I need to change my rear brake pads and saw a comment somewhere about a screw that is related to the parking brake. Have not changed before and not sure if you need to do anything but replace pads and re-install. Any help here will be appreciated.
Also, I have read some of your comments about changing the drive belt yourselves. What type of tools do you need to change the belt? I have many tools but nothing to conpress the spring if needed. I am going on 32,000 miles with the original belt, no problems other than a possible rubbing sound that, after reading comments on sliders, maybe they are making the sound. I have been doing some traveling at 75 mph (rpm @5700) for couple hours at a time and am wondering if that speed/heat has worn them faster.
Is the engine able to handle the high rpms?
