cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeby balconio Yesterday at 7:24 pm
cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeby zrx212 Sat Nov 16, 2024 4:40 pm
cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
winged warrior
winged warrior
winged warrior
Number of posts : 51
cleaning element (11356-mct-000) (aKA a piece of foam) Empty
PostSubject: cleaning element (11356-mct-000) (aKA a piece of foam)   cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeSat Dec 19, 2020 8:42 pm
Dear Silverwing Bretheren, A Merry Christmas to you all...
I cleaned out my air filter (the foam one from inside of drive pully cover), the manual doesn't say to add foam filter oil, so should I just clean it, dry it and put it back? I know this sounds really stupid, but similar filters use oil - does the silverwing element not have oil in foam before reinstalling?
( Winged Warrior) changing belt in Toronto (:
Number of posts : 1384
PostSubject: Re: cleaning element (11356-mct-000) (aKA a piece of foam)   cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeSat Dec 19, 2020 9:38 pm
No oil needed just clean it it's just there to stop any large particles from getting into belt case. No oil in belt area keep it dry. Fins on front pulley push air around in there to cool belt.
Merry Christmas.
winged warrior
winged warrior
PostSubject: Re: cleaning element (11356-mct-000) (aKA a piece of foam)   cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeSat Dec 19, 2020 9:43 pm
Thank you so much Mech 1 twa, I will go to sleep tonight knowing I don't have to take the bus to Canadian Tire and buy another product! Cheers
Number of posts : 2621
PostSubject: Re: cleaning element (11356-mct-000) (aKA a piece of foam)   cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeSun Dec 20, 2020 9:29 pm
Does anyone clean this prior to belt replacement? I cleaned mine at about 14K when I changed belt and it wasn't bad.  Just curious if there is a reason to clean it more often?
Number of posts : 1935
PostSubject: Re: cleaning element (11356-mct-000) (aKA a piece of foam)   cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeSun Dec 20, 2020 10:01 pm
Time is worse than miles on the foam, mine had right at 8K for miles but almost 10 years, it was falling apart.
Number of posts : 1606
PostSubject: Re: cleaning element (11356-mct-000) (aKA a piece of foam)   cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeWed Dec 23, 2020 12:52 pm
I give mine a clean whenever I take the drive cover off. Doesn't hurt cat
PeteP
Number of posts : 79
Registration date : 2020-08-31
PostSubject: Re: cleaning element (11356-mct-000) (aKA a piece of foam)   cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeThu Dec 24, 2020 1:23 pm
After replacing my drive belt I just blew air through mine to clean it. It was still in good shape but I also bought some thin air filter material on eBay to cut a replacement when it’s needed.
PostSubject: Re: cleaning element (11356-mct-000) (aKA a piece of foam)   cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeThu Dec 24, 2020 3:14 pm
If there is a fabric shop in an area you frequent check with them, my wife favorite shop carries open cell foam and foam suitable for seat work.
PostSubject: Re: cleaning element (11356-mct-000) (aKA a piece of foam)   cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeWed Jun 14, 2023 1:58 pm
Just did a good clean-up of the whole drive and driven assembly. Clutch shoes were glazed so I cleaned them up. Everything else was fine and not much dust or grime. However, the foam element was absolutely filthy. I cleaned it in some warm soapy water and the water was black. The foam element is a bit tatty but I put it back in and ordered a new one. I'm not fan of adding some oil to the element.
It really gets mucky in there, even after just 4 or 5 thousand miles.
Number of posts : 381
PostSubject: Re: cleaning element (11356-mct-000) (aKA a piece of foam)   cleaning element (11356-mct-000) (aKA a piece of foam) I_icon_minitimeWed Jun 14, 2023 4:13 pm
Mine was missing when I did my belt and clutch maintenance…I used some closed cell foam for HVAC floor registers (that I cut to size) and that seemed to fit really well in the region for it.
» 2009 Silverwing 600 fuel leak
» Brakes deposit small metal piece
» Uncomfortable seat
» Does Sea Foam Affect Mileage?
» How deep is the rider's seat foam on a SW?
