After market Metal Wheel/Tire Stems? I_icon_minitimeby sonuvabug Today at 4:19 pm
After market Metal Wheel/Tire Stems? I_icon_minitimeby sonuvabug Today at 4:17 pm
After market Metal Wheel/Tire Stems? I_icon_minitimeby sonuvabug Today at 4:06 pm
After market Metal Wheel/Tire Stems? I_icon_minitimeby JohnyC Yesterday at 10:04 am
After market Metal Wheel/Tire Stems? I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
After market Metal Wheel/Tire Stems? I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
After market Metal Wheel/Tire Stems? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
After market Metal Wheel/Tire Stems? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
After market Metal Wheel/Tire Stems? I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
After market Metal Wheel/Tire Stems? I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
2 posters
Dimond
Dimond
Number of posts : 540
After market Metal Wheel/Tire Stems? Empty
PostSubject: After market Metal Wheel/Tire Stems?   After market Metal Wheel/Tire Stems? I_icon_minitimeThu Jan 26, 2012 3:13 pm
I got my SWing used at 17,000 miles and now it has nearly 21000 miles and needs a new set of tires (rear mostly but will replace front at same time). When I first got my SWing I noticed a 'hissing' sound when I would fill up the front tire - so I took it to the dealer to have them check it out. The tire was fine but the front valve stem rubber was horizontally 'cracked' and needed to be replaced (and it actually broke in half in the mechanics hand as he was removing it - so they say). I try now not to stress/bend the front stem when I put in air; however, I am looking at alternative metal valve stems that may better resist forces acting upon it so as avoid a repeat of what may have happened to my front valve stem. I got on a couple of bike forums and found that some riders have elected to go with metal valve stems (that seal on outside and inside using rubber gaskets). There are online sites that sell metal valve stems and the price differential seems minimal between metal vs. OEM valve stems. The OEM front stems (7/8 inch high off rim) bend a lot so I am assuming that there is no metal that extends fully down the stem into the tire. I am torn between using using 3/4 inch metal stem that goes straight up vs 85 degree metal stem that does out the side -but my gut says go with the 85 degree as it will likely be easier to add air. The back wheel OEM is metal with rubber where it joins the wheel - and it seems as if the metal must extend directly into the tire - but this is just a guess. For the back I am thinking of staying with OEM or going with the 85 degree metal stem that is oriented 180 degrees (i.e., does not go through any support bracket). I am GUESSING that these metal stems will fit my SWing if it has an 11.5 mm hole (0.453 inch) in the rim ; however, the rear 85 degree metal stem may need to be oriented 180 degrees from the existing one as it likely will not line up with the bracket that helps position/brace the OEM rear valve stem from excessive flexing.
Finally, my questions (assume that either OEM or Metal get changed out every time a tire is changed):
1. Can anyone confirm that the wheel rim hole is approximately 0.453 inches in diameter?
2. Have you had any bad stem experiences that would lead you to consider installing metal stems?
3. Do you think that it would be a good idea to (at tire change) install metal stems on the front and if so, would you go with the one that is straight up or the 85 degree model?
4. Do you think that it would be a good idea to (at tire change) install metal stems on the back?
5. Is there metal throughout the OEM front stem? Rear stem? How are they constructed?
6. Any other comments/suggestions regarding stems?
Thanks for considering this topic.
REFERENCES:
Motorcycle Forum Discussion on Stems
http://www.goldwingfacts.com/forums/view_topic.php?id=128305&forum_id=1&jump_to=1507096
http://www.st-riders.net/index.php?topic=3887.0
http://www.goldwingfacts.com/forums/forum1/116050.html
Links to Metal Stem Supplier Sites
1st one listed for front wheel and 3nd to last listed for back or front wheel
http://kurveygirl.com/shop/index.php?cPath=27
http://yourtireshopsupply.com/category/9_419/passenger-valves-enkei-valves
The manufactures noted for metal valves seem to be Enkei, Haltec, and Beico.
Manufacturer Sites
beico.com
haltec.com
enkei.com and blog.enkei.com [can't actually find Enkai wheel valve stems]
PostSubject: Re: After market Metal Wheel/Tire Stems?   After market Metal Wheel/Tire Stems? I_icon_minitimeThu Jan 26, 2012 4:08 pm
The Arietes valves I have do not need to be changed out each time.
Light weight aluminum 90 degree valve stems fits most Japanese OE wheels with 11.3mm valve stem holes.
11.3 millimeters = 0.44488189 inches
Which is the size I used.
The metal stems leaked less and are not susceptible to heat.
https://www.silverwing600.com/t3669-1700-miles-around-washington-and-oregon-in-9-days#33320
http://motowheels.com/i-7442150-ariete-aluminum-valve-stem-pair-11-3mm-japanese.html
I did both.
The rear metal bracket is no longer required to hold the stem. I would suggest cutting to prevent interfering with inflation.
Dimond
Dimond
PostSubject: Re: After market Metal Wheel/Tire Stems?   After market Metal Wheel/Tire Stems? I_icon_minitimeThu Jan 26, 2012 5:35 pm
Thanks Bill for your comprehensive response. I just put a pair of Arietes valves ($30 for a pair) on order - one for the front and one for the back wheel (went with KurveyGirl.com as they are an adjacent state). Hopefully they will be installed next week. Do you know if they use a standard Honda equivalent stem internal core that can be removed by standard Honda equivalent stem core extractor tools? The Arietes looked squatter, more robust, and with a simpler nut-washer sealing mechanism than other manufacturers noted in my post - all of which I think is a good thing.
PostSubject: Re: After market Metal Wheel/Tire Stems?   After market Metal Wheel/Tire Stems? I_icon_minitimeThu Jan 26, 2012 7:42 pm
I was the extractor and used a standard knife blade to cut the rubber.
Do not screw the nut on the Ariete nut on until you have the Ariete installed ... the nut has thread sealant material.
» Valve stems
» Car tire back wheel trike
» 2003 silverwing hot rear wheel and tire
» rear tire/wheel valve failure
» darkside tire, front wheel wobble at high speed (80+mph)
