LW RED WING Scooter Rider
Number of posts : 9 Age : 70 Location : Walford,IA Points : 4931 Registration date : 2011-06-09
| Subject: DRIVING LIGHT ADDITION Thu Jun 16, 2011 11:05 am | |
| Dennis: Looked at the Optronic light set you suggest to use to add driving lights at Wal-mart and it does not come with a relay. Uses a direct wire to battery. Did you use a relay in your application or not? On another note....concerning air filter box modification. Has anyone tried running without the air filter cover? Just have the filter screwed in with the 1 screw and open to ambient air. Thanks Larry |
| Subject: Re: DRIVING LIGHT ADDITION Thu Jun 16, 2011 11:19 am | |
| Subject: Re: DRIVING LIGHT ADDITION Thu Jun 16, 2011 12:00 pm | |
| Dennis: Thanks for your help on the relay. Any thoughts on the air box question? Larry |
| Subject: Re: DRIVING LIGHT ADDITION Thu Jun 16, 2011 1:25 pm | |
| - LW RED WING wrote:
- Any thoughts on the air box question?
Some people have drilled holes in the air box. If you search for "drill" "air" you might find. |
| Subject: Re: DRIVING LIGHT ADDITION Thu Jun 16, 2011 1:43 pm | |
| There is only one screw that holds the Silverwing air cleaner in and the outer cover does all the rest of the holding. |
