| Axle to axle measurement | |
WingMan02 Super Scooter Rider
Number of posts : 287 Location : Honolulu Points : 5019 Registration date : 2012-01-19
| Subject: Axle to axle measurement Sun Jun 30, 2013 1:13 am | |
| Does anyone have the length between the front and rear axle? The measurement should be taken when on center stand, center of axle to center of axle? Thanks in advance. |
jobo2mi Super Scooter Rider
Number of posts : 238 Age : 70 Location : Kalamazoo, Michigan Points : 5218 Registration date : 2011-06-06
| Subject: Re: Axle to axle measurement Sun Jun 30, 2013 7:20 am | |
| You don't have a measuring tape yourself????? |
jmaslak Super Scooter Rider
Number of posts : 252 Location : Golden, CO, USA Points : 4804 Registration date : 2012-06-15
| Subject: Re: Axle to axle measurement Sun Jun 30, 2013 11:52 am | |
| I'm truly curious why you need the measurement.
Wheelbase (that is the same as axle-to-axle) is 62.8 inches per Honda, but not sure exactly how they measured it. If what you need it for actually matters about whether or not it's on the center stand or not, you better measure it yourself so you get the exact right number, because it won't be a lot different than 62.8 and I wouldn't trust some random person on the internet to do the measurement for something extremely precise. |
Number of posts : 350 Location : Elkton , Maryland Points : 5095 Registration date : 2011-12-11
| Your owner's manual will give you the wheelbase if you don't want to take the trouble to measure
Don't know if it has changed over the years or not , but my 2007 is listed at 62.8 inches or 1,595mm |
| Subject: Re: Axle to axle measurement Sun Jun 30, 2013 4:47 pm | |
| Thanks all for your responses. I had a minor front end accident and wanted to know if the front end had shifted any. Obviously I could have measured my Swing, but that will not answer my question. Thanks again. |
Number of posts : 199 Age : 63 Location : Athens Greece Points : 4837 Registration date : 2012-04-05
| Subject: Re: Axle to axle measurement Sun Jun 30, 2013 5:03 pm | |
| - WingMan02 wrote:
- Thanks all for your responses. I had a minor front end accident and wanted to know if the front end had shifted any. Obviously I could have measured my Swing, but that will not answer my question. Thanks again.
Figures.That's what I thought from the begining.Be shure to mesure on the center stand as it's mentioned above. |
| Subject: Re: Axle to axle measurement Sun Jun 30, 2013 5:53 pm | |
| OK, my measurement is at 61.8. It is an inch short. I know that the stem bearing needs to be replaced. It has a distinct notch when turning lock-to-lock. Will pull the bearing and measure the steering tube for out of round. If OK, will order and replace the bearings then re-check. |
| Subject: Re: Axle to axle measurement Mon Sep 09, 2013 7:24 pm | |
| Update. The steering stem had a bent shaft due to the frontal accident I had. After replacing the stem, and installing new roller bearings/races my wheel base is within 1/8 of an inch off of the specification. |
RArch Silver Wing Expert
Number of posts : 613 Age : 57 Location : West London, UK Points : 5408 Registration date : 2011-11-07
| Subject: Re: Axle to axle measurement Tue Sep 10, 2013 2:15 pm | |
| You'll have us all out with our measuring tapes now |
