| Back Pressure | |
| Subject: Back Pressure Wed Mar 09, 2011 9:23 am | |
| I have noticed quite a bit of back pressure when cruising at motorway speeds. The scoot has a Givi Airflow screen and a Honda top box. Adjusting the position of the screen didn't make any difference at all. Removing the top box did though. As I will be touring in France and elsewhere in Europe not having a top box isn't an option. Has anyone else experienced the back pressure and how (if you did) did you overcome it. I never get the same back pressure when riding the Burgman. That has a 7Jurock screen (stock + 3") and I use Givi top boxes ranging from about 28 litres up to 45 litres. I may make a plate to fit the Givis onto the Silverwing and try them for size and shape. Actually the cold on the back maybe an advantage in the warmer climates but up here in Sunny Lancashire it is a bit too nippy for my old bones. Thoughts and ideas please. Cheers, |
| Subject: Re: Back Pressure Wed Mar 09, 2011 9:48 am | |
| I felt the back pressure first ride after fitting the Givi Airflow screen.
I thought the benefits of noise reduction out weighed the minimal effect of the pressure I was experiencing on my back and particularly my helmet. Exaggerated by the colder temperatures we have been experiencing over the winter months.
I experimented with differing heights on the Airflow but have not managed to find an optimal setting to eradicate the slight pressure. |
| Subject: Re: Back Pressure Wed Mar 09, 2011 11:06 am | |
| Hello Waspie,
I've tried all sorts of heights for the adjustable screen. One thing I haven't tried yet is removing the top part of the screen completely. This will probably be fine for the warmer climate of the Auvergne in June but not for Sunny Lancashire in March. What top box have you got? I am thinking that the Honda box with it's flat profile maybe a possible cause. Need to make a bracket so I can experiment with the Givi boxes. Cheers, |
| Subject: Re: Back Pressure Wed Mar 09, 2011 11:34 am | |
| Don't do top boxes!!!!!
Sleek and mean!!!!! |
| Subject: Re: Back Pressure Wed Mar 09, 2011 11:51 am | |
| Waspie,
It looks as if I am looking in the wrong place for a solution. Possibly the screen is the culprit. Cheers,
| Subject: Re: Back Pressure Wed Mar 09, 2011 2:28 pm | |
| I think so. The air is directed over the head but then eddies behind causing pressure or air rushes in to replace the displaced air caused by a minor vacuum!!!
Tis my theory!!!! |
| Subject: Re: Back Pressure Wed Mar 09, 2011 2:36 pm | |
| Yes, Don't understand why I never get it when on the Burgman. Has Suzuki solved the problem and not told Honda! I think I'll try a full tail bag sat on the pillion seat to see if that prevents it. (Another excuse to have to go for a ride!) Cheers, |
| Subject: Re: Back Pressure Wed Mar 09, 2011 3:40 pm | |
| I've got an Airflow screen and E52 topbox. In all honesty I haven't noticed if there's back-pressure or not. If there is it isn't enough to bother me. |
| Subject: Re: Back Pressure Wed Mar 09, 2011 5:04 pm | |
| I used to get back pressure with the stock screen and a large topbox, but since I added a Laminar Lip I haven't noticed it. |
Sweendog Maxi-Scooter Rider
Number of posts : 154 Location : South New Jersey Points : 5780 Registration date : 2009-07-12
| Subject: Re: Back Pressure Wed Mar 09, 2011 5:50 pm | |
| You could end the pressure entirely by filling the gaping void between your back and the top box with something. In airplanes, it's called a turtle deck, it's the bit that sticks up above the cockpit and usually has a headrest on the front of it. =) |
| Subject: Re: Back Pressure Thu Mar 10, 2011 5:29 am | |
| Sweendog,
I had been thinking along the same lines, you'll see in a posting above from me mentioning the use of a tail bag. At it's full height it should be about 16" high so should make a decent diffuser. I'll post when I have tried it. It won't be today though, high winds and wet stuff trying to land!
Cheers, |
| Subject: Re: Back Pressure Thu Mar 10, 2011 6:12 am | |
| That's very interesting! I rarely ride 'fast' without a bag on the back seat - perhaps that's why I haven't noticed any back-pressure. |
| Subject: Re: Back Pressure Thu Mar 10, 2011 8:15 am | |
| We may have stumbled across the solution to prevent back pressure. Serendipity strikes again!
Cheers,
| Subject: Re: Back Pressure Thu Mar 10, 2011 10:00 am | |
| - tarmacburner2 wrote:
- It looks as if I am looking in the wrong place for a solution. Possibly the screen is the culprit.
I wonder if a tail pipe extender would help?? Either due to a longer pipe or a slightly bent pipe/angled to exit on the side, especially since the windshield is not very wide. |
joncallihan Silver Wing Guru
Number of posts : 1025 Age : 86 Location : Lafayette, Colorado, USA Points : 6932 Registration date : 2009-02-16
| Subject: Re: Back Pressure Thu Mar 10, 2011 10:21 am | |
Either due to a longer pipe or a slightly bent pipe/angled to exit on the side, especially since the windshield is not very wide. This thread has nothing at all to do with exhaust back pressure so how could a tail pipe extender help? :flower: |
| Subject: Re: Back Pressure Thu Mar 10, 2011 10:27 am | |
| Indeed! We're chatting about the vortex created by the screen as it travels through the air. The vortex created by a racing car enables another car close behind to be sucked along and thus save energy. In American parlance it's called 'draughting', I think. |
| Subject: Re: Back Pressure Thu Mar 10, 2011 12:46 pm | |
| - joncallihan wrote:
- This thread has nothing at all to do with exhaust back pressure so how could a tail pipe extender help?
I reread the thread, I kept reading the "back pressure" as muffler back pressure ... I accidentally crossed this thread with another. |
| Subject: Re: Back Pressure Thu Mar 10, 2011 1:17 pm | |
| Bit early in life to have a 'senior moment' Bill Cheers, |
| Subject: Re: Back Pressure Fri Mar 11, 2011 4:19 am | |
| Sounds as if there is a correlation between senility and where people live! The pond must help to diffuse whatever environmental factors as senility usually starts at around sixty five over here. You have to be aware though that 'senility' and 'senior moments' are not inter-connected. Now whereabouts on the screen did I leave my butty? Cheers, |
| Subject: Re: Back Pressure Sun Apr 24, 2011 7:36 pm | |
| Sorry it is a bit late in posting but thought I would let people know what I found.
Tried a tail bag on the pillion seat and it worked a treat. It is now a semi permanent item on the scoot. If not going on the motorway then it stays in the garage. I have also been experimenting with the position of the Givi Adjustable Windscreen, as yet I haven't found the ideal setting for it yet. I need to as we are off to France for two weeks in June so plenty of quick riding.
Realised why I wasn't getting back pressure problems whilst riding the Burgman - I had a Three Brothers backrest fitted. I have now removed it as the roads here are crap, everytime I went over a bump it thumped me in the back. Will use the tail bag if needs be.
Cheers, |
| Back Pressure | |
