leaking front shock I_icon_minitimeby zrx212 Yesterday at 4:40 pm
leaking front shock I_icon_minitimeby Meldrew Yesterday at 4:37 pm
leaking front shock I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
leaking front shock I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
leaking front shock I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
leaking front shock I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
leaking front shock I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
leaking front shock I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
leaking front shock I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
leaking front shock I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
 leaking front shock
3 posters
richard
Number of posts : 21
Registration date : 2011-08-28
leaking front shock Empty
PostSubject: leaking front shock   leaking front shock I_icon_minitimeTue Aug 30, 2011 8:00 pm
should I try to do this myself any advice or how to info I just bought a 2002 honda silverwing and I would like to fix this myself but i have no service manual I read a how to on this site but Im still not sure how to fix this I would try to buy a manual but not sure it would be in there please help any help in finding a servise manual would be great to thank you
matthew
matthew
Number of posts : 361
PostSubject: Re: leaking front shock   leaking front shock I_icon_minitimeTue Aug 30, 2011 10:16 pm
A leaking front fork means a fork seal is shot, most probably. I recently did this job myself while also replacing the fork springs with hyperpro's. I wouldn't have attempted it without the service manual. I bought mine on ebay a few years back. You might check there. There are other online sources which typically cost quite a bit more.
When you get to the part where you need to seat the new seals, all you need as a "special tool" is a short (maybe 10" or so) length of standard 1 1/2" pvc pipe, and a rubber mallet. The pipe will fit snugly over the inner tube and sit nicely on top of the new seal. Then you tap the seal down easily by hitting the top of the pipe with the mallet until it reveals the groove on the inside of the tube where the round-ish metal ring/seal holder will sit.
All this will make sense when you've taken the thing apart according to the manual, and are putting it back together.
Since your scoot is now "old", and if you can afford it, you might consider replacing the fork springs with hyperpro progressive springs.
They're also available online for about $175 including shipping.
Good luck.
Number of posts : 2392
PostSubject: Re: leaking front shock   leaking front shock I_icon_minitimeWed Aug 31, 2011 7:47 am
Although a new member I have moved to an appropriate section for an answer to the querie!!!
OH, welcome Richard, always difficult knowing where to place your first post!!!!! welcome
leaking front shock
» front forks leaking?
» Front fork seal leaking
» squeaking front shock
» Shock adjustment question
» Fork Leaking
