| Engine part location | |
robavi Scooter Rider
Number of posts : 26 Age : 68 Location : South East Florida Points : 5734 Registration date : 2009-05-02
| Subject: Engine part location Thu Apr 12, 2012 7:43 pm | |
| Where would the oil pump be on the silverwing? |
masscoot Silver Wing Rider
Number of posts : 438 Location : Central New England Points : 6177 Registration date : 2009-03-24
| Subject: Re: Engine part location Thu Apr 12, 2012 8:29 pm | |
| Find your oil filter, and follow it.
oil pump |
| Subject: Re: Engine part location Thu Apr 12, 2012 10:03 pm | |
| How does the relief valve work? |
KurtPerthWA Silver Wing Guru
Number of posts : 1711 Age : 75 Location : Belmont, Perth WA Points : 8153 Registration date : 2009-01-19
| Subject: Re: Engine part location Fri Apr 13, 2012 6:26 am | |
| Oil filter dirty....clogged up good pressure build up......can't get oot pressure build up lifts the valve....spring compressess oil gets out..... engine lives on Valve gets stuck......engine KA-BOOM! |
| Subject: Re: Engine part location Fri Apr 13, 2012 6:57 am | |
| So that explains that little bit of oil drops and the oil splatter in front of engine that most likely dribble down and under the engine? |
| Subject: Re: Engine part location Fri Apr 13, 2012 8:31 am | |
| nope. that may be a cam cover gasket........or head gasket leak I'd go looking...... the source of this evil. |
| Subject: Re: Engine part location Fri Apr 13, 2012 2:07 pm | |
| Is that normal for 32,000 miles? |
| Subject: Re: Engine part location Fri Apr 13, 2012 2:40 pm | |
Number of posts : 350 Location : Elkton , Maryland Points : 5096 Registration date : 2011-12-11
| Subject: Re: Engine part location Fri Apr 13, 2012 6:38 pm | |
| The real question is your engine leaking oil ? Do you have to keep adding oil every time you check the oil level ? If the level is staying the same then you can't have much of a leak if any to worry about.
