| oil level question | |
+4surlybiker58 bigbird Waspie cjuzda 8 posters |
cjuzda Maxi-Scooter Rider
Number of posts : 133 Location : Ontario, Canada Points : 5037 Registration date : 2011-05-16
![oil level question Empty](https://2img.net/i/empty.gif) | Subject: oil level question Fri May 11, 2012 6:13 pm | |
| I changed my oil and the level is about 1/8 inch above the top line. I know it's not good to over fill the oil but will it matter if it's just a little over? Also what is the easiest way to remove a small amount of oil?
Chris |
![Waspie](https://2img.net/u/3413/63/00/33/avatars/348-89.jpg)
Number of posts : 2392 Age : 72 Location : Portland, UK Points : 8073 Registration date : 2009-07-26
![oil level question Empty](https://2img.net/i/empty.gif) | Subject: Re: oil level question Fri May 11, 2012 6:18 pm | |
| I personally use a small syringe and small diameter plastic tubing. |
Number of posts : 2387 Location : Winnipeg Points : 7832 Registration date : 2010-05-02
![oil level question Empty](https://2img.net/i/empty.gif) | Subject: Re: oil level question Fri May 11, 2012 6:39 pm | |
![oil level question Empty](https://2img.net/i/empty.gif) | Subject: Re: oil level question Fri May 11, 2012 6:45 pm | |
| - bigbird wrote:
- cjuzda wrote:
- I changed my oil and the level is about 1/8 inch above the top line. I know it's not good to over fill the oil but will it matter if it's just a little over? Also what is the easiest way to remove a small amount of oil?
Chris Hi Chris. A little bit of overfill will not harm anything. A lot of overfill will cause oil aerating and with it troubles. As the crankpins and counterweights rotate, the turbulent air will suck up oil out of the sump, creating drag on the crank and interfering with oil flowing back into the sump. This is called windage, and it's a bad thing. How much excess oil will cause windage? It depends on the sump size and rpm of the engine. I would say 0.5L overfill may give you problems on a Swing.
Your wife's turkey baster does an excellent job of sucking up excess liquids. I'm sure she'll appreciate that afterwards. Thanks! Should I tell her I'm sure the turkey will test better too? |
![oil level question Empty](https://2img.net/i/empty.gif) | Subject: Re: oil level question Fri May 11, 2012 6:52 pm | |
![surlybiker58](https://2img.net/i/fa/i/avatars/gallery/Cinema_h/Cinema_h_85.jpg)
Number of posts : 350 Location : Elkton , Maryland Points : 5026 Registration date : 2011-12-11
![oil level question Empty](https://2img.net/i/empty.gif) | Subject: Re: oil level question Fri May 11, 2012 7:33 pm | |
| I always thought there were reliability issues with dry sump engines with the oil supply farther away from the bearing and crankshaft. If an an oil line broke or clogged you'd have major damage.
![oil level question Empty](https://2img.net/i/empty.gif) | Subject: Re: oil level question Fri May 11, 2012 8:45 pm | |
![oil level question 510-80](https://2img.net/u/3413/63/00/33/avatars/510-80.jpg)
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8483 Registration date : 2010-02-17
![oil level question Empty](https://2img.net/i/empty.gif) | Subject: Re: oil level question Fri May 11, 2012 10:22 pm | |
| Remember to not screw the dipstick in when checking the oil. Doing so will make it seem like there is more oil. Don't ask how I know. |
AAAA Silver Wing Rider
Number of posts : 442 Points : 5575 Registration date : 2010-11-14
![oil level question Empty](https://2img.net/i/empty.gif) | Subject: Re: oil level question Sat May 12, 2012 12:03 am | |
| - bigbird wrote:
Makes sense. The more that can go wrong, will go wrong. You have to remember that engines of that caliber, and type are only run for a matter of hours before being broken down and serviced. I get a year, maybe 2 years on my track bikes, and they get broken down and serviced every month or so, and a complete set of tires in a day or 2. Formula 1 powerplants spend all there time out of the cars for the most part. Being tested measured, rebuilt, and updated, except for the few hours of racing, and road testing. |
Windrider Maxi-Scooter Rider
![Windrider](https://2img.net/i/fa/i/avatars/gallery/Dessins_h/Dessin_h_71.jpg)
Number of posts : 189 Age : 85 Location : EastTexas Points : 5371 Registration date : 2010-07-05
![oil level question Empty](https://2img.net/i/empty.gif) | Subject: Re: oil level question Sat May 12, 2012 9:04 am | |
| Some of the Harleys have a dry sump system and them seem to work good. I have seen some with over 100000 miles. |
![oil level question Empty](https://2img.net/i/empty.gif) | Subject: Re: oil level question Sat May 12, 2012 9:06 am | |
![roadrunner](https://2img.net/u/3413/63/00/33/avatars/1001-96.gif)
Number of posts : 231 Age : 69 Location : Middleburg FL Points : 5275 Registration date : 2010-12-12
![oil level question Empty](https://2img.net/i/empty.gif) | Subject: Re: oil level question Sun May 13, 2012 7:26 am | |
The original Honda SOHC 750, which redefined performance and reliability for all motorcycling in 1969, is a dry-sump design. I personally put over 110,000 miles on a 1977 model before it needed a top-end refresh; the bottom end was still fine. It, like all Hondas, just needed religious oil changes to stay reliable. It had more problems with the small internal oil passages to the cam bearings than with the oil pump, tank, or external lines. The main advantage to a dry sump is that it allows the engine to be mounted lower in the frame, thus reducing the center of gravity -- that was a big deal on a tall and heavy four-cylinder motor. Wasn't necessary on the Silver Wing. |
