| Brake Lever Change | |
ehaughn Maxi-Scooter Rider
Number of posts : 131 Age : 56 Location : Norcross, GA Points : 5485 Registration date : 2010-06-13
| Subject: Brake Lever Change Mon Aug 01, 2011 1:42 pm | |
| I need to change my brake lever.
Has anyone done this? Any issues when I remove the lever? Will any springs come flying off? Do I have to bleed the hydralic fluid? |
Number of posts : 330 Age : 51 Location : Atlanta, GA Points : 5348 Registration date : 2011-05-13
| Subject: Re: Brake Lever Change Mon Aug 01, 2011 2:31 pm | |
| I replaced my bent one a few weeks ago (bike fell over). Extremely easy with just a flat screwdriver (if I recall). Nothing will fall out.
Jesse in Atlanta |
Number of posts : 2778 Age : 74 Location : NE Oklahoma Points : 9091 Registration date : 2008-12-28
| Subject: Re: Brake Lever Change Mon Aug 01, 2011 9:49 pm | |
| As I remember, There is a small nut on the bottom that you need to pay attention to when you remove the lever. |
| Subject: Re: Brake Lever Change Mon Aug 01, 2011 11:17 pm | |
| Thanks for your responses.
I am slowly replacing necessary parts on the swing. |
| Subject: Re: Brake Lever Change Tue Aug 02, 2011 6:23 am | |
| Thats weird- my nut seems to be attached, or maybe it is just glued on. |
Number of posts : 3837 Age : 75 Location : Seaham, Co Durham, UK Points : 9699 Registration date : 2009-06-29
| Subject: Re: Brake Lever Change Tue Aug 02, 2011 6:28 am | |
| Until you're standing over the drain in your driveway - then it will mysteriously drop out! |
masscoot Silver Wing Rider
Number of posts : 438 Location : Central New England Points : 6175 Registration date : 2009-03-24
| Subject: Re: Brake Lever Change Tue Aug 02, 2011 5:35 pm | |
| If I remeber correctly, the goldwing adjustable brake lever is compatable. Got to research where I saw that. Be back soon... |
| Subject: Re: Brake Lever Change Tue Aug 02, 2011 6:30 pm | |
| Hi Paul,
I did the research on the brake levers off the gold wings. Only the right lever would work with the Silverwing. On the Goldwing the left is a clutch lever so that side did not work at all. |
| Subject: Re: Brake Lever Change Tue Aug 02, 2011 6:50 pm | |
| You are right on the money Dennis, OEM are under $20 bucks each. If you do lose the nut it is a 6mm cap nut 90201-415-000 about $2.90. |
| Subject: Re: Brake Lever Change Tue Aug 02, 2011 10:47 pm | |
| Thanks for all your help.
I installed the left one today, piece of cake.
Also, I wanted to share something with all of you. I found buying online from www.powersportsplus.com has the best prices. Shipping is cheap. They match any price you can find. And best of all, if you know the secret code, you get another 15% off.
| Subject: Re: Brake Lever Change Wed Aug 03, 2011 8:27 am | |
| and what is the secret code? |
| Subject: Re: Brake Lever Change Wed Aug 03, 2011 8:44 am | |
| It's top secret. Look at www.boats.net You will see the current code. |
