goldwinger Scooter Rider
Number of posts : 75 Age : 70 Location : Canvey Island, Essex, UK Points : 4997 Registration date : 2011-06-15
| Subject: Side by side comparison , stock V Dr P sliders Mon Aug 29, 2011 1:44 pm | |
| Today, Me and another forum member, Nigel, had a chance to run our 2001 Swings side by side in a drag off. His bike is stock in the variator/clutch department, mine has a V4 Hit clutch and 26g sliders. Run 1) Me on mine, Nigel on his. Flat out up to about 70mph Mine got a faster start and pulled away to about a 50yds lead, then held the gap. Run 2) Same combination, same result. Run 3) We switched bikes. Nigel got away faster on mine, took about a 30 yds lead, then held it. Run 4) Same combo, same result. Conclusions: We estimated that I'm about 45lb lighter than Nigel, so thats why the difference in the lead gap. The sliders/clutch do make a difference, especially at takeoff (as expected) but once in "top gear" , there is no difference in performance (as expected) My Hit clutch was installed with the springs fitted as standard. Nigel pointed out that there was a little clutch judder, which I knew, so I will be changing the pillow springs soon to rectify that.
I hope that after I fit the 21g or 21/26g slider combination and pillow springs, I get a chance to test the set-up again, as it's much better than guessing or imagining a performance improvement.
Thanks Nigel, I enjoyed meeting you and having a little play!!!!!!
Ian
Number of posts : 693 Age : 67 Location : Loveland, Colorado Points : 6448 Registration date : 2009-01-23
| Subject: Re: Side by side comparison , stock V Dr P sliders Mon Aug 29, 2011 9:28 pm | |
| Thanksfor the write up Ian. Nothing beats a head to head comparison. I look forward to the result after you change the weights. |
