powpilot Scooter Rider
Number of posts : 45 Age : 82 Location : Benbrook, Texas Points : 3851 Registration date : 2014-06-30
| Subject: Coolant Change Fri Jun 26, 2015 9:13 am | |
| Finally got up the courage to drain and replace the coolant in my 2003 SWing. Not too bad a job using the instructions in the service manual and comments in a couple of threads on this forum.
I really don't see how the job can be done without removing the lower skirt on the left side although the manual doesn't call for it. I think I removed six screws to free the tupperware and that gave me sufficient access to the drain bolt.
Draining the reserve tank was accomplished with a cheap siphon pump.
I took out right around two quarts of coolant and put just slightly more than that back in. The system requires around 3 quarts, so I'm guessing I didn't get all of it out of there.
The job took about an hour and with an hourly labor rate of $120 at my local Honda shop, I figure that it was an hour well spent.
Gary |
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8557 Registration date : 2010-02-17
| Subject: Re: Coolant Change Fri Jun 26, 2015 9:53 am | |
| Make sure you followed the instructions to check the coolant after circulation. I needed to add more after I did mine. You're right about the manual and help from others on this forum saving money. |
| Subject: Re: Coolant Change Fri Jun 26, 2015 3:00 pm | |
| - Hi Yo wrote:
Make sure you followed the instructions to check the coolant after circulation. I needed to add more after I did mine. You're right about the manual and help from others on this forum saving money. I checked a couple of times, once after running it on the stand then again after a 20 minute ride. I will check it one more time time after riding a bit more. I appreciate the cautionary tip! Gary |
| Subject: Re: Coolant Change Fri Jun 26, 2015 8:52 pm | |
