Fuel injectors I_icon_minitimeby JohnyC Today at 5:39 am
Fuel injectors I_icon_minitimeby JohnyC Yesterday at 10:04 am
Fuel injectors I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Fuel injectors I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Fuel injectors I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Fuel injectors I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Fuel injectors I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Fuel injectors I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Fuel injectors I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Fuel injectors I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Fuel injectors
squasher
Number of posts : 6
Registration date : 2011-06-12
Fuel injectors Empty
PostSubject: Fuel injectors   Fuel injectors I_icon_minitimeTue Dec 13, 2011 7:22 am
Hi, think my injectors could do with a clean - sometimes getting occassional misfire / vibration coming through floor boards, nothing drastic though. Can they be cleaned using an additive or is the only way to take them out and have them cleaned professionally - if so has anyone ever done this - any help most appreciated as it ain't in the manual! Thank you.
Number of posts : 1995
PostSubject: Re: Fuel injectors   Fuel injectors I_icon_minitimeTue Dec 13, 2011 7:35 am
You can indeed use an additive to clean the injectors. Follow the mix ratio printed on the additives label.
ulflyer
ulflyer
Number of posts : 153
Registration date : 2011-10-27
PostSubject: Re: Fuel injectors   Fuel injectors I_icon_minitimeTue Dec 13, 2011 7:50 am
I've had good results from Sea Foam in my lawn tractor, aircraft engine, and other small engines. Haven't needed to use it in my current bikes/trike. Lots of guys on the oil forum use it regularly.
Number of posts : 2387
PostSubject: Re: Fuel injectors   Fuel injectors I_icon_minitimeTue Dec 13, 2011 8:16 am
x
PostSubject: Re: Fuel injectors   Fuel injectors I_icon_minitimeTue Dec 13, 2011 11:32 am
Yeah, What BigBird said.
You can remove the right side floor skirt body panel. That will expose the ignition coil and wires. Give the works a good healthy spritz of WD-40. That will help purge any moisture from micro cracks in the coil and adjacent wires.
After the WD dries you can take the scoot out for a nice dry ride. And after everything is well warmed & dry you can return home & give the works a good spritz of Silicone spray. That will seal those micro cracks from moisture and most likely resolve your problem.
Just why Honda decided to locate the ignition coil in such a vulnerable location is beyond me. Being there getting hammered by all the roadside potholes and soaked with all the puddles seems like a less-than-wise decision.
Fuel injectors
» Fuel cap won't come off
» Injectors cleaning
» Fuel tank removal (fuel pump replacement)
» is there a software for mapping the gas injectors on the 2003 silverwing
» Out of fuel
