| Givi Top Boxes | |
Guy Scooter Rider
Number of posts : 37 Age : 91 Location : Sand Springs, OK Points : 4916 Registration date : 2011-07-17
| Subject: Givi Top Boxes Tue Jan 31, 2012 11:10 pm | |
| Basically, what is the difference between Givi's Monolock and their Monokey cases? I am considering either the Monokey E-30 or the Monolock E-300 and the rear lights and back rest pad. All suggestions appreciated. Thanks |
Number of posts : 2453 Location : Georgetown, Tx Points : 8348 Registration date : 2008-12-23
| Subject: Re: Givi Top Boxes Tue Jan 31, 2012 11:44 pm | |
| - Guy wrote:
- Basically, what is the difference between Givi's Monolock and their Monokey cases?
http://www.giviluggage.co/givi-luggage-explained/the-difference-between-the-givi-monolock-monokey-technology/ |
| | | john grinsel Curmudgeon
Number of posts : 3309 Age : 85 Points : 9435 Registration date : 2009-08-18
| Subject: Re: Givi Top Boxes Wed Feb 01, 2012 10:46 am | |
| Above ref explains difference. My E-46 Monokey has survived over 500,000 miles of hard daily use. Go with the more expensive. You get what you pay for.
Buying another box--I would go for Givi Trekker, as you can open it part way, it has square corners.
Box mounted back rests tend to beat passenger up. Better Givi passenger back rest that mounts solid to bike---as I recall I had one on my SilverWing and have one on my last 2 Burgman 400's.
I found Givi lites not greatest in world....but connecting method to box is great. I found as box aged, red truck marker lite made great/cheap extra stop lite.
Of the many motorcycle/scooter aftermarket junk available----Givi works well/fits well and does the job.....and doesn't let you down.
| | | MikeO Site Admin
Number of posts : 3830 Age : 75 Location : Seaham, Co Durham, UK Points : 9675 Registration date : 2009-06-29
| Subject: Re: Givi Top Boxes Thu Feb 02, 2012 8:47 am | |
| I don't know about the Trekker but agree with everthing else John said. Incidentally, the givi separate backrest WON'T fit on the 650 Burger if it's got a topbox fitted - one up for the Silverwing! |
Number of posts : 4214 Location : York, North Yorkshire, England UK Points : 9418 Registration date : 2010-11-16
| Subject: Re: Givi Top Boxes Thu Feb 02, 2012 6:26 pm | |
| - MikeO wrote:
- Incidentally, the givi separate backrest WON'T fit on the 650 Burger if it's got a topbox fitted - one up for the Silverwing!
The 650 Burgman Executive already has a very comfortable backrest but you have to remove it to fit the Givi Monorack. It's pretty easy to do because because the rack bolts onto the three holes that held the backrest. On the older basic 650 Burgers with no backrest you have to drill three holes in the Tupperware. Even that is pretty straightforward because the underside of the panel is pre-marked with the positions to drill the holes. Then you can mount either a rear carrier or the 650 backrest. |
| | | Daboo Super Scooter Rider
Number of posts : 271 Age : 72 Location : Seattle, WA Points : 5738 Registration date : 2009-12-08
| Subject: Re: Givi Top Boxes Sat Feb 04, 2012 10:21 pm | |
| Givi makes it sound like you get a substantially better top box with the Monokey than the Monolock. I suppose it depends on what you're looking for. I frankly don't see the advantage of spending the extra money.
I looked at a Monolock and Monokey top case in the dealership one day. There was little difference between the two that I could see, and nothing that could justify spending the extra money. I asked the salesman, and he couldn't point out anything either. Especially since when you buy the Monokey, you have to buy the mounting plate. With the Monolock, the mounting plate is included.
Just as a point of comparison, the top box I bought for my 2007 Burgman 400 was a Bestem 2012. It cost me @$80 total. That's the top box and mounting plate for that price. It held up just fine for carrying cases of Costco Soy Milk and the 40 lb box of bird seed they sell. I used that inexpensive Bestem 2012 case for @49,000 miles. That's more miles than most of us will ride in the lifetimes of our scooters...and it held up just fine.
My point is the Givi Monolock top boxes are really decent boxes. The largest, I believe, is the e470...the one I bought from Kiwi Dave. The quality is like comparing a Chevy (Bestem) with a Cadillac (Givi Monolock). Yet even that Chevy top box looked good and did everything I asked of it.
One consideration to make is the amount of loading you can put on your bike. I'm not talking about the load capacity advertized by Givi, but what Honda calls out for the max load in that area. The Givi Monokey V46's shipping weight is 30lbs. The Givi Monolock e470's shipping weight is 23lbs. So while the Monokey will supposedly carry more weight...for all those times you're not carrying 40lbs of bird seed, you've got more weight hanging back there above and behind the rear wheel. On some bikes, the weight of the Givi Monokey alone, is the total max weight of what you can put back there.
Chris |
| | | MikeO Site Admin
| Subject: Re: Givi Top Boxes Sun Feb 05, 2012 4:57 am | |
| The weight difference is the key - the Monokey boxes are much stiffer than the Monolock ones, being double-skinned round the sides and therefore do not flex. The carrying-handle and locking arrangements are much better on the more expensive box. I've had two Monolock boxes and one Monokey, which is the one I have now I've owned and used for six years. The Monolocks were good but, for me, the Monokey is far superior. |
| Subject: Re: Givi Top Boxes Sun Feb 05, 2012 7:16 am | |
| Look on boxes.....GIVI is expensive, heavy my Monokey----but works well and any top box up high and back is about like an arrow with a rock tied to the rear. On this top box thing----best solution for money----large plastic tool box--yellow works great----drill out rear wing at pre-marked holes, with thin rubber pad and fender washers, 6mm bolts good enough, bolt directly to wing. Cost should be under $30 US.
Add some reflectors/tape and great top box---even can lock with little lock, but who cares---underseat storage is for locking. Looking back at 57 years of doing this I have never had helmet stolen, by just leaving on seat---Italy 1959 had 2 guys try to steal my camping junk from back of bike....I caught them. Same trip,while taking nap, covering myself with ripped/scuffed worn out leather jacket as blanket----it was taken. I have ridden most of Europe/Japan/Korea/Central America----bigger fear today are the fat ladies with bleached blond hair in SUV's, on the phone as I ride on my scooter----they could kill me/you, |
| | | | Givi Top Boxes | |
