| Does Sea Foam Affect Mileage? | |
+10joncallihan "Hi Yo" jdeereanton Pendragon RickV thomphoto exavid DaveR bigbird tankyuong 14 posters |
tankyuong Silver Wing Rider
![tankyuong](https://2img.net/u/3413/63/00/33/avatars/325-39.jpg)
Number of posts : 475 Age : 49 Location : Missouri Points : 6223 Registration date : 2009-07-12
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Does Sea Foam Affect Mileage? Thu Mar 03, 2011 2:29 pm | |
| Had a tank treated with sea foam and maybe winter gas and terrible 38 mpg, tank is slowly diluted with new gas and mpg slowly creeping up |
Number of posts : 2387 Location : Winnipeg Points : 7832 Registration date : 2010-05-02
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Thu Mar 03, 2011 9:47 pm | |
| - tankyuong wrote:
- Had a tank treated with sea foam and maybe winter gas and terrible 38 mpg, tank is slowly diluted with new gas and mpg slowly creeping up
Good to know. |
DaveR Silver Wing Rider
Number of posts : 440 Age : 88 Location : Scottsbluff, Nebraska U.S.A Points : 6132 Registration date : 2009-02-19
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Thu Mar 03, 2011 10:26 pm | |
| I don't know if it does or not, I know I don't like the Ethanol gas that is being forced upon us. They do make an additive to help it digest but is pretty costly. Has anyone experienced the rust situation using Ethanol? Since I have had to use this "poor fuel" my mileage has gone down to about 40 to 42 mpg. I don't like it. Does anyone have any suggestions? Old Dave |
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Mar 04, 2011 12:53 am | |
| I give my car, truck, and both bikes a dose of Sea Foam about twice a year. It does seem to smooth the idle of my truck and car and it definitely helped the throttle response of my old 1500 GW. The stuff does clean out a good bit of gunk from carbs and fuel injectors. I've never used it as a fuel stabilizer, I do know there have been reports on the GW forums of poor starting and low mileage when Stabil has been used as a protectant for storage, could be the same with Sea Foam. If the stuff protects the tank and keeps the fuel system clean during storage a bit of poor mileage once brought out of storage might be worth the bother. |
thomphoto Maxi-Scooter Rider
![thomphoto](https://2img.net/u/3413/63/00/33/avatars/272-69.jpg)
Number of posts : 188 Age : 87 Location : Owensboro, Kentucky Points : 5803 Registration date : 2009-06-11
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Mar 04, 2011 8:01 am | |
| Interesting, since I just started riding a week or so ago after storing over the winter with Sea Foam, and I have noticed that the gas guage is dropping much faster than normal. |
RickV Maxi-Scooter Rider
![RickV](https://2img.net/u/3413/63/00/33/avatars/987-78.jpg)
Number of posts : 100 Age : 79 Location : MN Points : 5147 Registration date : 2010-11-28
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Mar 04, 2011 11:32 am | |
| Everything I store with fuel has Seafoam added - scooters and cars - and I am fortunate to have non-ethanol premium fuel available here in MN. Haven't noticed any fuel mileage decreases as such due to Seafoam but operating in cooler temps does seem to reduce mileage somewhat. The Seafoam can states that it: "Stabliizes and conditions fuels. Use for engine storage". It also says: "Use in gas, ethanol, diesel or biodiesel". I'm not sure of any stabilizer effectiveness when used with ethanol - check out the February 2011 issue of Popular Mechanics for issues regarding ethanol and storage. I'm really glad that I have option of non-ethanol fuel for use in my scoots. Rick V |
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Mar 04, 2011 12:05 pm | |
Pendragon Scooter Rider
Number of posts : 38 Age : 84 Location : Abbotsford, B.C. Canada Points : 5029 Registration date : 2011-01-12
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Mar 04, 2011 1:46 pm | |
| Yo, Big Bird, I agree with you on all points, but if I might add... I use a product called Marvel Mystery Oil, both as a cleaner-outer and as a fuel stabiliser. I NEVER use Stabil because of all of the afore-mentioned problems. You can even add it to your crankcase just before an oil change (about 50 miles) it does a great job of freeing up sticky starter clutches. BTW, if you look in your owner's manual you might notice that it says up to 10% ethanol is OK, but where I am, mid-grade fuel only contains 5%.
Pendragon
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Mar 04, 2011 2:04 pm | |
| - Pendragon wrote:
- Yo, Big Bird, I agree with you on all points, but if I might add... I use a product called Marvel Mystery Oil, both as a cleaner-outer and as a fuel stabiliser. I NEVER use Stabil because of all of the afore-mentioned problems.
