| Those dang expensive leg deflectors | |
+6model28a john123 Daboo dspevack matthew craigory 10 posters |
craigory Maxi-Scooter Rider
Number of posts : 120 Age : 67 Location : California Points : 5075 Registration date : 2011-06-25
| Subject: Those dang expensive leg deflectors Fri Sep 16, 2011 8:13 pm | |
| I am planning to buy a pair of leg deflectors for my SWing later this fall. As most of you already know, for some inexplicable reason they are not available in the US. I can order a set from Britain and it will cost me GBP105 plus GBP50 for shipping (probably includes customs). For us yanks that means about $245 dollars total. That is just so incredibly expensive for two small pieces of plexiglas. I have had a pair before and they definitely made a significant difference in the winter, but it just galls me to spend that much for them. I just don't want to pay so darn much. So...
Does anybody here in the US know a cheap way to get these? Do any of you Brit's know of any way to get a set cheaper? Is there a discount outlet for Honda parts where it might cost less, and where shipping to the US might cost less? I sure hope some of you guys have some ideas before I mortgage my house to get them.
Thanks! |
matthew Touring Scooter Rider
Number of posts : 361 Location : near Santa Fe, NM Points : 6237 Registration date : 2008-12-24
| Subject: Re: Those dang expensive leg deflectors Fri Sep 16, 2011 9:44 pm | |
| I understand that some folks have adapted some of these things and have been happy with the results: http://www.jcwhitney.com/jcwhitney/textsearch_result.jcw?sku=window+water+deflectors&shopid=100001&_requestid=7021250
Can't speak from my own experience. I agree. The price for the "official" things is ridiculous. I'm certain, without a doubt, that an "unofficial", unorthodox alternative can be devised.
Good luck. Think outside the box. |
| Subject: Re: Those dang expensive leg deflectors Fri Sep 16, 2011 9:57 pm | |
| That's a pretty intriguing thought. They look very similar to the Honda models. On JC Whitney they are all custom fit and you have to supply the make and model of your car. Not sure how I would match that up with the shape of our fairings. I might go to Pep Boys and see if they have any "generic" ones in stock to look at. Thanks for the idea! |
dspevack Silver Wing Guru
Number of posts : 2008 Age : 59 Location : Miami, FL Points : 8213 Registration date : 2008-12-27
| Subject: Re: Those dang expensive leg deflectors Fri Sep 16, 2011 10:06 pm | |
Daboo Super Scooter Rider
Number of posts : 271 Age : 72 Location : Seattle, WA Points : 5764 Registration date : 2009-12-08
| Subject: Re: Those dang expensive leg deflectors Sat Sep 17, 2011 9:51 am | |
| Another thought besides the pricey leg deflectors from Honda, is to use the rear window visors from a car or truck. Others have done it in the past with their Burgmans with great results. While you can get some sets that are pretty pricey, I saw some visors being sold for $12.45 here. http://www.car-stuff.com/ventvisor.htm eBay also had some for a low price. You could probably go to a junk yard and find some there for a reasonable price that would look like new. Chris |
john123 Maxi-Scooter Rider
Number of posts : 133 Age : 76 Location : Santa Barbara California Points : 5570 Registration date : 2010-02-21
| Subject: Re: Those dang expensive leg deflectors Sat Sep 17, 2011 10:22 am | |
| I have been using a pair of hard rubber leg deflectors I bought on ebay since last year that work great. I found them on one of the very last pages and at the bottom of the page. I believe they only cost about $45.00
The first page had many beautiful color pictures of S/W showing Givi boxes I believe. They are the thickness of a side wall of a motorcycle tire and fit under the rubber floor mat, using existing screws. You can look at my pictures and see if that helps. If I find the receipt I will post here later. |
| Subject: Re: Those dang expensive leg deflectors Sat Sep 17, 2011 3:41 pm | |
| Thanks Daboo and John. John, your suggestion definitely sounds easy to install, and I'll definitely have to give it some serious thought. Daboo, I am really confused about how one would know which model to buy, and how it is installed. Do you have to bend it to shape. Do you have any photos of an installation? Thanks! |
| Subject: Re: Those dang expensive leg deflectors Sat Sep 17, 2011 5:03 pm | |
| Craig, the posts I saw on BurgmanUSA were years ago; I don't know that I can find a picture to show you.
