4 way emergency flashers I_icon_minitimeby sonuvabug Yesterday at 4:19 pm
4 way emergency flashers I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
4 way emergency flashers I_icon_minitimeby sonuvabug Yesterday at 4:06 pm
4 way emergency flashers I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
4 way emergency flashers I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
4 way emergency flashers I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
4 way emergency flashers I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
4 way emergency flashers I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
4 way emergency flashers I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
4 way emergency flashers I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Kurtis
Number of posts : 3
Registration date : 2011-07-06
4 way emergency flashers Empty
PostSubject: 4 way emergency flashers   4 way emergency flashers I_icon_minitimeThu Jul 07, 2011 8:58 am
has any one rigged up emergency flashers or know of a plug and play system ? cant belive this is not somthing the dot requires .
Number of posts : 2778
PostSubject: Re: 4 way emergency flashers   4 way emergency flashers I_icon_minitimeThu Jul 07, 2011 6:44 pm
Yes! These are powered off my headlight. Very low voltage draw.
https://www.silverwing600.com/t1683-4-way-flashers
bikerboy
Number of posts : 405
PostSubject: Re: 4 way emergency flashers   4 way emergency flashers I_icon_minitimeFri Jul 08, 2011 2:41 pm
I was quite surprised to find that my nice new SWing did not have 4 way flashers/hazard lights as my last two Honda bikes (a Deauville and before that a Varadero) both came equipped with them from new. Perhaps times are getting hard for Honda San especially judging by some of the accessory prices !!!
bikerdaryl
Number of posts : 23
Registration date : 2011-05-24
PostSubject: Re: 4 way emergency flashers   4 way emergency flashers I_icon_minitimeFri Jul 08, 2011 3:08 pm
Not to mention that the Goldwing has them too...
masscoot
masscoot
Number of posts : 438
PostSubject: Re: 4 way emergency flashers   4 way emergency flashers I_icon_minitimeFri Jul 08, 2011 9:45 pm
If you're a DIY'er here is a project for you. Dennis is the chief gadget and gizmo guru here and his plug n' play connector needs to be part of this or any electrical project.
When I began to add lights and electronics to my scoot I knew I wanted to have one source of power and one ground location just to keep troubleshooting simple. I bought and installed a Centech power block and run all my power and grounds to it. That way I keep the harness free from cuts and shorts. The electronics are powered with switched power (thru a relay) so everything shuts down when the key is turned off, except the 4-ways. My thought was if I have to leave the bike on the side of the road, I could still lock it up and leave the 4 ways on.
I mounted the fuse block on the inside of one of the access panels in the trunk (on the battery side) Here is a picture I will post some better views tomorrow.
masscoot
masscoot
PostSubject: Re: 4 way emergency flashers   4 way emergency flashers I_icon_minitimeSat Jul 09, 2011 8:42 am
Here are the picture updates.
Inside the trunk-fuse panel door closed
4 way emergency flashers IMG_7618
Fuse panel is easily accessible for fuse checking
4 way emergency flashers IMG_7621
A close up of the panel and relay
4 way emergency flashers IMG_7627
» 4-Way blinkers
» Four way flashers?
» 4 way flashers
» Easy Alternate 4-Way Flashers
» 4 Way Flashers Tutorial Video
