billc. Maxi-Scooter Rider
Number of posts : 189 Age : 76 Location : Atlanta, Ga. Points : 5616 Registration date : 2010-02-19
| Subject: Passenger floorboards Tue May 15, 2012 10:16 am | |
| Has anyone ever seen any passenger floorboards or larger pegs for the Silverwing that could replace or bolt on to the existing pegs? and perhaps fold up when not in use? thanks...billc. |
dspevack Silver Wing Guru
Number of posts : 2008 Age : 59 Location : Miami, FL Points : 8213 Registration date : 2008-12-27
| Subject: Re: Passenger floorboards Tue May 15, 2012 10:56 am | |
| Bill,
If you are looking for something cheap and prebuilt, I can't help you.
If you are willing to spend more, it should be relatively easy to remove the pegs that are there and have a welder weld whatever screws into the bike to whatever floorboard you like.
Dan |
| Subject: Re: Passenger floorboards Tue May 15, 2012 11:33 am | |
| Dan, I was kinda looking for an inexpensive add on, as I don't use the passenger pegs that often... thanks for your suggestion...billc. |
Number of posts : 1298 Age : 76 Location : Matheson, Ontario, Canada Points : 6132 Registration date : 2011-11-29
| Subject: Re: Passenger floorboards Fri Jan 17, 2014 5:48 am | |
| Looking for passenger floor boards. J&P Cycle has a adjustable set that look's like a good fit .# 5500090---- $144.99. look like all the parts are there to fit on the Swing.Has anyone installed passenger floor boards on there swing? |
