Why does SW have a trailing front axle? I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Why does SW have a trailing front axle? I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Why does SW have a trailing front axle? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Why does SW have a trailing front axle? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Why does SW have a trailing front axle? I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Why does SW have a trailing front axle? I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Why does SW have a trailing front axle? I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Why does SW have a trailing front axle? I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Why does SW have a trailing front axle? I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Why does SW have a trailing front axle? I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
3 posters
IDwingit
Number of posts : 26
Registration date : 2011-07-15
Why does SW have a trailing front axle? Empty
PostSubject: Why does SW have a trailing front axle?   Why does SW have a trailing front axle? I_icon_minitimeSun Aug 28, 2011 12:29 am
I am not an expert on motorcycle frame/suspension geometry or the cause and effect of changes to rake and trail.
But esthetically speaking, I wonder why the SW has a front axle located behind the fork legs vs. most motorcycles/scooter/bicycles which have leading front axles or axles mounted at the tips of the fork legs such as Burgmans?
I have a hard time getting past the appearance of the front fork on my scooter with the trailing front axle
AAAA
Number of posts : 442
Registration date : 2010-11-14
PostSubject: Re: Why does SW have a trailing front axle?   Why does SW have a trailing front axle? I_icon_minitimeSun Aug 28, 2011 12:52 am
The moment of inertia is raised up further on the fork leg. And wheelbase has a huge effect on the longitudinal stability of the frame system.
Wow, check out the big brain on Tagg!
IDwingit
PostSubject: Re: Why does SW have a trailing front axle?   Why does SW have a trailing front axle? I_icon_minitimeSun Aug 28, 2011 12:58 am
So you are saying that Honda made the frame too long and had to place the axle behind the fork leg in order to compensate?
LOL
IDwingit
PostSubject: Re: Why does SW have a trailing front axle?   Why does SW have a trailing front axle? I_icon_minitimeSun Aug 28, 2011 1:01 am
Irregardless of the front fender as well as the front brake caliper mounting, what would be the effect of swapping the left/right fork legs and placing the axle in a leading position?
AAAA
PostSubject: Re: Why does SW have a trailing front axle?   Why does SW have a trailing front axle? I_icon_minitimeSun Aug 28, 2011 1:15 am
LOL
Not at all! The greater the distance behind the rake line that the axle centerline is the better, however it is a exponentially diminishing effect.
AAAA
PostSubject: Re: Why does SW have a trailing front axle?   Why does SW have a trailing front axle? I_icon_minitimeSun Aug 28, 2011 1:18 am
You would be increasing the lean angle in turns, making scrubbing your front end out very much more of a likelihood.
Number of posts : 3313
PostSubject: Re: Why does SW have a trailing front axle?   Why does SW have a trailing front axle? I_icon_minitimeSun Aug 28, 2011 8:02 am
They put it where it works for the design. Who cares how is looks? Function is the deal if you ride a lot and SilverWing Suspension as scooter works well.
Forks= we have tele as SilverWing and most motorcycles today. Leading link=early honda step thru cubs, NSU MAX and Fox, others Trailing Link=Indians with leaf spring, Vespa.
» Front axle wont come out.
» Metric size for front axle nut!
» Axle to axle measurement
» Does honda silver wing has dual ABS (front and back) or only front ?
» Rear axle nut
