- allhondascoots wrote:
- Do you run your set up without the front backrest at all?
I do not have the front OEM backrest, which I call "buttrest". If you take the buttrest apart you will find a heavy metal plate at the bottom of the buttrest which created a lot of discomfort on my lower back/tailbone ... what a relief.
I do have the Utopia backrest. The Utopia backrest sits future back then just raising the buttrest up and it you can adjust how far forward you want it ... I have it extended and adjusted forward close to the maximum.
I have the Air Hawk on the seat which is covered by an Alaskan Sheepskin which lifts me up enough that the slope of the front seat without the buttrest and allowing me to slide back as much as I want ... I slide all the way back to the Utopia backrest.
Suggested steps
1) So I would first suggest removing the buttrest and checking if that
helps resolve your legroom.
2) If the front seat slope without the backrest does not allow you to comfortably slide back further ... then raising via Air Hawk (or something equivalent) would remove the slope .
3) If you need backrest support with long legroom ... I do not believe raised buttrest would work ... but I am sure the Utopia would not interfere with your ability to stretch out.
I originally thought I would need a Russel Day long seat, now I have do not need it ... and my portable seat solutions can go with me except for the Utopia backrest (which I would purchase a new one).
- The few aftermaket options out there don't really solve my problem..I wish someone made a long flat seat, or something for 34+ inseams..
I am 32 inseam but I know could adjust the Utopia backrest back further and get a couple of more inches ... without feeling any seat slope.
I hope that helps.
