Coolant change, refill volume question I_icon_minitimeby JohnyC Today at 5:39 am
Coolant change, refill volume question I_icon_minitimeby JohnyC Yesterday at 10:04 am
Coolant change, refill volume question I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Coolant change, refill volume question I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Coolant change, refill volume question I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Coolant change, refill volume question I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Coolant change, refill volume question I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Coolant change, refill volume question I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Coolant change, refill volume question I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Coolant change, refill volume question I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
2 posters
Paulk
Number of posts : 6
Coolant change, refill volume question Empty
PostSubject: Coolant change, refill volume question   Coolant change, refill volume question I_icon_minitimeSun Nov 20, 2011 6:15 pm
Im changing coolant on my 2007 Swing. When I drained almost 2 litres came out. When filling up only about 3/4 litre went it before level topped up at the filler neck. After 30 minutes the level dropped very little, there is air in the system. I am afraid to run the engine with so little coolant in it. How much coolant should be going in before starting?
Comments much appreciated,
Paul
old fart
old fart
Number of posts : 85
Registration date : 2009-02-02
PostSubject: Re: Coolant change, refill volume question   Coolant change, refill volume question I_icon_minitimeSun Nov 20, 2011 10:09 pm
run it
the water pump will circulate the fluid and displace the air.
If overheating is a concern simply watch your temp guage.
I just changed mine about one month ago and ran it after filling.
Topped it up.
No problems.
Paulk
Number of posts : 6
PostSubject: Re: Coolant change, refill volume question   Coolant change, refill volume question I_icon_minitimeMon Nov 21, 2011 7:30 pm
Factory Service manual 02-07 pg. 6-5 says to drain with sidestand applied, reinstall drain plug and new washer. After that "Place scooter on its centrestand on flat level surface" and fill the reserve tank and the system up to the filler neck. It even says is another time in slanted italics at the top of the same page.
Ignoring the manual I then proceeded to follow bigbirds suggestion to put the bike on the sidestand and the system took pretty well as much coolant as came out, most of the air bubbled out.
I have revised my manual to lean the bike when draining an filling and use centrestand after to run and check level.
» Coolant Change
» Coolant change
» Coolant change.
» Coolant change
» coolant change - what needs to be removed