Pendragon
Ahh, good old MMO. Some people swear by it. I've never used it. The only additive I like to put in my gasoline is several ounces of NOTHING. I find that this excellent product, NOTHING, alleviates any symptoms of poor running, poor mileage, and it even improves the vehicle's NVH characteristics. Best of all is the price of NOTHING. I'm not trying to be foolish here, just suggesting that the ultimate fuel for any internal combustion engine is fresh gasoline. If the gasoline isn't fresh, replace it ASAP. |
jdeereanton Silver Wing Guru
![jdeereanton](https://2img.net/u/3413/63/00/33/avatars/23-59.jpg)
Number of posts : 1995 Age : 77 Location : Huntsville, AL Points : 7807 Registration date : 2008-12-24
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Mar 04, 2011 2:34 pm | |
| Is NOTHING available in the states? I was at Wal*Mart earlier and didn't find NOTHING. Would it be in the automotive section? |
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Mar 04, 2011 2:39 pm | |
| I put NOTHING in my tank, and my scooter wouldn't go anywhere. |
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Mar 04, 2011 3:22 pm | |
| Dugglebogey, you need to read the instructions on the package. NOTHING cannot be used by itself. It must be mixed with freshly distilled gasoline in the ratio of gas:nothing = x:1, where x is any volume of fresh gas. Silly you! |
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Mar 04, 2011 3:33 pm | |
| That was soooo enlightening, B.B. :-)
Pendragon |
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Mar 04, 2011 4:46 pm | |
| Dang, I didn't know there was math involved. Now I don't need NOTHING. |
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Sat Mar 05, 2011 1:26 pm | |
| The instructions on my NOTHING say nothing about having to add something to NOTHING. Maybe I need to get some SOMETHING and read those instructions.
My head hurts |
![Does Sea Foam Affect Mileage? 510-80](https://2img.net/u/3413/63/00/33/avatars/510-80.jpg)
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8483 Registration date : 2010-02-17
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Sat Mar 05, 2011 4:24 pm | |
| NOTHING's on sale at Wally World and worth every penny. May be higher in Canada. |
joncallihan Silver Wing Guru
Number of posts : 1025 Age : 86 Location : Lafayette, Colorado, USA Points : 6857 Registration date : 2009-02-16
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Sat Mar 05, 2011 4:27 pm | |
| That's the only thing worth every penny at Wally World. |
![MikeO](https://2img.net/u/3413/63/00/33/avatars/308-62.jpg)
Number of posts : 3819 Age : 75 Location : Seaham, Co Durham, UK Points : 9613 Registration date : 2009-06-29
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Sat Mar 05, 2011 4:30 pm | |
| Adding a bit of culture: https://www.youtube.com/watch?v=3-GPNTCoMWE&feature=related |
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Sat Mar 05, 2011 4:44 pm | |
| Nothing is still Nothing. :flower: |
lndlyb4 Scooter Rider
Number of posts : 32 Points : 4684 Registration date : 2011-12-18
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Apr 06, 2012 2:12 pm | |
| More culture expanding on NOTHING. It's a gas, man!
https://www.youtube.com/watch?v=G_DV54ddNHE&feature=related |
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Fri Apr 06, 2012 10:37 pm | |
| FYI Sea Foam is on sale at NAPA Auto for $6.48. I think it's good for the month of April, but you should check. |
KurtPerthWA Silver Wing Guru
![KurtPerthWA](https://2img.net/i/fa/i/avatars/gallery/Science-fiction_h/sf_h_26.jpg)
Number of posts : 1710 Age : 75 Location : Belmont, Perth WA Points : 8082 Registration date : 2009-01-19
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Sat Apr 07, 2012 5:56 am | |
| Hi Yo, that was only on special last Sunday morning. Check the date on the adv. |
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Sat Apr 07, 2012 5:30 pm | |
| Sorry Kurt, I heard it on the radio. Got to get my hearing checked, Didn't hear the fine print. |
AAAA Silver Wing Rider
Number of posts : 442 Points : 5575 Registration date : 2010-11-14
![Does Sea Foam Affect Mileage? Empty](https://2img.net/i/empty.gif) | Subject: Re: Does Sea Foam Affect Mileage? Sun Apr 08, 2012 11:30 am | |
| I use it, and it does help the mileage in my truck. 158k and counting. I dont think i would use it in my oil however, unless i was doing a oil change very soon.
As For Ethanol. You CAN DE-alchohol your fuel, and you will get better mileage, its a simple process. A friend of mine takes the ethanol out of his fuel in 10 gallon batches, the difference is amazing. |
