Brake pads I_icon_minitimeby Hop Today at 7:04 pm
» Rear wheel valve stem
Brake pads I_icon_minitimeby GHM-PM Today at 6:43 am
Brake pads I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Brake pads I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Brake pads I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Brake pads I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Brake pads I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Brake pads I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Brake pads I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Brake pads I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
 Brake pads
jmaslak
WingMan02
WingMan02
WingMan02
Number of posts : 287
Brake pads Empty
PostSubject: Brake pads   Brake pads I_icon_minitimeSat Apr 27, 2013 4:41 pm
When replacing the brake pads, do I re-user the backing plate from the old pads? My new pads did not come with any?
jmaslak
Number of posts : 252
Brake pads Empty
PostSubject: Re: Brake pads   Brake pads I_icon_minitimeSat Apr 27, 2013 11:40 pm
The Honda pads come with the friction material attached to the backing plate as one unit. Can you post a picture of the new pads and the old backing plate, so we can be sure we are talking about the same parts?
Number of posts : 3316
Brake pads Empty
PostSubject: Re: Brake pads   Brake pads I_icon_minitimeSun Apr 28, 2013 3:57 am
Send them back---get proper ones. Local Honda dealer should know.
Brakes rather important----how lomg since brake fluid system flushed??
ScootRGuy
Number of posts : 55
Registration date : 2013-01-28
Brake pads Empty
PostSubject: Re: Brake pads   Brake pads I_icon_minitimeSun Apr 28, 2013 10:13 am
I just received a set of front pads which are Honda OEM equipment and they came with the stainless steel backing plates.
Gary
bikerboy
Number of posts : 405
Brake pads Empty
PostSubject: Re: Brake pads   Brake pads I_icon_minitimeSun Apr 28, 2013 11:57 am
Are these 'backing plates' a form of anti-rattle device?
Number of posts : 921
Brake pads Empty
PostSubject: Re: Brake pads   Brake pads I_icon_minitimeSun Apr 28, 2013 1:09 pm
I have used "Goldfren" brake pads front and rear. I have put the backing off my original ones on. I have also not put these back pads on and had no problems. Smile
ScootRGuy
Brake pads Empty
PostSubject: Re: Brake pads   Brake pads I_icon_minitimeSun Apr 28, 2013 3:57 pm
I also noticed that there is another backing plate on the piston side of the shoe. My assumption is it's a heat shield and is probably use to keep the pistons cooler during extreme braking.
Brake pads Empty
PostSubject: Re: Brake pads   Brake pads I_icon_minitimeSun Apr 28, 2013 8:36 pm
Along with the backing plate you should also have a white fiber or plastic pad, the same shape as the metal part of the brake pad. That plastic pad needs to go on the back of metal part of the brake pad then put on the backing plate to hold it in place. If you do not put the plastic pad in between the back of metal part of the brake pad and backing plate the tabs of the backing plate will rub the brake disk before your brake pads are gone and not give you the full life of the brake pads. Aftermarket pads do not come with the plastic pads or the backing plates. I don't think you have to use the plastic pads or the backing plates when using aftermarket brake pads, but that is one of the reasons I use Honda brake pads. Another reason is when I tried EBC brake pads on my front wheel they wore the brake disk down prematurely, costing me big dollars. I don't think Honda would waste money putting them with their brake pads if they were useless. But I have seen a lot of breaks without them and not have a problem.
Sorry for the long post, but I hope it helps explain what the backing plates are for.
WingMan02
WingMan02
Brake pads Empty
PostSubject: Re: Brake pads   Brake pads I_icon_minitimeMon Apr 29, 2013 1:18 am
I wanted to try ceramic brakes. I ended up installing the pads with the backing plates, including the white fibre sheet. I believe the backing plates are used to eliminate brake squeak, and the fibre sheet looks like it is there to reduce the heat being transferred to the calipers.
Brake pads Empty
PostSubject: Re: Brake pads   Brake pads I_icon_minitimeMon Apr 29, 2013 5:00 pm
WingMan02, how did the ceramic brakes work out? Did they cause extra or premature wear on the brake disk?
WingMan02
WingMan02
Brake pads Empty
PostSubject: Re: Brake pads   Brake pads I_icon_minitimeMon Apr 29, 2013 7:05 pm
model28a, I only have about 20 miles on the pads. Initial observations is that the pads seem to be riding on the rotor as I do notice it when trying to back the bike up while sitting on it. Brake seems to engage sooner than my old pads. After removing the pads, the old pads had about 50% left. The break in period is about 300 miles. Will post any updates in about a month.
Brake pads
» Brake pads.
» Brake pads
» Rear brake pads
» front brake pads
» Inexpensive Front brake pads for Honda Silver Wing
