Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeby sonuvabug Today at 4:19 pm
Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeby sonuvabug Today at 4:17 pm
Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeby sonuvabug Today at 4:06 pm
Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeby JohnyC Yesterday at 10:04 am
Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
aidanpryde18
Number of posts : 28
Registration date : 2011-04-29
Strange Noise from Transmission (Not Clutch Squeal) Empty
PostSubject: Strange Noise from Transmission (Not Clutch Squeal)   Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeTue Nov 01, 2011 10:54 am
I woke up this morning and went down to warm the bike up before going to work. I do it every morning once it gets cold. It was about 38 when I woke up.
I start the bike and it starts up fine but it was making an awful noise, emanating from the variator compartment.
Kind of a squeaky belt plus something else. I blipped the throttle to see if it would go away but it didn't.
Over time as the rest of the bike warmed up the noise lessened until it was an on/off kind of thing. By the time I got to the interstate, about a mile away, the noise was gone.
I figure it was just cold metal and maybe the belt slipping against it a bit, but I want to make sure it isn't something more than that.
The belt is relatively new, maybe 2000 miles on it.
Should I check it out, lube any points, put 5w in the final drive instead of the 10 that is in there?
This is my first winter with the Swing so I want to make sure that I am doing it right.
Thanks for the help
Number of posts : 2392
PostSubject: Re: Strange Noise from Transmission (Not Clutch Squeal)   Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeTue Nov 01, 2011 11:04 am
For me it sounds, (no pun,) normal for a cold start in my view. I too start the Wing early in the colder months, if the noise is overly discernible I ride off so as to not irritate the neighbours. That tends to get rid of noisy engine/transmission noises pretty swiftly.
I suppose there are many factors, oil viscosity - (the oil will take longer to disperse around the engine,) belt condition to name two.
Bit difficult to give you a fair reply not being able to listen to it. My loud may not be loud to you!!!
toolboxjesse
toolboxjesse
Number of posts : 330
PostSubject: Re: Strange Noise from Transmission (Not Clutch Squeal)   Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeTue Nov 01, 2011 12:45 pm
If it's happening when the bike isn't moving it wouldn't be the final drive. It might be one of the clutch assembly bearings spinning against the final drive input shaft.
Jesse
Number of posts : 2387
PostSubject: Re: Strange Noise from Transmission (Not Clutch Squeal)   Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeTue Nov 01, 2011 3:30 pm
x
aidanpryde18
PostSubject: Re: Strange Noise from Transmission (Not Clutch Squeal)   Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeWed Nov 02, 2011 7:40 pm
Yes, it is 10w-30. I just got lazy and shortened it in the description.
I cleaned everything really well when I changed the belt and sliders. That was only 1500 miles or so ago.
As for the possibility of a bearing issue, would that go away once the bike warmed up?
PostSubject: Re: Strange Noise from Transmission (Not Clutch Squeal)   Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeWed Nov 02, 2011 7:50 pm
x
buddy19520
buddy19520
Number of posts : 378
PostSubject: Re: Strange Noise from Transmission (Not Clutch Squeal)   Strange Noise from Transmission (Not Clutch Squeal) I_icon_minitimeWed Nov 16, 2011 4:32 pm
So what made the noise?
» Clutch Squeal?
» Strange noise at 5 mph!
» Belt slipping or clutch slipping?
» Strange Noise
» [Solved] Clutch/Variator squeal fix?
