Spraying the Headlight Amber I_icon_minitimeby zrx212 Today at 4:40 pm
Spraying the Headlight Amber I_icon_minitimeby Meldrew Today at 4:37 pm
Spraying the Headlight Amber I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Spraying the Headlight Amber I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Spraying the Headlight Amber I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Spraying the Headlight Amber I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Spraying the Headlight Amber I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Spraying the Headlight Amber I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Spraying the Headlight Amber I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Spraying the Headlight Amber I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Silver Winger
8 posters
Silver Winger
Number of posts : 8
Registration date : 2011-07-17
Spraying the Headlight Amber Empty
PostSubject: Spraying the Headlight Amber   Spraying the Headlight Amber I_icon_minitimeSat Aug 06, 2011 5:20 pm
Hi from a chilly Cape Town, South Africa
Anyone sprayed the inside of their headlight cover with luminescent orange spray suitable for polycarbonate services?
The reason for wanting change to orange is to easily seen by motorists
Safe Biking, you guys motorcycle
Number of posts : 2387
PostSubject: Re: Spraying the Headlight Amber   Spraying the Headlight Amber I_icon_minitimeSat Aug 06, 2011 6:06 pm
Is a headlight modulator legal in S. Africa?
That would be far preferable to painting the inside of the lens cover. You'll lose too much light intensity by painting it.
If the modulator is illegal, add extra driving lights lower on the forks. And try wearing hi-viz clothing and a high-viz helmet.
Number of posts : 341
PostSubject: Re: Spraying the Headlight Amber   Spraying the Headlight Amber I_icon_minitimeSat Aug 06, 2011 7:44 pm
I prefer the extra amber or yellow auxiliary lighting mounted to the forks or on the DennisB bracket over a single off color light.
https://www.silverwing600.com/t624-spot-light-relocation-and-bracket?highlight=bracket
Before you alter the expensive headlight assembly give these a try.
http://www.rallylights.com/detail.aspx?ID=2467
Number of posts : 3837
PostSubject: Re: Spraying the Headlight Amber   Spraying the Headlight Amber I_icon_minitimeSun Aug 07, 2011 5:22 am
You could lash out and buy a headlight cover to spray, rather than painting the stock headlight glass.
Number of posts : 2008
PostSubject: Re: Spraying the Headlight Amber   Spraying the Headlight Amber I_icon_minitimeSun Aug 07, 2011 6:20 am
Any color you can add will actually reduce brightness and therefore your ability to see in the distance. Typically only foglights are yellow, and for specific reason.
The Silverwing can handle a lot of extras electrically. Better to get aftermarket lights and leave your headlight stock.
Also, is there any regulation in your country about the color of headights?
In some countries there are two small yellow lights at the 11 and 1 o'clock positions relative to the headlight. Typically they are 5 watt bulbs, but there is nothing stopping you from replacing those bulbs with higher power and insuring there is enough power there to handle them.
If they are not part of the requirements for your country, then the space exists but not the holes. Where the holes are normally drilled their are two nipples on the back of the light, so its easy to know where to drill. Drill thru the back and attach your favorite yellow or orange bulbs right there. Power it up thru a separate relay and swiitch an you have a stock headlight look with colored light for visibility.
Dan
tankyuong
tankyuong
Number of posts : 475
PostSubject: Re: Spraying the Headlight Amber   Spraying the Headlight Amber I_icon_minitimeSun Aug 07, 2011 10:50 am
just buy a yellow bulb
Silver Winger
Number of posts : 8
PostSubject: Re: Spraying the Headlight Amber   Spraying the Headlight Amber I_icon_minitimeSun Aug 07, 2011 3:13 pm
Hi Bigbird and Ron!
Yes, modulators are illegal in SA. The extra spots does appear to be an option, Thanks!
Silver Winger
Number of posts : 8
PostSubject: Re: Spraying the Headlight Amber   Spraying the Headlight Amber I_icon_minitimeSun Aug 07, 2011 3:27 pm
Dan
Hi Dan!
In S Africa, both driving and high beam lights must be the same colour whether white, amber or orange. BMW and KTM with one amber and the other white are chalenging our authorities
I like our idea of using the small lights and upgrading the Watts. I suppose I could look at that changed to amber as well as the driving and high beams. Hope we can easily obtain them in S Africa
Thanks for your input Bud!
cheers
Daboo
Daboo
Number of posts : 271
PostSubject: Re: Spraying the Headlight Amber   Spraying the Headlight Amber I_icon_minitimeMon Aug 08, 2011 10:13 am
You might want to try using the Philips Motovision bulb. It comes in orange for the same reason you are looking to spray the headlight lens.
Spraying the Headlight Amber S_motovision_usp
As dspevack wrote, if you spray the lens with paint, you will block the headlight output. It is like putting a lamp shade on it.
Chris
Silver Winger
Number of posts : 8
PostSubject: Re: Spraying the Headlight Amber   Spraying the Headlight Amber I_icon_minitimeWed Sep 21, 2011 4:01 pm
Hi All!
I lost my nerve and decided to go the safe route and use a film over the lens
(11 Kb) Downloaded 20 times
(12 Kb) Downloaded 16 times
tubeck
Number of posts : 85
Registration date : 2011-08-10
PostSubject: Re: Spraying the Headlight Amber   Spraying the Headlight Amber I_icon_minitimeThu Sep 22, 2011 2:38 pm
Philips motovision bulb white sounds like a great upgrade
» How do you fill up without spraying petrol (gas) everywhere?
» Amber lights has come on
» Rear Amber Marker Lights Sucessfully Completed
» Converting White Auxiliary Lenses into Amber Lenses
