| Kuryakin or heated grips | |
CSN Scooter Rider
Number of posts : 50 Age : 60 Location : Halton Hills, Ontario, Canada Points : 4756 Registration date : 2012-01-25
| Subject: Kuryakin or heated grips Sun Feb 12, 2012 2:34 pm | |
| I'm sure there is probably discussion somewhere on here regarding this. I have always used Kuryakin grips on my motorcycles as I need the wider grip as I have arthritis in my hands and it has always made it easier for me over the stock grips. So I was going to replace my swing with those, however, I also want heat and I don't really like the idea of wiring gloves/clothes to the battery. So can anyone recommend a good heated grip that is wide like the kuryakins and possibly even helps with vibrations? If there is nothing out there, has anyone tried gloves with a rechargeable litho battery and what kind of gloves did you get. They have to be able to ship to Canada. If I don't get the heated grips I'm thinking of getting the kuryakin grips which I'm use to and possibly a battery operated heated glove. Thoughts or suggestions? Thanks for your input in advance. ...Christina |
| Subject: Re: Kuryakin or heated grips Sun Feb 12, 2012 2:48 pm | |
| CSN, if you type "heated grips" into the search function at the top of the page. Ensure the 'Topics' button is highlighted and click 'Go' a plethora of topics on the subject will appear.
I was going to post a link or two but there are so many it would be easier for you to search. |
CSN Scooter Rider
| Subject: Re: Kuryakin or heated grips Sun Feb 12, 2012 2:50 pm | |
| Thank you, I'll try that |
dspevack Silver Wing Guru
| Subject: Re: Kuryakin or heated grips Sun Feb 12, 2012 3:45 pm | |
| Hotgrips.com You can also get grips that are up to an inch wider than stock, which means more real estate for your hand. Get the PWM heat control.
Dan |
CSN Scooter Rider
| Subject: Re: Kuryakin or heated grips Sun Feb 12, 2012 3:52 pm | |
| Hot grips is what my mechanic recommended but I couldn't tell what size the girth is. This is what he recommended for me. Is this the same as what you are referring to Dan? http://www.hotgrips.com/store.php?rn=121&action=show_detail |
| Subject: Re: Kuryakin or heated grips Sun Feb 12, 2012 5:19 pm | |
| Close. That is 4.75 inches long, which is standard for the Silverwing. Mine are the 5.75 inches long. 1 inch wider than stock. http://www.hotgrips.com/store.php?crn=210&rn=139&action=show_detail As long as the fit a 7/8 diameter handlebar, any length will work.
Don't forget either this: http://www.hotgrips.com/store.php?crn=201&rn=390&action=show_detail or this: http://www.hotgrips.com/store.php?crn=201&rn=389&action=show_detail
Look carefully at hotgrips info on open ended units and discuss the barweight situation with your mechanic when using grips that are longer than the metal bar they surround.
They aren't so long that you will lose rigidity, but the extra width is great especially if you decide later to use a throttle rocker or other device for palm rest.
Its complicated but I'll try to explain. The current grip is the width of your hand approx. Devices which go around your grip and add a palm rest take up part of that space near the outer end of it. When you hit the brakes in an emergency stop, your hands against the grips absorb the forward motion of your body. If the palmrest is in the way, you will have to roll your hand forward putting all the stress on your wrist. At that point an impact will break your wrist.
If you have the extra wide grip, your wrist rest will be out of your way and you will still have a full hand width grip, avoiding that problem.
Even if you don't use a throttlerocker or similar, the extra inch allows you to reposition your hands more comfortably.
Take a look at the link in my sig to my bike. You will see them installed. Dan
Fiddler Scooter Rider
Number of posts : 11 Points : 4750 Registration date : 2011-12-02
| Subject: Re: Kuryakin or heated grips Mon Feb 13, 2012 2:26 am | |
| - CSN wrote:
- Hot grips is what my mechanic recommended but I couldn't tell what size the girth is.
