Wiring Diagram Needed I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Wiring Diagram Needed I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Wiring Diagram Needed I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Wiring Diagram Needed I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Wiring Diagram Needed I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Wiring Diagram Needed I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Wiring Diagram Needed I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Wiring Diagram Needed I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Wiring Diagram Needed I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Wiring Diagram Needed I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Wiring Diagram Needed Empty
PostSubject: Wiring Diagram Needed   Wiring Diagram Needed I_icon_minitimeThu Feb 09, 2012 4:44 pm
Does anyone know if there is a link where I can access the Wiring Diagram for a non-ABS FSC600? Or does anyone have a Wiring Diagram that they can post here.
I have an early edition of the factory Service Manual but the wiring diagram has several errors for switch connections as well as wire color codes.
I have been trying to trace several circuits but with the amount of errors I've come across I just can't trust the diagram any longer. It'd be quite a disaster if some wire got crossed and the ECU or Meter Panel got smoked.
Hopefully the Wiring Diagram from a later edition of the manual or a later model FSC600 (non-ABS) Silverwing will have the errors corrected.
FWIW I have an '03 Silverwing, but the wiring diagram for any year non-ABS FSC600 should do the job.
Thanks in advance.
Number of posts : 2008
PostSubject: Re: Wiring Diagram Needed   Wiring Diagram Needed I_icon_minitimeThu Feb 09, 2012 5:48 pm
Actually, there were a significant number of wiring differences for FSC vs JDM, (Japanese Domestic Model) and some of them unified over in years subsequent to the original bike.
The ECU in particular because Japan had a T-mode which changed the ECU and EFI programming and added more power at the expense of fuel efficiency.
I remember finding the old diagram on an obscure website. DennisB and a few others looked at it, and decided it was an expensive experiment nobody wanted to pay for. Also, as you've seen, some wires and connections on the diagram simply no longer existed.
Dan
Number of posts : 2778
PostSubject: Re: Wiring Diagram Needed   Wiring Diagram Needed I_icon_minitimeSat Feb 11, 2012 10:56 am
Hi Tim,
I can scan in the Honda Schematic in 2 pieces and make Jpegs of them for you. Will that work for you? I can remove the large page from my service manual. Over the years it's just barely attached in the book. It's much easier to look at once it's removed.
PostSubject: Re: Wiring Diagram Needed   Wiring Diagram Needed I_icon_minitimeSat Feb 11, 2012 11:44 am
Dennis,
Yes that would be a great help. Thank you.
PostSubject: Re: Wiring Diagram Needed   Wiring Diagram Needed I_icon_minitimeSat Feb 11, 2012 1:31 pm
Hi Tim,
PM was sent with jpeg's attached.
scomeau478
Number of posts : 1
Registration date : 2014-04-12
PostSubject: Re: Wiring Diagram Needed   Wiring Diagram Needed I_icon_minitimeSat Apr 12, 2014 5:56 am
I have a 2002 silver wing when I turn the key on I have no power new bat.12volt
PostSubject: Re: Wiring Diagram Needed   Wiring Diagram Needed I_icon_minitimeSat Apr 12, 2014 7:58 am
Hello scomeau478,
Try checking your fuses. They are under the seat. The Main starter fuse is located under the left/rear side cover under the black rubber boot.
https://www.silverwing600.com/t1010-left-rear-cover-removal-pictorial-main-fuse-access
After you get the problem solved, please introduce yourself to the group.
Colin B
Colin B
Number of posts : 586
Registration date : 2013-03-20
PostSubject: Re: Wiring Diagram Needed   Wiring Diagram Needed I_icon_minitimeSat Apr 12, 2014 10:22 am
Was the battery charged before it was installed?
» Hi Beam Break Out Connector
» Wiring diagram for almost everything but a SW
» Colour wiring diagram for early non-ABS
» Service Manual, Parts Manual, Wiring Diagram, etc pdf
» VIP trunk install