For the longest time, I too was confused. The reason you use the rear window visor is that is the length that will fit on that upper portion of the foot rest that slopes upward. If you get the proper length, you don't have to bend or cut anything. One end will taper just right to blend in at the top of your footrest, and the other end will taper to blend in at the bottom where the footrest turns horizontal.
For the Burgman, the people suggesting it were using a GMC 4-door cab truck. I think you'll find it easier to match up the proper length than you'd imagine. I was originally thinking you needed to match the bend in the front window to the curve on our footrests or floorboards. There was no way I could think of making that happen. Once I realized it is the straight rear visor you need, it all became much clearer.
The only reason I haven't done it is that it makes the front of the 400 look like a Burgman 650...and I like "svelte" more than "lardy". :D .
Chris |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7560 Registration date : 2010-02-03
| Subject: Re: Those dang expensive leg deflectors Sat Sep 17, 2011 5:09 pm | |
| I seam to remember someone making them out of the black abs garden and sidewalk edging and they mounted under the floor mats ? |
| Subject: Re: Those dang expensive leg deflectors Sat Sep 17, 2011 8:43 pm | |
| Daboo, you have enlightened me. Now it all makes sense. I kept thinking "there's no way to do that bend", but it turns out there is no bend to do. I'll start looking into those.
Roger, you should look at John123s post above. It sounds similar to what you are talking about.
All, another idea I had was to ask Clearview if they would be interested in adding these to their product line. I know for sure they could fabricate them, but I don't know if the volume would make it worth their while. If I get any response I'll let everybody know. |
PHXScooterBill Maxi-Scooter Rider
Number of posts : 142 Location : Miami, Oklahoma, USA Points : 5074 Registration date : 2011-06-07
| Subject: Re: Those dang expensive leg deflectors Sun Sep 18, 2011 12:52 am | |
| The guy that sold them on ebay was the same maker of "Three Brothers Backrests". If you click on their webpage for it, you'll see "Item Not Found". A few months ago, I emailed him and he said he no longer regularly makes them (he used to for $59.98, but he said the price of materials has since doubled). He then said that he may be able to special make them for requests for $79.98 delivered, but I never got back to him. Personally, I think his flat rubber leg shields are ugly, unless one paints them the way kjrman did as seen in his gallery pictures. The real Honda ones sold in the UK are far better looking as they curve inward & don't make the S-Wing look as fat. But I too would be interested in which model truck window visor fits our Silverwings, and more importantly, specifics on exactly where you would attach or screw them onto the current floorboard. |
Vealie Scooter Rider
Number of posts : 15 Location : Barnsley UK Points : 4835 Registration date : 2011-09-18
| Subject: Re: Those dang expensive leg deflectors Sun Sep 18, 2011 5:15 am | |
| Craig pm for you.
Hi I'm new... Been riding a while and decided to get an old SW to take the strain off my other bike which was getting a few to many miles on it. I wish I'd had it years ago as it's been a treat. That cavern under the seat is dead handy, I'm sure I'll do a bit of touring on it as so comfy and easy to get along with. |
Number of posts : 3838 Age : 75 Location : Seaham, Co Durham, UK Points : 9709 Registration date : 2009-06-29
| Subject: Re: Those dang expensive leg deflectors Sun Sep 18, 2011 5:33 am | |
| I know for sure they could fabricate them, but I don't know if the volume would make it worth their while.Presumably. that's the same reason the Honda ones are expensive.
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8560 Registration date : 2010-02-17
| Subject: Re: Those dang expensive leg deflectors Sun Sep 18, 2011 8:22 am | |
| Vealle, welcome to the forum. It would help you if you go to the "introductions" section and post about yourself and riding experiences and habits. That way people will be able to respond to your posts better. We're happy to have you here. |
| Subject: Re: Those dang expensive leg deflectors Sun Sep 18, 2011 12:11 pm | |
| The first ones that (Model28a) described, the ABS garden and sidewalk type, I did like at all and ended up throwing them away.
Scooter Bill is correct, it was the Three Brothers that were selling the hard rubber ones for $59.98 I bought a few years back and still use. I like the fact that it makes me look wider from the front and they work just fine. To bad they are not selling any longer. |