This is what he recommended for me. Is this the same as what you are referring to Dan? http://www.hotgrips.com/store.php?rn=121&action=show_detail I love HotGrips®. They are the best. Both the models your mechanic and Dan suggested have more girth than the original SilverWing grips. The model 401 HotGrips® are the same girth as the original. Measuring the original grips, they show a touch under 1 1/4 inches in diameter or about 3 7/8 inches in circumference. The HotGrips® model 475-875 and model 525-875 measure just a touch over 1 1/2 in diameter and 4 3/4 inches in circumference. (Thats with a sewing tape, not a high precision measure) The difference is from "hilt" to end weight length. The 475-875 has 4 3/4 inches between hilt and pommel but the model 525-875 measures 5 1/4 "hilt" to weight so it gives a bit more real estate to spread out on but will feel just as fat in the hand. Dan's model 575-875 will be 5 3/4 inches "hilt" to endweight giving the most room to spread out but still has that same girth of 1 1/2 diameter and 4 3/4 circumference. |
CSN Scooter Rider
| Subject: Re: Kuryakin or heated grips Mon Feb 13, 2012 5:43 am | |
What about vibration? Does it take away vibrations? I know that the kuyakins absorb a lot of vibrations. I am leaning towards this model and I think I'm going to suggest to my mechanic to get me the model Dan suggested to have that extra. If someone tells me that it also absorbs vibrations then I think this is what I'm going to go with. Thanks for the help. |
| Subject: Re: Kuryakin or heated grips Mon Feb 13, 2012 6:49 am | |
| I've never used the Kuryakin grips, so I can't compare them to those. The HotGrips aren't spongy but I feel less vibration than the original. The fatter grips feel better under my hands. |
| Subject: Re: Kuryakin or heated grips Mon Feb 13, 2012 8:10 am | |
| - Fiddler wrote:
- I've never used the Kuryakin grips, so I can't compare them to those.
The HotGrips aren't spongy but I feel less vibration than the original. The fatter grips feel better under my hands. +1 |
| Subject: Re: Kuryakin or heated grips Mon Feb 13, 2012 8:57 am | |
| Since grips are first of all a safety item....fit must me exact......and made exactly for SilverWing length grips. Bars are 7/8...pretty much standard except for HD and some Cruisers. There are at least two grip lengths out there,, SilverWing being the shorter.......exact fit on throttle side because putting bar end back on with grip too long=throttle that won't return. Could lead to real thrills.
Then electric hook ups......
Try Aerostich catalog for selection.
I am sure in some markets Honda has OEM heated grips.
Secret with stiff hands (mine are) proper fitting gloves/mitts and no death grip on bars. A NEP throttle stop, properly set up works wonders on long trips. Get off bike at least every hour. Scooter requires less wrist action on long day-----bike @ 400 miles, I take 2 aspirin, scooter hands ok @ 500------but boring.
| Subject: Re: Kuryakin or heated grips Mon Feb 13, 2012 10:37 am | |
+1 Mine are Honda ones. |
| Subject: Re: Kuryakin or heated grips Mon Feb 13, 2012 4:04 pm | |
| Aerostich sells the Hot Grips. they describe it as - Quote :
- This is the best heated grip system available.
I've not seen the Honda grips in person. My dealer said they could get them but the Hot Grips were what they recommended. Not trying to be argumentative, I just don't understand how a fatter grip is a safety issue. |
| Subject: Re: Kuryakin or heated grips Mon Feb 13, 2012 5:31 pm | |
| - Fiddler wrote:
- I just don't understand how a fatter grip is a safety issue.
John Grinsel is a bit of a purist. Very few variations from stock. He is all about safety first, and feels that stock is usually the safest route, and makes repairs easier due to parts availability He's entitled to his position and so are you. Dan |
| Subject: Re: Kuryakin or heated grips Mon Feb 13, 2012 5:43 pm | |
| - MikeO wrote:
- I am sure in some markets Honda has OEM heated grips.
+1 Mine are Honda ones. Mine too, and they are superb. |
MarkB Scooter Rider
Number of posts : 90 Age : 69 Location : Boston Points : 4909 Registration date : 2011-09-19
| Subject: Re: Kuryakin or heated grips Tue Feb 14, 2012 12:19 am | |
| I'm pretty happy with the Oxford heated grips I got from Twisted Throttle for something like $80. It has 4 heat settings and was fairly easy to mount and wire.
I never considered the extra length aspect but since I've been using the Crampbusters throttle assist - which I really enjoy - I can see how a wider grip would help. Right now I sort of have to scrunch my right hand to to left to get the most effect from the heated grip. |
