Number of posts : 2658 Age : 81 Location : Medford, Oregon Points : 8374 Registration date : 2009-07-17
| Subject: Rear brake pads Wed Sep 02, 2009 7:02 pm | |
| I just changed the pads on the rear caliper of my SW and I have to tell you I've changed brake pads in a lot of vehicles and bikes and this is the easiest of them all. If you're just replacing the pads all you have to do is put the bike on the centerstand, remove the pad pin keeper, pull the pad pin out of the caliper, press the caliper inward to push in the pistons a bit to free up the pads, drop the pads out, replace with new and replace the pin and keeper. Fifteen minutes if you're not in a hurry. It was interesting to note that the same pads that fit the rear of the SW also fit the big Valkyrie and the ST1100. That says the rear brake is plenty big for this little scoot. If you go with EBC pads the part number is FA196 and the price is a bit over $30. |
| Subject: Re: Rear brake pads Wed Sep 02, 2009 11:25 pm | |
| I just changed the front and rear brakes on mine. YES, it's as easy as you say. |
Number of posts : 199 Age : 63 Location : Athens Greece Points : 4819 Registration date : 2012-04-05
| Subject: Re: Rear brake pads Tue May 08, 2012 3:48 pm | |
| Hello everydody.New member from Greece here.Concerning the rear aftermarket pads we have to remove the inox isolator holders as well as the isolators themselves between piston and pad 'cause there's no space for them as ...EBCs at least... are thicker than the OEM ones.We can put them back after 500 miles at least |
Number of posts : 2453 Location : Georgetown, Tx Points : 8348 Registration date : 2008-12-23
| Subject: Re: Rear brake pads Tue May 08, 2012 4:11 pm | |
| - micbusathens wrote:
- Concerning the rear aftermarket pads we have to remove the inox isolator holders as well as the isolators themselves between piston and pad 'cause there's no space for them
From the picture http://www.bikebandit.com/houseofmotorcycles/2007-honda-silver-wing-abs-fsc600a-rear-brake-caliper/o/m150991sch417916 ... which part numbers are the isolators and inox isolator?? |
| Subject: Re: Rear brake pads Tue May 08, 2012 4:35 pm | |
| They are ON the pads ....at least on my FJS and they are not shown at the diagram.Honda does not sell them separately .They are in the container as a set with the pads.Its good to keep them when you change OEMs with aftermakets. |
Old Sloppy Scooter Rider
Number of posts : 33 Age : 66 Location : Atlanta, Ga. Points : 4591 Registration date : 2012-05-13
| Subject: Re: Rear brake pads Sun May 13, 2012 11:51 am | |
| How many miles did you get on your old brake pads?
I have 20,000 on mine and they are still O.K.
Harry |
| Subject: Re: Rear brake pads Sun May 13, 2012 2:35 pm | |
| With city use I change them every ...7000 miles
