Replacing drive rollers- Belt I_icon_minitimeby MikeO Yesterday at 6:23 pm
Replacing drive rollers- Belt I_icon_minitimeby POCAHONTAS Yesterday at 6:05 pm
Replacing drive rollers- Belt I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Replacing drive rollers- Belt I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Replacing drive rollers- Belt I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Replacing drive rollers- Belt I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Replacing drive rollers- Belt I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Replacing drive rollers- Belt I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Replacing drive rollers- Belt I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Replacing drive rollers- Belt I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
wingmann
JeffR_
8 posters
Number of posts : 921
Replacing drive rollers- Belt Empty
PostSubject: Replacing drive rollers- Belt   Replacing drive rollers- Belt I_icon_minitimeThu Oct 20, 2011 2:07 pm
I've been following the topic of Belt and Roller replacement. I have now over 13000 mls up, so changing the belt may soon crop up. Thanks to Jeffs pictorials i don't see a problem with the belt. I get the feeling most people would opt for the Dr pulley re placement rollers as opposed to the J Costa. My question would be, when should the Rollers be changed, is a particular mileage recommended? or is there something to look out for when inspecting/cleaning which tells you they need replacing? Smile
JeffR_
JeffR_
Number of posts : 1103
PostSubject: Re: Replacing drive rollers- Belt   Replacing drive rollers- Belt I_icon_minitimeThu Oct 20, 2011 3:27 pm
You would need to inspect for flat spots on the rollers but from what I understand they should last about 25,000 miles. I'm not sure if you meant Dr Pulley sliders instead of rollers. I like the sliders since they seem to make things even smoother, and Im' not sure if they make rollers. But if you don't see flat spots i would just keep them in if you are happy with them.
Number of posts : 2387
PostSubject: Re: Replacing drive rollers- Belt   Replacing drive rollers- Belt I_icon_minitimeThu Oct 20, 2011 4:45 pm
x
wingmann
wingmann
Number of posts : 58
Registration date : 2010-08-22
PostSubject: Re: Replacing drive rollers- Belt   Replacing drive rollers- Belt I_icon_minitimeThu Oct 20, 2011 8:01 pm
I changed to Dr pully at 6000 miles on my new silverwing just to have the performance of the sliders and I found a small flat spot on one of my stock rollers with only 6000 miles on them.
donkeyhater
Number of posts : 20
Registration date : 2011-09-18
PostSubject: Re: Replacing drive rollers- Belt   Replacing drive rollers- Belt I_icon_minitimeFri Oct 21, 2011 1:19 am
Dr. Pulley ( unionmaterial.com ) manufactures slider weights and roller weights (like stock rollers).
The service limit (minimum diameter) for your stock roller weights are 27.5mm (1.08 in.)
TNG
TNG
Number of posts : 32
Registration date : 2011-09-23
PostSubject: Re: Replacing drive rollers- Belt   Replacing drive rollers- Belt I_icon_minitimeFri Oct 21, 2011 7:04 am
Does anyone have a pdf service manual in English?
Thanks in advance! cheers
geo_tng@yahoo.com
PostSubject: Re: Replacing drive rollers- Belt   Replacing drive rollers- Belt I_icon_minitimeFri Oct 21, 2011 9:29 am
To my knowledge there is no softcopy Service Manual in English. The pdf Service Manual in German was done via a scanner.
TNG
TNG
PostSubject: Re: Replacing drive rollers- Belt   Replacing drive rollers- Belt I_icon_minitimeFri Oct 21, 2011 10:52 am
Thank you very much!
I already have one in German. Sad
If someone needs ...... an email to geo_tng@yahoo.com Wink
PostSubject: Re: Replacing drive rollers- Belt   Replacing drive rollers- Belt I_icon_minitimeFri Oct 21, 2011 12:58 pm
Thanks very much for the speedy response.Iam not mechanically adept enough to measure the wear tolerances. If there is little wear that seems to be acceptable at my low mileage. I will only be changing the belt if i get the warning light,and at the same time cleaning and inspecting. Iam very happy with my bikes performance and MPG. Can i just confirm that to reset the V light Both H and M Buttons need to be held down and kept down for a few seconds before and after turning ignition on. Smile
GaryL
GaryL
Number of posts : 237
PostSubject: Re: Replacing drive rollers- Belt   Replacing drive rollers- Belt I_icon_minitimeFri Oct 21, 2011 4:36 pm
Hold the buttons down until the V light starts to blink, then release.
The light will come on at 16,000 mikes regardless of the condition of the belt... it is an automatic alert designed into the electronics to serve as a reminder that it is due.
» Replacing the drive belt.
» Replacing drive belt
» Ordered New Drive Belt and Rollers/Pins
» How many miles before replacing CVT belt
» Belt rollers
