to bite. I'm glad it worked out. Did the PO indicate that there was a problem the last time it was used and that's why it was parked?
| Subject: Re: New Silverwing, Wont Start, Help!! Fri Oct 07, 2016 9:52 am | |
| This is one for the oddity book. I can't recall ever hearing of a ECM failure on this scooter...Ever! Happy to hear you got it back on the road. |
steve_h80 Silver Wing Guru
Number of posts : 1030 Location : Teesdale, UK Points : 4189 Registration date : 2016-05-15
| Subject: Re: New Silverwing, Wont Start, Help!! Fri Oct 07, 2016 3:27 pm | |
| Congrats on the detective work. And I guess that explains why its been dormant since 2011 :-) |
Number of posts : 1384 Location : Allentown PA. Points : 4694 Registration date : 2016-01-02
| Subject: Re: New Silverwing, Wont Start, Help!! Fri Oct 07, 2016 5:34 pm | |
| Last owner must have done something wrong. Tried to jump start it, cables reversed. POS. NEG. switched or too many AMPS from a running car. Only takes a half second to FRY something. Happy its running. |
| Subject: Re: New Silverwing, Wont Start, Help!! Fri Oct 07, 2016 6:02 pm | |
| Yea the PO I bought it from just said it cranks but won't start, I was surprised as well that it was the ECM , I thought it would just be clogged fuel injectors from sitting. It may have been beneficial on accident to clean the injectors and to also put new o-rings on them. While I had the fuel pump out I drained all the old gas as well, so all the effort was not spent in vain. It would have been nice to know that all I really needed to do was plug in a new computer, but theres no way no know that beforehand. |
Number of posts : 2658 Age : 81 Location : Medford, Oregon Points : 8363 Registration date : 2009-07-17
| Subject: Re: New Silverwing, Wont Start, Help!! Sat Oct 08, 2016 1:31 am | |
| Incorrect jump starting can certainly fry an ECM, especially if the donor battery is in a running vehicle. You can get some impressive voltage spikes that way even if one connects the battery correctly. It's a problem of the donor vehicle's voltage regulator. When that sees voltage fluctuations that are often seen connecting the two batteries it can confuse the running vehicles voltage regulator and cause nasty pulses to hit the bike's system. |
Reg Maxi-Scooter Rider
Number of posts : 101 Age : 71 Location : Brockville Ont. Canada Points : 3107 Registration date : 2016-08-07
| Subject: Re: New Silverwing, Wont Start, Help!! Sat Oct 08, 2016 3:07 pm | |
| Seems to be the way of electronics. On last use it worked fine. Next time using it. Doesn't work.
Good for you getting it fixed. Hate to take that problem to a dealer. They could have made a fortune looking for it.
Number of posts : 1997 Age : 78 Location : Princeton, MN Points : 6038 Registration date : 2014-02-13
| Subject: Re: New Silverwing, Wont Start, Help!! Sat Oct 08, 2016 4:55 pm | |
| When I bought my sister's SWing 4 seasons ago it had sat for over two years. I trailered it home from FL to MN and put it in the garage. The battery was totally shot so I ordered a new one from Ebay for $25. I figured if it lasted one season at least I could ride it and worry about a new better battery over the winter. While it was sitting in the garage I hooked up jumper cables from my pickup to the SWing just to check the lights etc. without the pickup running. The SWing probably thought, "Man have I got a huge battery". I figured what the heck and hit the starter. It turned over about 3 times and popped right off and ran like a kitten. I let it run for a while being happy that it started and just to listen to it. It had 1/2 a tank of two year old gas in it but that didn't seem to matter. The battery came and I put it in to go on my first ride. I dumped about 1/3 of a can of SeaFoam in it and went to the gas station and topped it off. I rode around town for a while to get the feel of it then took it on the highway. It handled great! I was happy! I went home and changed the oil, filter and air filter. I took the wheels off and had the dealer put new tires on and balance them. I put the tires back on the SWing and also put a bottle of RideOn sealer/balancer in both tires and haven't had a problem since. The SWing is a great little bike! |
HORNBLOWER Maxi-Scooter Rider
Number of posts : 171 Age : 69 Location : Birmingham UK Points : 4234 Registration date : 2013-10-08
| Subject: Re: New Silverwing, Wont Start, Help!! Sun Oct 09, 2016 4:21 am | |
| Hi you guys from acros the pond constantly talk about seafoam. What is it and what does it actually do. Ive ever seen or heard of it over here, are we missing out on something? |
| Subject: Re: New Silverwing, Wont Start, Help!! Sun Oct 09, 2016 7:59 am | |
| Seafoam is an additive that you can either put in the gas tank or oil. I don't use it in the oil but use it in all my gas engines. It cleans engine deposits and keeps our Ethanol gas from going bad. I use it in my 5 gallon gas can for my lawn mowers and snow blower. Sometimes it will take me two or three years to use up that 5 gallons and I've never had the gas go bad. My small engine equipment starts and runs great using Seafoam. Usually my snow blower will start on the first or second pull after sitting in my shed all summer. And come spring my lawn equipment does the same. I've used it for years without any problems. About every fourth or fifth tank on my SWing I add a few ounces before I go and fill up. |
| Subject: Re: New Silverwing, Wont Start, Help!! Sun Oct 09, 2016 8:38 am | |
| Here's the Seafoam companies product information site.
http://seafoamsales.com/ |
| Subject: Re: New Silverwing, Wont Start, Help!! Sun Oct 09, 2016 6:08 pm | |
| Sea Foam is another miracle in a can. But it actually does seem to do some good. I started using it in my 1980 Goldwing which wasn't happy with alcohol in it's gasoline. A good does every other tank made that bike happier. I continued using it in my '93, '02 and '07 Goldwings. From that time on all my vehicles get a shot now and then. I can often see a difference in a smoother idle soon after I put a dose in the fuel. I haven't noticed a big difference with my cars or trucks but in the smaller engines it seems to help. My BMW C650 definitely wants some in it's fuel. When I run a tank of ethonol free gasoline in it the Sea Foam doesn't seem to make much difference. In Oregon it's a pain to use pure gasoline because it costs about half a buck more and there aren't all that many stations around here that sell it. |
| Subject: Re: New Silverwing, Wont Start, Help!! Mon Oct 10, 2016 2:03 am | |
| Thanks guys for the information. I wonder if the deep creep might be of use to me here. I repair a lot of brass musical instruments with stuck piston valves where the oil has turned hard like a sticky glue. It might help. |
